Question about Toshiba 42HL67 42 in. LCD Television
Toshiba Regza 42HL67US pink screen
My screen has a pink tint. Cannot fix it with the settings.
5 Suggested Answers
  • 290 Answers
SOURCE: Best picture settings for toshiba regza 42RV500e
Go to menu on your remote control and select picture setting and try selecting "default" setting to seeif you like the color, if not adjust contrast to about two thirds of the way and brightness to your liking and color to about the middle.
Posted on Jan 17, 2010
  • 4 Answers
SOURCE: toshiba regza 52xf550u has a 6 inch multi colored
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
Posted on Jun 21, 2010
  • 5 Answers
SOURCE: I have a Toshiba Regza 42HL67US
First you should lay the unit face down on a blanket or the like, being careful NOT to damage the screen. I don't have one in front of me right now but if memory serves well, there is a plastic cover on the back side of the base that you can pop off giving you access to the base mounting screws. Remove the 4 screws and viola, the base should slide off.
Posted on Jul 21, 2010
dduncan774
  • 760 Answers
SOURCE: I have jjust purchased a
I would have to say your micro is bad on your main board. If you just got the set, I would take it back or use your Warr and get it fixed.
Posted on Apr 04, 2011
How to adjust brightness
The set should have in the on screen customer menu settings for brightness, contrast, color, tint etc.
If in doubt consult the owner manual which will have instructions.
Aug 29, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have jjust purchased a 32inch Toshiba rv with Regza supposed to have full HD but when clicking on to an HD channel all I get is a pink flashing screen
Apr 04, 2011 | Toshiba Televison & Video
Color problem
32inch lcd toshiba regza the screen has a yellow tint
May 26, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
I have a Toshiba Regza 42HL67US that I want to wall mount...how the heck do you get it off the stand?
May 06, 2010 | Toshiba 42HL67 42 in. LCD Television
Multi colored lines running from top of screen to bottom
panel is cracked the cost of the repair is usually about 90 percent of the cost of the tv when purchased new. panel and labor. not worth if panel is cracked.
Jun 02, 2009 | Toshiba REGZA 47HL167 TV
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Toshiba 40" 1080p plays dvds with a red tint and no sound??
When connecting the dvd player using component cables and audio cables, go to the progressive scan setting on the dvd player and select it. Once I activated the progressive scan, the problem was solved.
Jan 26, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
LP70+ projects a dark rose/pink tint upon the screen
The pink tint produced by my LP70+ projector was not a lamp issue but a connectivity issue. I swapped the old cable with a good known cable and the tint went away.
Aug 14, 2008 | InFocus LP70+ Multimedia Projector
Red color abunDANT
Please verify model # from rear of set.PVAT! Look closely at signal PCB for signs of CRT coolant leak.
Oct 03, 2007 | Toshiba 42H82 42" Rear Projection...
Toshiba 42HL67 42 in. LCD Television Logo
44 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
