Question about Car Audio & Video
No power on PIONEER CD head unit - Car Audio & Video
Dude check the fuse on the back of the head deck if its ok look at the one the on your car for radio
Posted on Jan 05, 2009
My pioneer head unit wont come off mute when i turn on the radio mp3 or cd player
It happened to me today and it passed after a while when i was arriving home. Try to reset it by taking the power source off for a couple of minutes then try again.
Don't forget about your system definitions, it will be restored to default.
May 21, 2010 | Pioneer DEH-P5900IB CD Player
I have a 1998 Pioneer head unit to put in my car. the #is 1256237179. Is There anyway to get a diagram to see how to hook it up?
Well you can please follow the below steps -
1. Disconnect your car battery. It is vitally important to your safety that you never work on any type of electronic in your car with the battery still connected, as this puts you at risk for electrocution.
2. Remove the old stereo by taking off all the dashboard panels surrounding your stereo, sliding out your old stereo head unit, and unplugging all the wires that are connected to the head unit. Discard the old stereo.
3. Take your Pioneer car stereo head unit and plug each of the positive wires from your car speakers to the positive terminals on the head unit. Take all of the negative speaker wires and connect them to the negative terminals on the head unit.
4. Attach the stereo's black ground wire to a metal bolt or screw located near where the stereo is mounted in the dash.
5. Connect all of the ignition power wires to your Pioneer stereo.
6. Take the harness connector and plug it into your car stereo. Now plug the antenna into the back of your head unit.
7. Slide the stereo back into the dash, screw it in place, and replace the dashboard pieces you removed earlier.
8. Reconnect your car battery, turn the car on and test out your new Pioneer car stereo. Please post comments for more help or information..........
Good Luck!!
Thanks
Jan 16, 2010 | Sony CDX-F7710 Car Audio Stereo CD MP3...
NEED HELP ON PIONEER HEAD UNIT
get a variable power supply(ac to dc) that will get you 11-14 volts . You wont need a lot of amperes to run the deck.I had a buddy that just used a little car battery charger in his shop when he was jammin in there-kinda ghetto but hey it worked fine
Jan 14, 2010 | Pioneer DEH-2100 CD Player
Lost cable between changer and head unit for CDX-P25
http://www.hermanelectronics.com/HermanStore/homepage.asp
www.vancebaldwin.com
www.partstore.com
Jan 12, 2009 | Pioneer CDX-FM1277 12-Disc CD Changer
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Panasonic CD Changer with Pioneer reciever
Panasonic CD changers have a specific plug in that will not work with the Pioneer head unit. The Pioneer uses the IP-BUS plug. You will also not be able to convert the unit to work because the data between the two cannot be controlled and you won't have the ability to use the units together.
Sep 12, 2008 | Panasonic CX-DP801 8-Disc CD Changer
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
Pioneer DEH-p3700MP Head unit and CD stuck
Had the same problem with a burned CD with a printed label.
I had to press the eject button and help it with some plyers.
Best of Luck.
Nov 27, 2007 | Pioneer CD Receiver - DEH-P3700MP - CD/MP3...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
