Unpluging circuit board on mitsubishi ws-65411
frcs68
  • 1605 Answers
SOURCE: Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Posted on Oct 14, 2008
Slinteriors
  • 8617 Answers
SOURCE: Mitsubishi Model # WS 65311 HD 1080 turns on then shuts off.
try holding in the menu and input/device buttons on the front of the set both together and see if it blinks a series of blinks, pause briefly then blinks a second series of blinks, let me know what the blinks were sush as 22 or 24
Posted on Mar 13, 2009
tlm931
  • 273 Answers
SOURCE: Mitsubishi WS-55413 timer light flashing. tv will not power on
you have some caps that have failed in the dm module
that will have to be replaced to correct the problem
if your know how to change them and have the tools the caps can be obtained through most electroinc parts suppliers
there 1000mfd 16v we increase working voltage to 35WV
if you can change them let me know and i can give you locations on the board and the dm stands on the right side of chassis at rear
Posted on Oct 24, 2009
SD Tech
  • 14553 Answers
SOURCE: I have a Mitsubishi WS-65411 purchased on 08/2003.
Two things---first if the chips were replaced recently you may have a new one bad.
Second: do the self check that this set has:
when it shuts off and the power light goes off: On the front of the set press and hold BOTH the MENU AND INPUT (or DEVICE) BUTTONS AT THE SAME TIME AND HOLD THEM FOR AT LEAST 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
The power light will blink a 2 digit error code:
The most common is 2 blinks, a pause and 2 blinks.
Let me know what you find and I will tell you what it means.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH.
Posted on Nov 18, 2009
  • 668 Answers
SOURCE: I HAVE A MITSUBISHI 65 INCH MODEL WS-65411 AND HAS A CODE 23
This error code shows that you have a Horizontal failure occurring. It could be a intermittent solder connection on one or more of the yoke connectors. That is the most common issue with shut down due to Loss of Horizontal Deflection. If you are handy with a soldering Iron and confident in general TV knowledge, you can repair this. If not , do not attempted it. Call a Professional. If confident, unplug the set from power, remove the speaker Grills from the front. Then remove the Center Piece of the front panel. You should have access to the front plate. Remove the 6 screws holding in on and place it aside. If you look at the neck of the left CRT', you will see a 4 pin Plug Connector that goes from the High Voltage Board up to the Yoke . You will need to use a flash light and check the solder connection under that yoke plug. Most of the time it will look like it has been arching. Resolder each of the pins. then move to the center CRT and do the same. After that, repeat it again on the CRT to the right. Make sure that each of the pins you solder are not shorted or have Solder Splashes between the pins. Plug in the set and turn on. Hopefully you will not have the problem again. Reinstall the Front Panel Access plate, Center Piece and Speaker Grills.
Hope it does the job,
Sky Assoc
Posted on Apr 21, 2010
What is the wattage for the WS-65411?
POWER
AC 120V 60Hz
240W
Only WS73411 takes 275W otherwise, all other model with this series like
WS48311
WS55311
WS65311
WS55411
WS65411
WS73411 take 240W as yours.
Hope you are talking about main wattage. Audio wattage is exceptional.
best of luck
Jan 27, 2010 | Mitsubishi WS-65411 65" Rear Projection...
Neeed a new plug /cord for my WS-65411
The Part Number for the AC Cord is 246C351030.
Mitsubishi Parts Department 1800-553-7278
Good Luck,
Skyassoc
Nov 29, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Replacement bulbs
Probably through Mitsubishi only.
Are you sure you want to pay the cost of the CRT'S?
These are the Part Numbers for each of them.
RED CRT --------251C217040
GREEN CRT----251C217050
BLUE CRT-------251C217060
Mitsubishi's Parts Deparment 1800-553-7278
Nov 16, 2009 | Mitsubishi WS-65411 65" Rear Projection...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
