Question about Westinghouse LD-3235 32in LED 720p Flat Panel HDTV
LD-3235 Westinghouse LED LCD - Picture flickering
Picture Flickers / Lines in picture intermitently
3 Suggested Answers
SOURCE: westinghouse 27" lcd hdtv
I don't know if this will work for everyone, but we were having much the same problem with our Westinghouse LCD TV (which is what led me to this site in the first place.) After a great deal of experimentation we have found that if we keep the backlight setting at 3 or lower we do not have the problem. If we try to view it on the level 4, 5 or 6 setting the picture goes crazy after 5-15 minutes and does not clear up until the set has been turned off for about 30 minutes. Good luck! I hope this works for you too.
Posted on Mar 17, 2008
  • 395 Answers
SOURCE: 32inch westinghouse LCD TV flickers/slighly shaky picture-LTV32W1
try reseating the LVDS cable inside the set it is the multi wire connector from the main board to the LCD panel (top portion of the panel). if that doesn't look to see if the back lamps are remaining lit during this problem. if they go out the problem may be power supply or inverters (lamp power supply).. some panel makers make these available as a seperate part, some do not and the panel must be replaced. if the back lamps stay lit it is the main board. start with the LVDS cable first.
Posted on Apr 24, 2008
I have a Westinghouse 32" LCD model VR-3235 that the screen flickers and almost appears that each "refresh" of image is overlayed on the previous creating a "stacked" image.
hola amigo tu problema es la eprom de la pantalla por desgracia no de puede programar nuevamente ni sustituir ve a por una pantalla nueva y suerte
Dec 30, 2016 | Westinghouse Televison & Video
Westinghouse how to
Back-light problem.Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts.It will be best to replace the inverter board as card basis.
Aug 08, 2014 | Westinghouse LD-3260 32-inch LED LCD TV...
Why is it that my westinghouse 32 in LEDTV model#LD-3265 just went blank on me no sound no picture but powered up properly
Do the menus work or input labels appear when you change sources?
Have you tried unplugging the power with the tv turned on, waiting a few minutes, then plugging it back in and turning it on?
Jul 14, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Luxor 40 914 tvb
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 13, 2014 | Televison & Video
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Westinghouse ld-3235 led tv no picture
t con board on the back of the screen will need replacing, its the one with the wires going to it from the main av board to the screen. the chip can become damaged due to heat or even come away from the board. if its working when you bag the board it could be a lose connector or the connections that is soldered to the board have come away and will need soldering back on.
Jun 05, 2017 | Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse ld-3235 picture goes in and out connections are good stops after 30 minutes or so,only 5 wks old
I have the same tv and had the same problem.
If picture appears when you slowly hit back of the tv, then the solution is quite easy.
1-There are 2 small lids on the back of the tv, open the one at the top with using a screw driver.
2- there is a connector on the top, make sure that it is connected well.
As far as I understand there is somehow a connection problem or maybe result of oxidation or something.... 5_3_2012_9_06_22_pm.jpg5_3_2012_9_06_40_pm.jpg5_3_2012_9_06_54_pm.jpg
Oct 09, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Apr 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LD-3235 32in LED 720p Flat Panel HDTV Logo
161 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
