Question about Creative Labs Zen Sleek Photo MP3 Player
Help! Devices show as working, but "not detected" when opened
I have two problems which I suspect come down to the same glitch in my computer. Online reading has not solved it. Windows directs me to Lenovo, and Lenovo directs me back to the Internet.
I am running Windows XP. Yesterday, I attempted to upload music from my Thinkpad to my Creative Zen Sleek Photo MP3 player. I plug in the MP3 player, and a box pops up saying "MTP Media Player". I am then prompted to sync Windows Media files to the device, but when I try to do so, it says "Windows Media Player does not detect a portable device. Connect your portable device, and then try again." I went into the device manager and it says the device is installed and working properly. But trying to open the device with it's own installed software or Windows Media both give me the message that there is no device attached "no device detected. I read that others had the problem and it might be a registry issue, so I changed the registry to allow "everyone" permission to the USB, but that didn't solve the problem. I uninstalled and reinstalled the player's software, but that didn't help either.
Then, today, I tried to use the Bluetooth installed on the computer for the first time, and had the same problem. The device manager says the Bluetooth in my computer is installed and working properly, but when I try to open the Bluetooth application, it states "Bluetooth device not found."
I suspect that these problems both stem from the same issue. Somehow, the computer is not able to communicate with these devices, even though they are properly installed and show in diagnostics to be working. I know nothing about how to work with the registry, so am now desparate for someone to tell me step by step what I should do. Can anyone advise me?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 16 Answers
You could try to go into the registry and remove the usb enumeration folder "USB" .HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Enum\USB\ change permissions for it to be able to remove it. When you restart your computer all usb devices will be recognized and installed again. Let me know if this helps or not.
Posted on Sep 14, 2009
Hello there please guys help me I bought ecs elitegroup motherboard but it doesn't detect my g210 invidia geforce after plug my graphic cart it shows strange lines
suspect you may need to disable the motherboard built in graphics card and tell it to use PCI graphics adapter otherwise an interrupt conflict in CPU and possible conflict as both devices compete for same computer resources.
Aug 14, 2015 | EliteGroup Computers & Internet
F9 error after power glitch
F9 is a door latch problem. its saying it can not read or detect if door is open. repair latch. good-day ! Unlock door and inspect the switches or clock assembly.
Nov 27, 2011 | Maytag MER5770 Electric Kitchen Range
My computer says it can't detact my webcam. everytime I go to it, it says no wecam detected.
The first step will be to check to see that your computer recognizes that anything is detected. to do this you should:
  1. Open your Control Panel (Make sure it's set to "Classic View")
  2. Click on "System".
  3. Go to the Hardware tab and click on "Device Manager".
  4. If your computer does recognize the camera, it should show up under "Imaging Devices".
If it does not, then it should show up under "Other Devices".
  1. Right click on the camera there, and click "Update driver"
  2. Now, follow the on screen instructions, and windows should get your camera working.
If your camera is recognized, but still doesn't show up, then you probable have a problem with whatever program is trying to use it. For that, I would need to know what program that is.
Feb 26, 2011 | Logitech Webcam
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
I have an 07 Mustang GT. When you open the door, the window comes down about an inch. When you close the door, the window goes all the way up. Normal. Now, when I close the door the window wont go up. Why...
The window lowering and raising as you open and close the door is normal, it is designed that way to prevent damage to the weather stripping that seals the door glass to the body. The computer controls this action and is activated by the door switch. If the problem is only with the driver door then I would suspect a switch. If the problem is with both doors then I would suspect a computer glitch. Either way I would reccommend taking the vehicle back to the dealer to have it checked out and repaired. Is the car still under warranty?
Aug 27, 2009 | 2007 Ford Mustang GT California Special...
Webcam can´t be found
Hi
After Change of vista to xp. Need to install the webcam software.
To detect the webcam
Right on My computer - Select Manage - Device manager - select the imaging devices for the webcam devices.
If does not shows go to View and select show hidden devices
If it is not showing in the devices manager
Shut down the notebook. Power on as soon power on the notebook keep tap on F8 to access the Advance startup options - select the Safe mode press enter
Check for the webcam device if doesn't show in this mode may need to Flash the BIOS.
With Regards
anand_manj2005@hotmail.com
Apr 10, 2009 | Computers & Internet
Bios setup error
Unplug ALL Usb devices, that includes printers, cameras, pen drives, i.e. anything that plugs into a USB connector. Then try rebooting your computer. I bet your problem will no longer exist, but if it does, then you need to suspect a faulty USB connector on the motherboard or USB chipset located on the motherboard. Once the computer is booting normally without USB devices hooked up, you can start installing ONE Usb device at a time, until you find your defective USB device. The USB device drivers will need to be installed and computer rebooted at least once between the various devices. Not doing so will lead to confusion as to which USB device is causing your high current problem. It is also possible athough a bit unlikely that this procedure will cure your situation for the time being but look out for it in the future because it could be an early sign that one of your USB devices is going bad.
Aug 11, 2008 | ASUS P5PE-VM Motherboard
My computer
OK I actually suspect ya MP3 player has gone Flakey ... ya say it won't detect "Devices" But, have ya tried "Other" things? or is it "Just" this particular MP3.. ?
In any event I would up date your USB drivers from manufacturers web site.
Jul 28, 2008 | Computers & Internet
Zen vision m not recognized
Same problem. Solved by downgrading Windows Media Player to v.10. Do it through Control Panel and click Remove WMP11 and WMP11 runtime. Restart, connect your player and if not recognized do go to Control Panel=>System=>Hardware tab=>Devices. Find Portable Devices drivers in the menu and click Uninstall MTP device. If still not detected, go to Control Panel=>Detect New Hardware and run that. The player should connect automatically. WMP 11 has a glitch that disallows 3rd party MTP players. Intentional or purposeful? Ask B. Gates.
Jul 22, 2008 | Creative Labs Zen Vision Digital Media...
Creative Labs Zen Sleek Photo MP3 Player Logo
174 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
