Garden Logo
Posted on Jan 05, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Parts for a sunpak accent garden light
Can you still get parts for these lights as i love the lights but the bulbs/lamps have gone? Have searched several sites looking for these lights to no avail.
Many thanks
Michelle
[email protected]
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 404 Answers
  • Posted on Jan 05, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
404
Questions
0
Helped
157453
Points
971
Go to an electric wholesaler
2answers
Brake lights dont turn on toyota rav 4, whats the problem?
Check the switch on the break peddle , thay can work loose or renewal good luck colin
1helpful
How do i replace sunpak ms 4000 tube
Found 'em! Tocad has them, you just have to call to order. $62.15/ea - part S7300.
None of the brake lights on my daughters 2010 Hyundai Accent, come on when she steps on the brake pedal. why?
You listed this vehicle as a 2006 Accent, yet you write it's a 2010.
If 2006, it's probably the brake lamp switch. However, I've seen all three brake light bulbs burn out within days of each other.
If 2010, it's still under warranty.
Lamp light is blinking as well as the red standby temperature code, tried replacing bulb, still getting lamp blinking light
If the bulb did not fix it then it is probably the ballast that has gone out or the power supply board has failed. I usually replaced the ballast and power supply together. You can call 1-800-samsung or search online for the parts.
1helpful
My Sunpak Auto 383 Super will not fire on or off the camera. When I turn on the switch, the ready/test light lights immediately. I suspect the bulb is burned out, so I wonder if that can be replaced.
There can be one of many parts which is gone :
Flash tube,capacitor,trigger cap.or triggering switch.
Warning as it has 330 volts even when battery is removed do not open if you are not aware of the risks.
Sunpak 383 contains no bulbs inside.
6helpful
My license plate lights are out...what kind of bulbs do i need??
Check this reference guide...
2002 Hyundai Accent Car Lightbulb Size Guide
Low Beam Headlight Bulb Size: 9003/HB2
High Beam Headlamp Light Bulb Size: 9003/HB2
Parking Light Bulb Size: 2357A
Front Turn Signal Light Bulb Size: 2357A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 2357A
Rear Sidemarker Light Bulb Size: 168
Map Light Bulb Size: DE3175
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: DE3022
Trunk/Cargo Area Light Bulb Size: DE3022
From Sylvania Lamp Replacement Guide
License plate
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp.
I hope help you with this. Good luck (remember rated this help).
How do I change the license plate tag lights in 2005 Huyndai Accent?
remove the inner panel of boot lid to access rear of No plate light assy ? then the 2 x bulb holders are twist anti clockwise and lift out of each lamp replace bulbs and reassemble
Need spare bulbs/lamps for my sunpak 'accent' garden lights
michelle most lights are interchangable these days,take old one out and shop around
Jan 04, 2009 • Garden
Hyandia Accent
not sure which top tail light you mean? do you wish to replace bulb or actual lamp on the rear screen? this is the high level brake light ! OR do you wish to replace bulb in one of the rear tail lamps offside/nearside ? which ever ? the h/level brake light bulb is accessable for bulb from the rear panel on hatch behind lamp bulb is 16 watt capless push in type
Top Garden Experts
Jay Finke
Jay Finke
john h
