Question about Vehicle Parts & Accessories
Key fob will not unlock drivers door on mgf lucas type tn17
4 Suggested Answers
SOURCE: mgf central locking won't open the car doors
I had same problem. It was cured by "flicking" shut the interior opening handle of the drivers door. This allowed the central locking to lock then unlock the drivers door properly. You get into the car in the first place by using the romote to "unlock" and whipping the passenger door open quickly before it has a chance to relock!
Posted on Aug 13, 2009
SOURCE: Have 56 plate seat leon 1.6 .the alarm keeps going
I have Seat Leon 07 and my alarm has gone off loads of times in the last 18 months. The first time it was the window motor that went - went in under warranty and part replaced - it's now back in the garage getting the same problem fixed again. the neighbours are fed up with the alram going all times of the day and night. Hope this helps
Linda
Posted on Sep 18, 2009
  • 148 Answers
SOURCE: toyota fob does not work
Fob needs to be reprogramed after replacing battery. Not familiar with the programing on this vehicle, may have to be done at dealership with a scan tool, if you have the manual look in there and it should tell you. Feedback is appreciated, the only way we know if something helps is if we get feedback.
Posted on Feb 13, 2010
2007 sonata driver door won't unlock with key fob
door reciever or lock has issues
did you scan the car first.
does the receiver put 12dc to the unlock solenoid.
if yes the solenoid is bad.
if not the receiver has issues. (check connections first there)
Jul 15, 2015 | 2007 Hyundai Sonata Limited Sedan
Bmw drivers door only wont lock/unlock with key fob
Could be your driver door lock mechanism that is going bad , since the other door are working, it cannot be the fob. I would try to change the driver side door latch mechanism.
Apr 02, 2014 | 2008 BMW 320i Automatic
Key won't unlock driver door
the key or fob?
the key is bad,
use the spare key that came with all new cars.
always keep a spare. or get stranded.
Feb 22, 2014 | 2007 Honda CR-V
Key fob will not unlock driver door. It will
I would suggest a new key fob and get the dealers to program it so you know it all works.Yes some vehicles can be programmed by swinging on the aerial and pressing the rear tailgate all at the same time whilst turning the ignition on with the left foot whilst the right foot is on the am/fm radio button but whenever i have followed the instructions to the letter its far easier if the car is connected the dealers computer
Apr 30, 2010 | 2005 Toyota Highlander
Key fob only opens drivers door
hit the unlock button twice. most fobs are programmed so you hit it once, drivers unlocks, and again for all the rest.
Jan 25, 2010 | 2004 Volkswagen Passat
2003 Nissan Murano Driver door won't lock or unlock with keyfob
The key fob is the remote. But the remote type that works like a key. The remotes that you just need to carry on you to start the car or truck. That is a Key Fob.
Thanks Jay!
Jul 30, 2009 | 2005 Nissan Murano
Car will not unlock.
To get inside the car .... Use the key in the lock cylinder, unlock the drivers door to get inside. You shouldn't have to reprogram the fob unless it or the keyless module was changed. There may be a blown fuse that supplies the keyless control module (check the owners manual for location). or wires that lead into the Drivers door may be damaged ... The keyless module is located inside the drivers door at the bottom behind the door panel ... do the unlock/lock and trunk release switches on the inside of the drivers door operate the locks and or trunk release? If so it is not the fuse ... and not the wires to it ... And it could be your BCM body control module, located in the dash board to right of your gas petal. Because the number entry keypad (code for that is on the inside of the right passenger trunk bracket arm) also doesn't work I assume it's not the key fobs themselves. Your 98 manual is correct for your car.
Apr 02, 2009 | 1998 Mercury Grand Marquis
Mgf central locking won't open the car doors
Feb 21, 2009 | Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
