Question about Kyocera KM-1510 Copier
I have a machine error
When i turn the copier on it come on but when i hit the start button it shows a a400 error how can i fix this. kyocera 1810 laser copier
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 126 Answers
Does your machine have a ADF ( document feeder) on it? IF it does check the connection between the ADF and the machine. Also check the connection between the scanner PWB and the DF drive PWB. These are the 2 boards that let the machine communicate with the ADF. If your machine does not have an ADF, check to make sure that the side covers are closed securely.
Posted on Jan 05, 2009
How do I fix error code C-6 with a KM 2020 copy machine
It is resettable to enter simulation so .....
Press and let down "Clear / Stop", "Start" button on the left to darken or clear, then "Stop / Clear" "U163", "Start" appears "CLE" and there you hit "Start" other time and now.
Feb 22, 2015 | Kyocera Office Equipment & Supplies
KYOCERA 6030 ERROR CODE C0220
Try reset this code by entering on the panel: 1087 1087this will take you to service modehit 906 then hit Start keythen on the screen highlight execute and hit start key.
the machine is going to reboot and this will take care of your problem.This is a board error but can be fixed by updating the machine firmware.
Dec 17, 2011 | Kyocera Office Equipment & Supplies
Kyocera 1810 A400 error. What is wrong and how do I fix it?
This error refers to a bad laser unit. The laser is what "etches" your image onto the drum as it transfers to the paper.
This is the cheapest replacement unit I have found for you.
Here
Aug 23, 2011 | Kyocera KM-1510 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
I need to know what error code A400 means?
a400 is a trouble code for Laser Scanning Unit problem.
Jun 24, 2009 | Kyocera KM-1510 Copier
I have a kyocera 1810 copier. it has a error a 400
Does this machine have an ADF ( document feeder) on it? If so, check the connect cable from the document feeder to the machine. Also check the connectors from the scanner PWB to the document driver PWB. ( these are the 2 boards that do the communicating , the machine and the document feeder). If this machine does not have a ADF the check the side covers/ doors and make sure that they are closed securely.
Jan 05, 2009 | Kyocera KM-1510 Copier
Kyocera model km-1810 laser copier error code a400
dependds on what the problem is and $ of repair ??????????????
Oct 06, 2008 | Kyocera KM-1510 Copier
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Kyocera KM4035 Service Message C6050
the above is incorrect, Kyocera made a mistake by having a thermistor that physically touches the upper heat roller/belt.. it has worn the roller to a point where it throws up the error.. you will have to install a new fixing unit.
I have done over 25 warranty replacements regarding the 4050/5050/2525 etc.
Sep 14, 2007 | Office Equipment & Supplies
Kyocera KM-1510 Copier Logo
160 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
