Question about Garden
Craftsman dlt 3000 cannot engage the blades to spin
GM Elec
  • 1000 Answers
SOURCE: Craftsman riding lawn mower...engine dies when blade is engaged
Push the clutch all the way down and try to start, does it crank over?
Let me know.
Regards,
Posted on May 10, 2009
wadembly
  • 489 Answers
SOURCE: 42 inch Craftsman blades won't engage
is the belt spinning & smoking when blades are engaged or the belt won't spin if the belt spins but blades wont go then there is something stuck under the deck or the bearings are gone out do to not being greased
Posted on Jun 14, 2009
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
wadembly
  • 489 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
SeaDaddy46
SOURCE: Craftsman GT5000: Dies when switch is pulled to engage blades
I have the same tractor. If you have the transmission in <reverse> this will happen every time. It's a safety feature. Be sure the tractor is in <neutral> or one of the 6 forward gears.
Jim Romines
Posted on Jul 31, 2009
My Craftsman DLT 3000 Riding Lawnmower will not go into gear.Could something have come loose? a spring orwire to the mower?
At the rear of the mower at the very back is a transmission disingauge lever, it may be set, this lever is so u can easily push the mower when it is not running...!
Oct 26, 2014 | Garden
How to fix my craftsman riding mower, whcih dies after engaging blade
make sure blades not jammed. with mower off, try turning blades by hand.
it could either be a safety switch in the seat or for the reverse paddle.
make sure its not in reverse when you attempt to engage blades.
you should be able to bypass both switches with a jumper wire for testing purposes. if it works with jumper, replace the switch(s).
Sep 01, 2014 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Blade not cutting. How can I adjust? Craftsman model 358.796480
When the blades are engaged do they turn? It could be a belt is loose tha causes the blades not to spin. Check the handle that engages the mower deck to see if it goes into the proper slot which would cause the blades to spin.
May 18, 2014 | Garden
My YTS 3000 will run but the blades won't engage. Engagement lever is really hard to push up but when I try to engage blades, nothing. Could it be the cable?
Find where the cable is connected to the deck. Have someone move the lever and watch the end. Does it look rusted or bent?
Unclip the cable at the deck. Then try the cable. If it moves freely there is something rusted, bent or broke on the engage pulley mechanism on the top of the deck.
Nov 02, 2013 | Craftsman YT 3000 42" Kohler 22 hp Gas...
Craftsman DLT 3000
Maybe the wire to the seat switch came off or broke, or the switch came loose from vibration. Have you checked?
Apr 22, 2017 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Tractor won't go forward or reverse
Check the drive belt. It has probably broken or has come loose.
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
model 917258862 mower was given to me. sat outside numerous years. I've managed to get it to start run and drive, but cant get blades to engage. don't know what the wires are for or do that go to some sort of pulley attached to the bottom of motor. can somebody help me pls ?
Jun 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
426 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
