Question about Cub Cadet Garden
My 1811 cub cadet wont start
Oil is blowing out of top of motor
  • 48 Answers
SOURCE: I cant start my cub cadet cc989
sounds like a plugged high speed jet
Posted on Oct 24, 2008
blueextc3221
  • 15935 Answers
SOURCE: A short in the pto wiring perhaps?
Form what you are desribing you have a direct short, probaly in the wiring going to pto. I t has rubbed somewhere and is causing your short. Unplug the wires at connector close to your pto clutch and try it again and see if fuse stuill blows after you unhook it.
If the fuse still blows it is in the wiring going back up to thje switch. If the fuse does not blow after unhooking wiring connector the problem is in the clutch.
Thanks for using FixYa - a FixYa rating is appreciated!!
Posted on Feb 20, 2009
  • 376 Answers
SOURCE: finding the oil plug on Cub Cadet LT 1050 with Cohler engine
It is probably on the right side in the middle of the engine. It should have a yellow cap on the end of the drain. Take the cape off and slide about a 12" piece of 5/8" x 1/2" clear vinyl tubing (available at Home Depot, Lowe's, etc.) on the end, turn the plastic body to the left (about 1/4") and pull out about a 1/4". Oil will flow. Reverse to shut off.
Posted on Jun 12, 2009
  • 202 Answers
SOURCE: how do i change oil on a cub cadet riding lawnmower
is yours the newer cub with a kohler command engine? if so pop open the cap on the drain to expose the port.
remove the oil fill cap/ dipstick.
put the rubber hose on the end of drain spout and route it to a safe container.
push in on the spout and rotate counter clockwise and pull outward on it to begin draining the oil.
Posted on Jul 08, 2009
SOURCE: how do i reset the change oil light on a 1040 cub
The Service Monitor meter contains a service minder function that utilizes the 4-digit LCD display. The letters "CHG" will display followed by the letters "OIL" and then followed by the meter accumulated time. "CHG"/"OIL"/TIME will alternate on the display for five(5) minutes after the meter reaches 50 hours. The display will also flash as described above for five(5) minutes every time the tractor has been started during the maintenance time interval. The interval will occur every 50 hours and will be in effect for two(2) hours ( Example: this feature will display from 50-52 hrs., 100-102 hrs., 150-152 hrs etc...). While the LCD is displaying the "CHG"/"OIL"/TIME letters, the red LED "oil symbol" will also be flashing for the entire five(5) minutes. The meter display will return to normal function automatically after the reminder maintenance time interval of two(2) hours.There is no method of manually re-setting this Service Monitor gauge.
Posted on Sep 01, 2010
Cub cadet 3200 serie motor oil went up don't know if hydraulic oil or diesel fuel
All motor oils are rated by viscosity and type either mineral or synthetic.
Wal Mart oil is just fine if it's the same specs.
Mar 29, 2016 | Cub Cadet Garden
What type of oil do i use
(32 degrees and above, 30w oil) - (32 degrees to 0 degrees, 10w-30) - (32 degrees to -20 degrees below 0 and beyond -20, 5w-20 or 5w-30) Cub Cadets call for a low ash oil. it can be purchased at any cub cadet tractor dealership.
Jan 21, 2016 | Cub Cadet Snow Blowers. 28 in. Two-Stage...
My cub cadet ran for 15 mins then cut off. Screen said low oil so i checked the oil and it was full. Now it wont crank at all.
Hi Al
If it won't turn over there has to be a problem with the battery or the wires or connections, or components like the switch or solenoid.
I'd just start checking with a voltmeter and a continuity meter..
Dec 01, 2015 | Cub Cadet Garden
Troubleshooting
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
Cub cadet trouble shooting
bad rings need to rebiuld motor
Jul 04, 2014 | Garden
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub cadet troubleshooting
?huh? Thats TOTALLY UNSAFE and really hard on the starter motor. Check out MTDPARTS.COM
Feb 03, 2014 | Garden
Cub cadet ltx 1045 wont start, no spark.
remove the top cover from the engine and remove the small wire from the coil if still no spark the coil is bad
Aug 07, 2012 | Cub Cadet Garden
Garden Logo
46 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
