Toshiba Satellite m30 unlock bios
Challenge Code=7AK71-48TC2-DUR4U-U5P2X-DD6C5 pc sERIAL no= 7401722DH
PAeasop
  • 17 Answers
SOURCE: Toshiba Portege S100 Bios password
Nedacqua,
The only way to obtain the response for the challenge code is to send your unit to an authorized repair facility. I work at the depot repair facility in Lou.Ky. And we have to send a request to Japan or California to get the response code.
PAeasop
Posted on Apr 25, 2008
  • 47 Answers
SOURCE: toshiba satellite a105 bios password dont have
1), when taking your computer apart, take out the battery and unplug it always
2), Remove the plastic cover piece above the keyboard, called the keyboard bezel. this is the piece where you can see the speakers. it is a bit difficult to get the plastic retaining clips to pop loose, but if you are careful, you can use a small screw driver and slowly between the two screen mounts. this is done with the screen all the way back. you could use a paper clip with a little 1/8" bend at tip to do this also. (it is a tight working area) there are three retaining clips that have to come loose the others are fairly easy to pop out . once this is bezel is off the rest is fairly simple. please take your time and be patient as if your not you could damage it .
3), Remove the keyboard. Remove the two screws that are evident once the bezel has been removed. These hold the keyboard in place. Lift the keyboard up from the screw side and the retaining clips at the front of the keyboard will lift out. (there is no need to pry here). Once the keyboard is loose you will have to either leave it connected, just off to the side, or disconnect it from the mother board. The keyboard cable connector has a black clip along the top of it. just lift this clip up a little and the keyboard cable will slide out. (the keyboard cable does not have a fixed connector, but is just a ribbon that is held in place by the black clip along the top of the keyboard cable connector) Once you have removed it you will better understand what I mean.
4) Remove the wireless card. It is the only card visible at this point. It is connected by metal spring clips. just unclip in a similar fashion as removing ram. You do not need to disconnect the wires connected to card, just move card over to expose area below card.
5)you will see C88 clearly labeled right next the jack that the wireless card plugs into. There are two little solder squares (approx 1/16") at this location. *** At this point plug the power adapter to your computer again. ***
You will have to jump the two solder squares at label C88. .use a small wire or paper clip but make sure you removed all the coating off the paper clip first with pliers so it can make a good contact on both ends. hold it in place on these two solder contact squares and press the power button to boot your computer. here is a link to guide you for disassembly it is the same family of laptops although its for a a135
http://www.irisvista.com/tech/laptops/toshiba-satellite-a135/remove-mainboard-2.htm
Posted on Jul 08, 2009
  • 5 Answers
SOURCE: need to unlock phoenix bios password for toshiba satellite a135-s4527
remove the keyboard the mobo battery is there you need to unsolder one end of it, lift the leg, and turn it on that way for it to clear.. you will have to resolder once done.. have the skills or find someone that does... and you're set..
Posted on Aug 07, 2009
peepnklown
  • 175 Answers
SOURCE: unlock bios Toshiba Satellite Pro A60FR !
This WEBSITE should help you out:
http://www.tech-faq.com/reset-bios-password.shtml
Posted on Dec 08, 2009
Need drivers TOSHIBA Satellite M30 SYSTEM UNIT Model no. PSM30L-3K33XP Serial no. Z3118806P
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
May 29, 2011 | Toshiba Satellite Pro M30 Notebook
CRAQUER MOT DE PASS BIOS TOSHIBA SATELLITE M30 MERCI
To reset the BIOS password read the information from this link.
In case of your Toshiba laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper and I wouldn't recommend doing it especially if it's under warranty.
Apr 26, 2011 | Toshiba Satellite M30-S350 Notebook
Reset password cmos toshiba satellite A65-s1064
The only way to reset the cmos battery is to remove the battery from the back, open the bottom of the laptop and remove the button battery for 3-5 minutes. Replug in the battery and close up the case. Once completed, you can then create a new password.
Apr 08, 2011 | Toshiba Satellite A65-S1065 Notebook
Need updated BIOS for Toshiba Satellite M30 laptop mother board. Thank you.
You can download the BIOS updates for your model laptop from theToshiba WEB site from their download page. Make sure you enter the model ofyour laptop so you can get the correct BIOS update. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
Jan 17, 2011 | Toshiba Satellite M30 Notebook
Toshiba satellite m30 bios password
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
Jan 11, 2011 | Toshiba Satellite M30-S350 Notebook
On boot up it displays and asks for a password on Laptop
1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another:
Ctrl, Tab, Ctrl, Enter
The computer's response should be:
PC Serial No.= XXXXXXXXX
Challenge Code= XXXXX XXXXX XXXXX XXXXX XXXXX
Response Code=
2. Get response code from your local toshiba support center
Then follow the instructions the support guy will give you to unlock the laptop
Jan 15, 2009 | Toshiba Satellite R25-S3503 Tablet PC
Power on password for toshiba satellite m30-107
You can by shorting the CMOS/BIOS battery connector for 30 sec's with a resister pack (2.4 KOhms), but if you don't have any PC repair experience, don't try it!
"You can blow the motherboard if you get it wrong.."
I suggest you take it to a Toshiba repair shop, it will cost about $100 to have them do it for you.
May 08, 2008 | Toshiba Satellite M30 Notebook
Locled out, I forgot the password.
check you manual or with toshiba, but it is possible to get the bios reset you just need to have the right tools. It might be a disk or a setting in the bios itself.
Sep 01, 2006 | Toshiba Satellite R10 Tablet PC
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
