Question about Toshiba Computers & Internet
No channels have been added yet message on toshiba tv connected to tivo
Pressed channel button on tv remote and no channels have been added message comes up on tv
SOURCE: TV suddenly doesn't respond to Sony remote & power button on Satellite remote.
I am having the same problem with the "initial setup" screen flashing repeatedly/ intermittently. It's not a problem with the remote. In the research I have done online, it seems as though this is a common/known problem with the Wegas that will require a service visit. Apparently the problem is a defective receiver chip. The best thread I found is at: http://www.agoraquest.com/viewtopic.php?topic=15393&forum=34&start=0&select_page_number=1 I've seen some speculation that it is caused by windex or cleaning fluid dripping down when the screen is cleaned and corroding one of the internal components. That's not applicable in my case, since I always just clean the screen with a microfiber dusting cloth. So, I guess I will be calling a repairman and spending $$$ to fix as it is now flashing up so often as to be unwatchable. Ridiculous, I think, given that my TV is only 3 years old!!
Posted on Jan 11, 2007
  • 1694 Answers
SOURCE: remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Posted on Oct 02, 2007
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
SOURCE: Tivo won't change my TV Channels anymore with direct cable
I re-did the guided setup in the Tivo under Messages & Settings/Restart-Reset System/Restart menu section in Tivo. Once I did that, it cleared this issue, even though I didn't have to change any of my settings thru this guided setup. I tried a reset alone first, but that did not fix it. Only this fixed it. We had lost both power and cable during a recent tree fall in a storm, and when both were restored, this problem started. I have a cable coax directly in the back of the TV (no cable box/IR etc) and the system is on a home wireless network. I actually have 2 identical Tivo's in the house set up the same way but only one had this problem. The other worked no different after the outage.
Posted on Oct 13, 2008
SOURCE: TIVO DVR : Won't Change Channels
Set up your infrared blasters connected from your IR port on the Tivo and by placing the two lead lights in front of your cable box so it (the cable box) can read the signal.  Then go to Channel settings accessed through Tivo Central and follow the questions. It will ask you to change channels until the remote is working correctly.  This all worked on a different "input" on my Mitsubishi TV (it has multiple inputs.  I have the cable input on a different "input" to make it work.  Hope this helps.  Call TIVO tech assistance because they are the ones who talked me through this.
Posted on Jan 15, 2009
Remote control code required for virgin TiVo & 50 inch blaupunkt TV combo
I have just managed to do this. I cannot tell you the code as I had to do it manually, but this is how I did it.
point the remote away from the TiVo and hold down the clear button and the to button until the free light flashed twice.
type in the code 0999 and the light will flash again. Then point the remote at the to and press and hold the channel up button. You will now scroll throw all the codes.
it will take about a minute but eventually the to will go off. When this happens release the channel up button and hold down the green on button to try turn the tv on with the TiVo remote.
if it comes on press ok and this will store the code. If it doesn't come on, use the blaupunkt to remote to turn the tv back on and then keep holding down the channel up button to scroll through more codes. When the to goes off again release the channel up button and try turn it on with the TiVo remote. If it works this time store the code by pressing ok
for me it took two attempts to turn the to on but eventually it worked on the second code
Nov 29, 2014 | Blaupunkt Car Audio & Video
I cant program any channels on my tv. Toshiba 42'' plasma. Do i need the remote or can i do it directly from the tv?
Which specific model from Toshiba do you have? There are several 42" TVs released with the Regza name. Most of the manuals can be found on the Toshiba support web site. http://www.tacp.toshiba.com/customersupport/
The one that I have allows for the channels to be set from the On-Screen Menu. In the TV mode, press Menu (there is a Menu button on the side of the TV). Navigate with the arrow keys (CH+, CH-, Vol+, Vol-) to the Setup menu and highlight Installation and press Enter (the Menu button is also the Enter key when using the buttons on the TV). Then highlight Channel Program and then Start and press Enter. When the search is done, press Ch+ or Ch- to view a station. To add or delete channels, use the Channel Add/Delete that is one line below Channel Program. Use the enter key to change the check mark status next to a channel. If adding a digital sub-channel not previously found, enter the number manually on the remote using the 100 key to add the dash. If the channel isn't found, an error message will result.
I hope this helps.
Jul 28, 2010 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
I want to set the remote to change volume on TV,we can change the channels using the Time Warner remote but cannot change the volume using thesame remote, we have to change the volume on the Toshiba...
I am not familiar with the Time Warner remote, but Tivo remotes require pressing "tv power" and the "Tivo" button at the same time to program them.
Maybe you are pressing one a little ahead of the other.
Oct 18, 2009 | Toshiba 26 26AV502R 26 in. LCD HDTV
Programming my TiVo remote to control my Proview TV
  1. Cover the end of the TiVo remote control with your hand.
  2. Hold down the TiVo and TV POWER buttons simultaneously until the red light on the remote control remains on.
  3. Remove your hand from the end of the TiVo remote control.
  4. Enter code 0999.
After you enter the code, the red light will flash three times and then remain on.
  1. Press CHANNEL UP once every two seconds. This will test hundreds of codes, one by one.
IMPORTANT: Do not go any faster than this or you may skip over a code that works.
  1. If you press CHANNEL UP and your TV turns off, press ENTER to select the code. Press the TV POWER button to test the code. If your TV turns on, you have successfully programmed the remote
Jun 11, 2009 | Tivo Series 2 Remote Control
I have upgraded my comcast service to an extended version including more channels but no cable box. I've been unable to set up my TIVO dual Series device to get the new channels, it only recognizes the...
Try this first...Press the TiVo button at the top center of the Remote, then > Messages & Settings > Restart or Reset System > Repeat Guided Setup and then follow the onscreen instructions from there.
This should load your new channel lineup into your TiVo.
If all the channels are still not recognized... Press the TiVo button at the top center of the remote, then > Messages & Settings > Settings > Channels > Channel List and then make sure all of the channels you receive are checked.
Jun 08, 2009 | Tivo Series2 Dual Tuner Digital Video...
Zenith TV
automatic code search. this may take a while to do but it works. hold the directv button and tv power until the red light stays on. while its on press the channel up button (this will search for a code). release and test with the tv power button. if the tv does not turn off, press the channel up button again and test with the tv power. when the tv finally goes off, press the enter/last button (bottom right corner of the remote) to store the code
Aug 31, 2008 | Philips DSR708R DirecTV / TiVo DTV...
Change channel lineup
1.) Press the TiVo button on the remote (at the top)
2.) Scroll down to "Messages & Settings" and press 'Select' on remote
3.) Scroll down to "Settings" and press 'Select'
4.) Scroll down to "Channels" and press 'Select'
5.) Press 'Select' on "Channel List"
6.) Pressing the "ENTER" button on remote will let you change Channel Line-Up
Aug 28, 2008 | Tivo Series2 TCD649080 Video Recorder
Mar 01, 2008 | Tivo Series2 TCD649080 Video Recorder
Loss of certain channels
Go into Messages & settings > Settings > Channels > Channel Line up and make sure there is a checkmark next to any channels you want and uncheck those you don't.
Dec 15, 2007 | Tivo DirectTV Remote Remote Control
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Computers & Internet Logo
1,899 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
