Question about Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A
Reddy heater 60,000
Lighting but not staying lit
2 Suggested Answers
  • 17 Answers
SOURCE: Reddy Heater 60,000 Model R60 only runs with top off.
Sounds lik the vent hole in the filler cap is plugged. Try cleaning it or replace the cap.
Posted on Oct 15, 2009
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Sw6p suburban won't stay lit. My 6 gallon hot water heat on my 2007 camper won't stay lit, I go and light the pilot light and it lights but I turn the gas up and it blows out please help
the thermal couple is likely bad .
when you release does pilot stay lit or only as long as you hold the button .
if it stays lit then the thermal couple is good
if it only blows out as you turn on the heat then its draft issue.
May 09, 2015 | Water Water Heaters
I have a Reddy heater RLP100. It will light easily but will not stay lit when you let off pilot
It's either the thermocouple or the limit switch on back of burner, disconnect coupler and jump the 2 tabs. if it works thats the problem if not it's the limit switch.
Feb 21, 2015 | Reddy Heating & Cooling
CAN YOU MANUALLY LIGHT A DOMETIC RM2652 PROPANE FRIDGE IN A 2006 TRAILER
It will not light manually as the ignition probe is electronically controlled. If it doesn't stay lit normally then it will more then likely not stay lit when trying to light manually.
b2d344ab-6ceb-4320-bc24-f6c38ab91df8.jpg ArctiCold Refrigeration We keep it cold
Jul 24, 2014 | Dometic RM2652 Refrigerator
Abs and brake light on
Hi have you checked the brake fluid level ?
Oct 07, 2017 | 2004 Honda Civic
I have a readyheater model 65-85 the flame will not stay lit im thinking thermal couple is there a way to test this part? or could it be another problem?
If your pilot light will not stay lit when you release pilot light button then chances are that your thermocouple is bad. Make sure that the tip of thermocouple is directly in line with pilot light. Tip of thermocouple should be cherry red if it is properly placed. If pilot will not stay lit then replace it. If you aren't sure about placement of thermocouple you can heat thermocouple with a seperate heat source. If you do this and pilot light stays lit then reposition thermocouple in pilot flame. If it still won't keep pilot burning then replace thermocouple. Hope this helps. Thanks.
Nov 19, 2010 | Reddy Heater-30-55,000 BTU Variable
Flame won't stay lit
bobdukw,
This is a classic reddy heater problem. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which should solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Sep 22, 2010 | Reddy RLP55V Utility Heater
My reddy 30 heater will not stay lit after starting I have held the switch down for longer than 30 sec but it just want stay lit
thats sounds like a thermocouple problem its located right by the pilote light assembly,,,rod shaped object
May 14, 2010 | Heating & Cooling
Reddy Heater 60,000 BTU Kerosene Forced-Air Heater #R60A Logo
41 people viewed this question
Top Reddy Measuring Tools & Sensors Experts
jdthefixer
Matt Olenzek
Matt Olenzek
Are you a Reddy Measuring Tool and Sensor Expert? Answer questions, earn points and help others
