How to replace a backlight inverter board on Samsung P2270
rlamkin
  • 44 Answers
SOURCE: Replacing backlight inverter board
Not always but usually the inverter board is part of the display panel, way to much money to bother fixin.
Posted on Jul 03, 2008
Shuttle83
  • 1139 Answers
SOURCE: Inverter opertion
Hello davidweldon,
If the inverter board is bad, I would suggest that you replace the whole board unless you have a SMD (Surface Mounted Device) rework station, and a background in electronics. I have worked on TVs where people have tried to remove SMDs and it never is an easy thing to do, so I would again suggest that you replace the whole board, because all of the components are SMDs.
Now as to your question, I have seen on these sets the majority of the time it is a driver transistor that goes bad.
I hope this helps,
Thank you,
Shuttle83
www.electron-age-technologies-llc.com
Posted on Nov 28, 2008
  • 58 Answers
SOURCE: "Upgrade" of Backlight Panel
just replace what failed.
I replace the surface mount FETs on the inverters.
Posted on Dec 06, 2008
SOURCE: part number for the samsung le52m87bd backlight inverter
Hey!
I also have a SAMSUNG LE52M87 LCD TV and I have the same
ANOYING BUZZ comming from ( I think ) backlight converter. - I am
almost 100% that its because of the backlight inverter while the sound shifts frequency when backlight is changed ( from 1 - 10 ), but the volume of the buzz stays the same. Only the tone changes. I have this TV for a year now and havent realy noticed until now, so I think it started buzzing recently, because I didnt hear it before ( and I got realy sensitive hearing :) ) ...
ITS DRIVING ME CRAZY ...
PLEASE post what happened when ( if ) you changed the inverter,
or what did you do to solve the problem ...
Many thanks in advance!
Eddie from Slovenia
my email: Ldesign.marketing@gmail.com
Posted on Jan 08, 2010
  • 1684 Answers
SOURCE: I have the same power supply problem on my
You may be able to repair the board instead of buying a replacement board. If you are up to a little soldering it may save you a good bit of money for the repair. If you are interested just take a few pictures of the boards and email them to us at tech@ccl-la.com We will check them out and give you some pointers on what to do. Most power supply issues with the blinking power lights are caused by blow capacitors on the power board. These are fairly easy to replace and the replacements are less than $20 usually. To get an idea what capacitors are and what will need to be do to repair you unit check out our pages at :http://www.ccl-la.com/blog/index.php/capacitors/ You may want to look over the repair guides for other units we have posted too. If you need parts we can also supply them for you. If you have any additional questions just contact us at: tech@ccl-la.com
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Posted on Apr 19, 2010
How do you fix a Samsung 55" Television with no picture but good sound?
The symptoms you described would indicate the backlights are not working.
The 2 main reasons are the backlight inverter board has gone or the backlights have blown!
Since you have replaced the inverter board with a new working one then this would point towards the LED backlights.
Apr 02, 2016 | Samsung Televison & Video
My Samsung un32eh5300fxza has no backlight it has sound and pic but no backlight
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Jun 19, 2015 | Samsung Televison & Video
Backlights not coming on in samsung led tv
Back - light problem? Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should troubles shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Apr 13, 2015 | Samsung Televison & Video
I have a Samsung LN40A450C1D TV that has sound but the backlight doesn't come on. I replaced the power supply board and same problem. I then replaced the backlight inverter. Same problem! I'm absolutely...
You have to check all the voltages, that comes from its main power supply board, to its back light inverter board. These is one pin at the backlight inverter board; comes from the main board; which controls the back-light inverter to start and off. This voltage is generated at the main board, and send to the back-light inverter board, as control voltage. It will be best to contact any service technician. If you wish to get some details; check the site linked here.Viewing it in "Mosaic" will make surf easy.
Feb 24, 2014 | Samsung LN40A450 LCD TV
Samsung le32r87
Check the backlight inverter board. It is faulty. There is no repair to these boards, if the inverter transformer on it is damaged. Card base replacement only can be done. To get more details, http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Samsung LE Televison & Video
I have a samsung ln-t4053h that had a bad caps. I replaced the caps and the tv turned on fine and i put a flashlight to the screen and the screen turns on but the backlight is on 10 and it looks like its...
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 23, 2017 | Samsung LN-T4053H 40 in. LCD Television
Samsung ln32a550p3f turns on and has sound but no picture
Ur LCD inverter backlight board is dead.Tries these Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.Will get ur picture after this board is change.The is board is a long board in shape.
Mar 20, 2010 | Samsung LN32A330 32 in. LCD TV
Our 22 in Samsung Series 3, 350 only has sound, no picture. Is this a simple problem to fix?
Yes,Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries these Websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.The board is long in shape.
Mar 17, 2010 | Samsung LN40A550 LCD TV
LN-T4061F turns on black screen sound is there and no menu appears
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Feb 27, 2010 | Samsung LN-T4061F 40 in. LCD HDTV
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
Electro Med Services...
