Question about Dacor Ovens
Any one have a dacor convection wall oven #W305B manual out there?
I just purchased a house with a Dacor W305B Convection Wall Oven that is pretty old serial number 876246. Of course there is no manual and I cannot get it to do the self clean function...the oven does not come on and get hot. It's going to take me a while to figure how too cook in this oven, does anyone have a users manual for this oven online?
SOURCE: dacor cps130 wall oven f1 error
According to the manual, this is an element relay circuit failure. Call the tech.
Posted on Jun 15, 2008
  • 29 Answers
SOURCE: Dacor ECS230 Epicure Electric Double Oven
You probably tripped a safety thermostat in the back of each oven. If you turn off the breaker and find a way to pull the units out you could probably remove the rear panel and reset the thermostat by pushing in a button on the back of the open thermo. Some thermo's aren't resettable though so you'd have to buy a replacement.
Posted on Sep 22, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
localwonder
  • 6784 Answers
SOURCE: f9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Posted on Jul 30, 2009
  • 523 Answers
SOURCE: ECS227 Epicure Electric Double Oven: I have a Dacor model # CPD227R double convection o...
replace touch pad
Posted on May 06, 2010
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
How to turn fan to oven
First of all, here is the main DACOR ONLINE SUPPORT page for your model:
http://www.dacor.com/Our-Products/Wall-Ovens-Single/Distinctive-Single-Wall-Oven.aspx
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.dacor.com/WorkArea/showcontent.aspx?id=18137
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 10 of the manual for detailed instructions on how to use the various cooking modes of your oven including the convection fan feature.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
Jun 13, 2011 | Dacor DO130S Oven
What size is the bottom element in a dacor model w305wc wall convection oven
I'm sure what you are asking. If you need an element, you can order it by your model number, which you have provided. We supply parts and you are welcome to call us at 9728590929 and we will be happy to assist you with your parts orders. We hope this helps!
Aug 14, 2009 | Dacor Epicure 30" Double Wall Oven,...
Control panel fan won't turn off
Is the oven still hot?? this is a Electronics cooling fan it will run even after the oven is turned off give it some time it should shut off let me know if not
Jan 26, 2008 | Dacor Epicure 30" Double Wall Oven,...
My Dacor wont heat, broil or convection after self cleaning. No heat but everything else works The bake, broil, and convection elements on my Dacor CPS130 electric wall oven will not heat.  The oven has...
like another person stated-from the front behind the door, take off the 6 screws and the cover by the latch. there is an "oven hi temp limit switch" It is crome with 2 heavy black wires connected to it. On the back side of this is a small red button which will reset the limit switch. I had the same issue (everything worked except the any of the heating elements) and quickly resolved.
Jan 07, 2008 | Ovens
Dacor cps130 wall oven f1 error
Dec 04, 2007 | Ovens
Dacor Oven - convection fan stays on while on "bake" setting
Question: does the unit appear to hold the correct temperature? Most convection units only turn the heating elements on and off...not the fan. If the unit is reporting operating temp and then taking other direction...and it is cooking right...you're done.
Nov 14, 2007 | Dacor ECS127 Epicure Stainless Steel...
Ovens Logo
94 people viewed this question
Top Dacor Ovens Experts
Dan Webster
Dan Webster
ashburton
Jaime Hernandez
Are you a Dacor Oven Expert? Answer questions, earn points and help others
