Question about Microsoft Windows Vista Ultimate Edition
USB PORTS NOT WORKING
I used have XP before I upgraded to Vista. It was all fine for about 2 months until one day i wen to my computer and inserted my usb. The usb light flashes for a sec then it gone. Like there is no power. My computer doesn't detect a single thing. Nothing about anything malfunctioning or anything. I right clicked on My Computer and went to "manage". I Selected the Device Manager option and at the bottom of the list on the right I found Universal Serial Bus Controllers. I Checked to see if the port is listed and if it has an error. There was no yellow question mark or exclamation point. There is nothing like that my computer see's that everything is working and updated.Even my front panel usb's aren't working. There doing the same thing as the back ones, which are intergrated to the motherboard. I thought that the back and front usb's didn't have anything to do which each other besides connecting to the motherboards chipset. Well, I had 2 of the same motherboards. I was using one of them in my computer and the usb ports were working fine. I accidentally fried that motherboard and had to switch to using my other motherboard in the same computer but the on that was fried had that usb problem. So im guessing something on my mother is fried or something. Really CONFUSED. Not sure what to do............
Asus motherboard A8n vm csm
700 watt power supply
Go to Regedit and type the following HKEY_LOCAL_MACHINESYSTEMCurrentControlSetServicesUSBSTORstart
change the value data from 3 to 2
Regards,
Meraj
meraj2k@hotmail.com
Posted on Jan 05, 2009
G'Day! I have a Transcend 2 GB USB stick. Whenever I connect it to my computer or any other computer, I get this error message ''THIS USB DEVICE CAN PERFORM FASTER IF YOU CONNNECT IT TO HIGH SPEED USB 2.0...
Yes. The problem is you don't have usb 2.0 ports on your motherboard. Its the second generation usb port. So if you want to upgrade you can buy additional hardware to upgrade this. But your motherboard has to be compatible with that additional peripheral too. As an example buses of your motherboard. So you have to check that also when you purchase. This is not a problem. The only thing is it will reduce the efficiency of your pen drive (Access time etc.). Other usb sticks you have may be usb 1.1 devices.
If this is helpful to you, please rate this .
Thanks.
Jun 15, 2009 | Computers & Internet
USB PROBLEM- NEED ATTENTION NOW
Here is another option: you can see if your computer has even recognized the device by going into the computer management again, accept this time check the "disk management" instead of device manager. You should see your hard drive listed and hopefully your flash drive is there as well. If it is try right clicking on the drive and select "change drive letter..."select something like "x" and see if that helps it to appear.
I know you may not want to hear this, but If this doesn't work you may need to resort to adding a PCI card with some new ports on it.
Jan 06, 2009 | Microsoft Windows Vista Ultimate Edition
SEROUSLIY NEED HELP USB PORTS NOT WORKING
restart the computer try that then get back to me
Jan 05, 2009 | Microsoft Windows Vista Ultimate Edition
All Usb ports not Working
First you need to see if your computer recognizes the USB ports on the computer. Right click on My Computer and go to "manage". Select the Device Manager option and at the bottom of the list on the right you should find Universal Serial Bus Controllers. Check to see if your port is listed and if it has an error. You'll be able to tell by a yellow question mark or exclamation point. Once you know that you can finish solving the problem
Jan 03, 2009 | Microsoft Windows Vista Ultimate Edition
Was having problems with my vx922 lcd display.
Sounds like my problem that I fixed by sending back for repair.
I read that these VX922 monitors are affected by dodgy capacitors on the power board.
I had the monitor for over 2 years. Viewsonic picked it up, yep u guessed it... changed 2 caps on the powerboard sent it back all within 2 days, under warranty. I got my awesome monitor back. Its all good!
Dec 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Vista Write Protected USB
have your computer reset and reinstall the operating system.. the software is corrupted
Mar 07, 2017 | Electronics - Others
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
"USB Device Not Recognized" - any usb device
Hardware to old or a spontaneous defect ? Burn a free linux live dvd ( mint or other live distro) to recognize a good working device.
Boot on cdrom and see what happens.
DistroWatch com Put the fun back into computing Use Linux BSD
Mar 08, 2017 | Electronics - Others
Ext WD500GB drive not being recognised by my computer,but seen in device manager
try downloading this and and scan may be it might locate yr drive since windows can still see it in device manager. and with these u can recover even deleted and formated files. try it
http://services.seagate.com its trial version so u can get a full version n pay little or find similar software but i know yr drive can still work fine its just that we r missing something here.
thank u
May 27, 2008 | Computers & Internet
Freeagent tools is not working
It is all about pressing the eSata cable into the back of the external HDD hard. I have been working on this all day and I finally figured out this was the problem. Let me know if you need more help!
Sep 02, 2007 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Microsoft Windows Vista Ultimate Edition Logo
584 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
