Question about KitchenAid KGRA806PSS Gas Kitchen Range
Triple burner on gas stove will not ignite.
I have a Kitchenaid gas range model no. KGRA806PSS.
The other burners ignite and the ignition spark works well. The problem occurs only with the triple tier burner. It malfunctions every so often. Sometimes it lights fine, sometimes it will only light if another burner is lit as well, sometimes the problem just goes away after trying and scrubbing the burner base and the cap.
The thing is that the burner base and cap never seem to have anything on them so I don't see how scrubbing it helped. I wonder if the gas tube has something in it? It also seems that not enough gas is coming to the burner as sometimes it will only light if another burner is already lit.
Another issue is that the large burner base seems a bit loose. Would that interfere with the gas coming the burner? It hardly seems possible since the gas comes in a tube.
Do we have to remove the base and drill out the holes or buy a new one? What do you suggest?
SOURCE: kitchenaid gas stove left back burner won't light. hear clicking
I have a Kitchen Aid gas stove. All the burners will not light. No clicking, NOTHING. Is there a lighting switch or something that needs to be replaced ?? Or do I replace all 4 lighters ??
Posted on Jun 26, 2009
SOURCE: Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Posted on Sep 05, 2009
  • 57 Answers
SOURCE: Gas Range, trouble igniting
It is likely that the ignitor needs to be replaced. If the range does not sense the correct amount of resitance in the ignitor it turns the gas valve off. When the ignitor is starting to fail the problem is intermittent, so the range turns on and off as you have described.
Posted on Sep 22, 2009
iwillfixforu
  • 619 Answers
SOURCE: My KitchenAid KGRA806PSS Stove's Burners won't
Bad power source. Not getting 240 volts to oven. reset breaker by turng off the back on for the stove. 240 volt double breaker. If this doesn't work problem will be where stove plugs in.
Posted on Feb 02, 2010
heatman101
  • 43501 Answers
SOURCE: Oven burner won't ignite
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Posted on Apr 21, 2010
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
Random spark from igniter
it sounds like the wire that goes to the stove igniter is shorting out when you are using the oven.
Jun 09, 2014 | KitchenAid KGST307 Gas Kitchen Range
I have a kitchenaid gas stove 30"wide model# KGRA806PSS01 and the problem its having is that the bake and broil igniters will not spark to light the gas the top burners are working just fine and I...
Unfortunitly i myself a tech of 30 years has no idea what the code 0164 means and have only ever see error codes with E/F so on that sorry no help. HOWEVER having replaced the spark module and EOC i would suspect the only thing else that could be causing the oven/broiler to not ignite is the electrodes(igniters) and would go ahead and replace those as well.
GENE
Sep 23, 2011 | KitchenAid KGRA806PSS Gas Kitchen Range
I havef a KitchenAid Gas Range Model KGSS907... and one of the ignitors on one of the burners is not sparking. I tried to take the stove top off to check the wire to the ignitor but don't see how to...
Typically the burner come off by removing the burner caps and inside the burners are 2 screws that hold the burner base to the top..yes you could swap igniters on all burners they will be the same. If by swapping the igniters it still doesnt work the things that could be the problem are;
the spark module espically if the igniter that doesnt work on that burner suddendly work on a different burner
the spark switch on the gas valve for that burner..typically all burners spark when one it turned on but the only one that lights is one that has gas flow to it..so turning on a different burner first and leave it set to light setting by turning on the one that doesnt light it will light if that spark switch is the problem
of course a cracked igniter
a broken wire from the spark module to that igniter taht doesnt work..its not that uncommon that the insulation will sometimes wear off a wire off so the electric that should be going from the spark module to the igniter is instead being grounded by that wire touching the metal on the frame uninsulated
Good luck,i hope i have been able to help you fix your range,
GENE
Aug 27, 2011 | KitchenAid KGSS907SSS Gas Kitchen Range
KitchenAid gas stove main burner igniter does not work when the control knob is turned to the ignite position; however when any one of the other burners control knob is turned to the ignite position, the...
Hi Cecchung,
I think I know it.
Modern cookers have semi automatic ignition. Behind every knob there is a hidden switch and the switches are wired in "parallel". That means, when one button is put in "sparkstand", all plugs will spark. At least it should be.
In the youtube movie you can see how these switches are in a string.
So I suppose that the switch behind the button for the main burner does not work.
Fortunately, you still can lit that burne r with the other buttons.
Look at the movie, may be you can fix it yourself.
Kind regards, Dik
Maytag Gas Stove Burner Won Light Spark Ignition Switch
Feb 04, 2018 | KitchenAid KGST307 Gas Kitchen Range
heatman101
Apr 19, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
My whirlpool gas cooktop on sparks on left front burner. Model scs3014gq1
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 01, 2010 | Whirlpool SCS3014 Gas Cooktop
My KitchenAid KGRA806PSS Stove's Burners won't light. And the stove gets up to 200 degrees but no further.
Feb 01, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid gas stove left back burner won't light. hear clicking
I have one of the kitchenaide gas ranges and if the burner cap is not set on PERFECTLY straight, the gas doesn't flow properly and will not ignite. Try lifting and replacing the cap back down on the burner and see if this solves it.
Mar 05, 2009 | KitchenAid Kitchen Ranges
KitchenAid KGRA806PSS Gas Kitchen Range Logo
128 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
