Question about Whirlpool GEW9250 Electric Dryer
My dryer sparks when i push the start button.
Now one of the wires are burnt and i am scared to use it. please help!
  • Default KITT
    Default KITT May 11, 2010
    Disconnect the dryer, as well, maybe try to replace the wire.
  • 706 Answers
Hello www_jaymepri,
The fact that you can see one of the wires is burnt suggests ( that it is a wire on the power cord). If that is not true, please elaborate on exactly which wire you saw that was burnt. I am assuming it is the power cord and will walk you thru changing it. First off, you need to unplug that cord from teh power receptacle. If there is any question regarding the insulation on the dryer power cord, I would encourage you to remve or disable power to the receptacle in your circuit breaker box. Once power has been disabled, unplug the dryer cord from the receptacle. Make note of the plug end and determine it is a 3 prong or 4 prong configuration. If unsure, cut that cord off the dryer and bring it with you when you get a replacement. Most home good departement stores liek Home Depot or Lowes sell replacement power cords for this very purpose. Once you get a replacement cord, slide the dryer away from the wall so that you have ample rooom to get to the back of it.
Note where the existing ( original ) cord penetrates thru the back of the dryer cabinet ( normally thru a pass thru with a cable clamp). Loosen the cable clamp screws to free the cord up and also remove the access cover near it so that you can see where it is wired in. With the cover removed, you should see a terminal block where the power cord lugs are connected. Make note of the colors associated with these connections. They are normally red, white, black and/or green. The red and black lines are the actual supply line ( power) and are commonly terminated on either side of the neutral line ( normally a white line). The green wire is normally the ground connection and is tied to the dryer frame someplace. The ground wire termination varies from mfr to mfr and model to model but the end result is that it is bonded to the frame of the dryer. So, when installing the replacement cord, pass it thru the cable clamp and over to the terminal block. Then install one wire at a time and based on the colored ends to match what you presently have. Make sure you tighten the screws that hold the wire lugs snuggly .. Loose connections here, have been known to cause resistive junctions and get hot enough to cause fires so make sure these screws are tight. Then, tighten the cable clamp so that it locks the cord in place and doesn't slide freely inside that clamp.
When all wires have been installed, plug in the cord to the receptacle and switch on the circuit breaker. Before positioning the dryer back against the wall, try running it for a minute or two without any clothes in it to make sure it operates correctly ( heats up and the drum rotates) The exhaust from electric dryers ( albeit, not healthy) can be vented into a room for a minute or two while you test things. Gas dryers should not be allowed to vent into a room. Hopefully this will resolve your problem. Feel free to send me a follow up notice if you are experiencing another problem not associated with the cord.
Posted on Jan 06, 2009
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
Why will my Maytag Dryer Model# LDE8624ACE not start?
check the switch. Wire may be out of its post or burnt.
Oct 07, 2009 | Dryers
My dryer won't start, but I think the cycle button won't engage.
Thanks for using FixYa. The issue might have happened due to a blown fuse or burnt wiring/components on the control board. You'll need to check and replace the fuse and replace it.
Blows fuses or trips circuit breaker —ELECTRIC Models:
• The amperage readings are at 240 volts. One line will be 24 amps and the other line will be 21 amps. The neutral line will be at 3 amps. If the above amperages are not present, then the house wiring, fuse box or circuit breaker should be suspect.
• Shorted heating element to housing.
• Incorrect wiring or a wire shorting to ground.
• Drive motor winding shorting to ground.
Please do rate the solution & revert for further assistance.
Sep 20, 2009 | Whirlpool LER4634J Electric Dryer
Dryer shuts off after releasing "push to start"
this problem sounds like it can only be 1 of 2 problems. the start button or the motor is not going into run winding. i found over the years that the blue wire i believe is burnt at the motor. this can be repaired quite easily .cut the wire and strip it putting a new connector on. if you need to you can buy an assortment at a hardware store. if every thing is good check the start button for burnt wire if ok then you most likely have a bad motor. i'm pretty sure though that a wire is burnt off at the motor
Jan 30, 2009 | Kenmore 67082 Electric Dryer
It sounds like the motor has burned up or is burning up is why you are getting that smell. There could at the same time be a wire that has come loose or burned off that is causing it not to come on.
Jan 26, 2009 | Kenmore 73952 Gas Dryer
I have a Maytag Neptune MDE4000AYW electric dryer. It has been trouble free until now. The problem: When I pushed the start button, it started slow several times. I stopped using ut for 4 hours. Now,...
its a motor problem check to see if theres a capacitor that starts the motor it may be burnt out it will have 16uf etc on it or the motor itself could be faulty if its covered in lint they over heat.hope this helps.
Mar 07, 2008 | Dryers
Whirlpool GEW9250 Electric Dryer Logo
1,583 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
