Question about Dishwashers
I want to reset door latch on Bosch SHE3AR55UC
2 Suggested Answers
  • 457 Answers
SOURCE: our Bosch SHY66C05 door latch is stuck in locked position
you have to pull back the spring or replace the lock. the repair is pretty easy.let me know what happen.
Posted on Feb 26, 2010
Bosch oven error code F43; breaker reset doesn't work. Door ok (though it locked while using broiler). Beeps continuously. Worth fixing? OK to use gas burners without power? Smells very gassy.
Don't use any appliance that smells of gas or partially burnt gas. Time for a new one or a professional Bosch service engineer. Your call?
Here is the Error Code
F43Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; defective latch motor or its wiring.
  1. Check P24 connector on the power board.
  2. Ensure door latch switches are operating properly.
  3. Check that neither latch switch nor common wires are pinched to the appliance chassis.
  4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis.
  5. If F43 persists, replace power board.
Read more: http://www.appliancepartspros.com/repair-help/bosch-fault-codes.html#ixzz4TKlEr5YM
Bosch Fault Codes AppliancePartsPros com
Dec 20, 2016 | Bosch Ovens
I have a dishwasher bosch model SHE3AR55UC/07. I press the ON button to turn dishwasher on. And when I press START button, the dishwasher does not start.
Many Bosch dishwashers have a design flaw...the door will not fully close and pops out after you start it. When this happens the D/W will not run. You can go to the Bosch website to order the part to fix this and no they will not reimburse you nor acknowledge your email to customer service.
Aug 27, 2016 | Bosch Dishwashers
My Bosch Vision 300 series washing machine wont start?Why? What has to be done to it?
Michael, the door lock/latch mechanism should be tested, if faulty replace. Have a good repair Tech. check, diagnose and estimate repair. Make sure to at least look at the first link, it tells of a reset procedure that may fix your washers door latch problem. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://baubilt.com/?p=1318
How to replace washing machine door lock on Balay Bosch Neff and Siemens
http://www.repairclinic.com/Shop-For-Parts/a11b129/Bosch-Washing-Machine-Parts
Aug 22, 2016 | Bosch Washing Machines
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Bosch wiring diagram
Not for unskilled person to use. Contact service agent.
Aug 10, 2014 | Bosch SHE3AR55UC Builtin Dishwasher
Why will the door not stay closed ?
it could be the latch frame and casing but if no one has recently put a crowbar in to door lock to force your door open - i would say its an eletrical fault check the sensor on the door frame and on the door and make sure they line up while the door is closed and if thats the case i would say you have a fault with the hall sensor or ghosts haha just kidding
May 27, 2014 | Bosch SHE3AR55UC Builtin Dishwasher
Won't stay closed
check the seales on the sides of the unit or take appart the latch asemberly very easy may need replacing
Door latch is broken. Door wont close. Is it possible to buy replacement door?
you can purchase a door latch:
Repair Clinic:
http://www.repairclinic.com/Bosch-Dryer-Latch-Parts
eBay:
http://shop.ebay.com/i.html?_nkw=+dryer+door+latch&_sacat=0&_odkw=bosch+dryer+door+latch&_osacat=0&_trksid=p3286.c0.m270.l1313
Jan 10, 2011 | Bosch Axxis WTL 5400 Dryer
Bosch dishwasher won't latch
No you did good in ordering a latch ,that is a common issue i find with the bosch d/w, for no apparent reason the latch locks itself with the door open. Look at the door where the male part of the latch goes into the door, you will see that is locked. if you take it apart and manually unlock the latch u stand to break it. Again you did good on ordering the latch.
Jan 09, 2009 | Bosch 36 Inch Pyramid Chimney Hood - Black
Can't close Bosch Dishwasher door
I had same problem and was alarmed at the idea of taking the door apart, so I tried the 2 screwdriver option described below - it works!
Open door and get two small screwdirvers behind each side of the catch inside the top of the door and gently apply pressure. The catch should reset itself on 'open' and allow you to shut the door again.
Thanks to all for their postings and helpful advice!
Nov 10, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
94 people viewed this question
Top Dishwashers Experts
