Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
P52810lv Rca tv won't turn on and makes clicking sound.
  • 50 Answers
SOURCE: volume distortion only on tv setting
RCA HAD A CERTAIN MODEL SERIES THAT HAD A REALLY BAD DESIGN,,IT SEEMS THAT SOLDER CONNECTIONS STARTED BREAKING LOOSE AND DEPENDING WHERE THEY CAME LOOSE,,YOU WOULD HAVE PROBLEMS IN THAT CERTAIN CIRCUIT..TO DETERMINE IF YOU HAS THAT SERIES,,WE WOULD NEED THE CHASSIS # ON THE BACK...
IF THE CONNECTIONS CAME LOOSE IN THE VERTICAL CIRCUIT--THE PICTURE WOULD CLOSE UP ,,IF IN THE TUNER SECTION--YOU WOULD LOOSE CHANNELS ,,IF IT WAS IN THE AUDIO SECTION--YOU WOULD GET CRACKLYN SOUND OR NO SOUND
ONE THING YOU CAN TRY--PUT IT BACK IN THE TV MODE,,GENTLY TAP ON THE CABLE CONNECTOR IN THE BACK OF THE SET AND SEE IF IT CLEARS UP,,IF SO YOU HAVE THE CONNECTION ISSUE--WILL NEED A TECH..GOOD LUCK ..TUNICA
Posted on Nov 01, 2008
freetek
  • 5568 Answers
SOURCE: Dead RCA TV model # P60752EB. My TV would make a
The PS suggestion is likely on the money. You have a couple of choices- - Buy a new board from RCA - Buy a used or repaired board; one source is: Jimmy's Parts (~40-60% of new) Finally, the failure is often only electrolytic capacitors that were bought from the lowest bidder. There are probably 1-2 dozen parts which will cost (if buying according to my guidance) under $20 US. There will be a couple of larger parts rated at ~ 200 VDC and 200-400 uFd and these seldom fail since they see only low frequencies. If those have bulging tops or some deposits surrounding them, they too have failed. Many of the rest of the capacitors are exposed to high frequencies which chemical (electrolytic) capacitors really hate and must be far better constructed than the previously mentioned two larger ones.
If you choose to DIY, you will need a better soldering iron or risk damaging the board. You can buy these direct from China or locally and add 20-50% to the prices at the site below;
DealExtreme (irons/stations)
I wouldn't buy the cheapest; your board may not be irreplaceable but don't waste your time and money.
You will also need something to remove the solder from the parts' leads or again, risk damaging the board. There is solder 'wick' which works well with some practice, and solder vacuums here:
DealExtreme (solder removal)
If you have never done any board repair, dig out that ? that you just couldn't throw away although it is sick or you haven't used it for three years, disassemble it and practice on those parts and boards.
I suggest instead of spending a couple hundred dollars on a capacitance meter with other functions you don't understand, you just might 'shotgun' the board and replace all except those mentioned two.
I recommend Mouser.com and have used them for business and private stuff for several decades. Their prices are fair, shipping at cost, no handling charges.
When looking for your parts, you will find a selection of different prices and don't pick the lowest; look for:
- Low ESR - For switched mode service (or 'higher frequencies')
The parts that have likely failed WEREN'T rated that way and have died because of it. A new supply from RCA will have the same garbage parts as the sick one and will fail in ~ the same number of hours.
There are ways to prevent even cheap parts from failing but still add to cost so I am the only one on earth who does this unless the device is 'hi-rel' and cost 50 times what it should since the taxpayer is stuck with the extra cost.
Posted on May 13, 2011
hardrocko
  • 1476 Answers
SOURCE: RCA 52" rear projection tv
rscimeca,
This could literally be anything. I have a tip at http://www.fixya.com/support/r6396176-projection_tv_troubleshooting which will help you isolate the problem and tells you where to get the parts.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on May 23, 2011
Slinteriors
  • 8617 Answers
SOURCE: Hi my rca p52937 won't turn on and is making a
The ticking sound is almost always caused by the Flyback and Hot transistor. It could be other items also located on the deflection board but flyback is most likliest. You can get a replacement flyback and Hot tarnsistor from www.tvrepairworld.com
Posted on Jul 07, 2011
Slinteriors
  • 8617 Answers
SOURCE: My RCA D52W20 won't power
Thats usually caused by a failed Flyback and HOT transistor.
Posted on Jul 24, 2011
My RCA tv died. It will not turn on.
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1100 posts to different brand TVs now. Pull up older posts there.
Nov 10, 2012 | RCA P52810LV TV
RCA P52810lv will not power on
Completely dead with nothing suggests maybe a blown or open fuse--first step would be to unplug and look for a fuse--follow the power cord.
Jun 11, 2012 | RCA Televison & Video
RCA P52810LV wont turn on
If the set is dead, what to do with a reset? The power supply section circuit should be troubleshooted. Contact any experienced service technician.
Jun 11, 2012 | RCA P52810LV TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
I have a RCA 32" Flat Screen TV that shut off and
The sound was came from the clicking of the relay. This kind of symptoms is an indication of out-of-regulation condition on the power supply section. This is caused by faulty electrolytic capacitor. It will dropped the supply voltage and will trigger that kind of symptoms.
Faulty electrolytic capacitor mostly has a physical indication of fault like bulged/dome at the top and can be easily identified. See sample picture of faulty electrolytic capacitor below.
capacitor with bulged/dome at the top.
Check these parts on the power supply section. Once found, replaced it with same capacitance and working voltage which is printed on its body itself. Click this LINK for more info regarding electrolytic capacitor.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified TV Technician to isolate the faulty parts.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Aug 05, 2011 | RCA L32HD31 32 in. LCD HDTV
TV Won't Turn On
HI,
Please CLICK HERE for the list of TV repair centers.
Goodluck.
May 10, 2008 | RCA P52810LV TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
22 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
