Question about Mitsubishi VS-60719 60" Rear Projection Television
Mitsub large screen vs6071 has no picture but has sound
Mitsu has sound but no picture
  • angie1470 Jan 10, 2009
    I get sound but no picture. If I push the Menu button I can see the words but no picture for cable or Video
Bulb needs replacing
Posted on Jan 05, 2009
1998 73" Mitsu diamond the RBG/HV Im trying to
I'm not sure that the set can handle the speed, but make sure that the sync pulse is on the green when you make the connection. Also, you must use the component input not the composite. IF hte picture ends up being purple, you will need ot change the set from YPrPb to RBG as well.
Good luck,
Dan
Apr 05, 2011 | Mitsubishi WS-65809 65" Rear Projection...
Manual Tranny fill port
access should be from underneath. it should be a fairly large sized bolt on either side of the trans. quite possibly marked.
May 14, 2010 | 2002 Mitsubishi Lancer
Older rear projection 63 inch Mitsub. A brown block
Ur convergence is dead.Must replaced 2 Convergencce ICS,and some or all it resistors.Can u solders?Buy a convergence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Feb 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I HAVE A MITSU VS50707 PROJECTION. THE PICTURE BOWES TO THE CENTER OF THE SCREEN AND PICTURE HAS THREE DIFFERENT COLOR HALLOWS. IS THIS A REPAIR THAT CAN BE DONE AT HOME? WHERE CAN I PURCHASE THE PARTS?
This is not a diy repair, unless you have a service manual, can follow a schematic or have circuit repair skills. The main cause is bad convergence ICs (large black ICs mounted to large heatsinks). The ICs go bad and usually take out micro fuses/fusible resistors when they short out. Another problem is they can take out the voltage regulators that feed the ICs. If you don't know where the fuses or the regulators are ( or how to test them) you can cause more damage then good, and turn a inexpensive repair into a very expensive one.
Aug 30, 2009 | Mitsubishi VS-50707 50" Rear Projection...
Mitsu vs-5042 Works then picture goes out. Thumping works sometim
If you occasionally have a picture then you stand a good chance of repairing this tv. There are bad grounds on the deflection board. Start with the board that has the flyback. I do not know the year of your tv. Sometimes the same model may have an option improvement than one couple of months earlier. The first suspected problem would be the vertical IC. In some cases this ic is located on the convergence board and in others the flyback board. It has seven pins and is the TDA version. Located on a large heatsink. Resolder this and any other grounds on both board. Some will tell you the P I P board is bad. This is a free standing board that can be removed and replaced. But please do the earlier option first.
Jun 28, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Flickering screen with semi-circular middle whitish flicker and static sound
Use your warranty, as most warranties are vioded if you open the set up.
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsu Problem Resolved??
After about a week I got it to turn on but still no picture just a white beam about 2/4 down on the screen and still has sound
Apr 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Same problem - loss of picture with green bars flickering
We contacted Mitsu today in Irvine. Sounds to us like they're aware of a widespread problem with this model. Told us to get a Mitsu Tech to diagnose and fax to them the outcome and someone would contact us back within two days. Seems like so many are having the same problem and all about 2.5 to 3 yrs. old. I paid $3,500.00 for mine. I'm not going down without a fight with Mitsubishi. Thought they were #1 in the Big Screen world. CLASS ACTION LAWSUIT OR RECALL BY Mitsu should be in order....They know there is a problem with the power supply module.
Jan 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Mitsubishi VS-60719 60" Rear Projection Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
