Question about Panasonic DMR-EZ47V DVD Recorder/VCR
The remote doesn't work
Every button I press on the remote does nothing, and RC2 comes up on the player. Help?
  • 5 Answers
Press "enter/OK" and hold number "2" for about 3-5 seconds - this should re-sync remote
Posted on Jun 16, 2009
Panasonic DMR-EZ28 has RC2 display /l cant see an enter button to try pressing 1 then enter
the unit has been changed to remote control 2 mode. Look in the owner's manual and change the remote to mode 2 and you should be fine.
Feb 20, 2015 | Panasonic Televison & Video
Error rc 1 but cannot engage the setup in order to follow instructions provided by panasonic
press and hold the numbered button
corresponding to the code on the
remote control simultanously with OK button for approx 10 secondes
ex: if rc1 appear on panel press number 1 and ok button on the remote for approx 10 sec. ( if RC2 press number 2, if RC3 press number 3)
Oct 06, 2013 | Panasonic DMR-EZ28K DVD Recorder
The remote is not responding. it displays RC2 whatever button you push.
  • Go ahead and press and hold the #2 button and the "Enter" button on your remote for 20 seconds and this will return control to your unit.
Regards, Tony
May 27, 2011 | Panasonic DMR-EZ37VS
When i push the buttons on the remote it keeps saying set 1
The remote is probably set to another command mode (for example, SET2, DVD2 or RC2 depending on the model unit) or the batteries were replaced recently, so the remote needs to be reset. You can try this: take the batteries out of the remote (as if to replace them), press any button to clear the remote's buffer, then re-insert them. Point the remote at the player, then press and hold 1 and ENTER/OK buttons together for approximately 10 seconds, then release. This should restore the remote's function back to your player. This 'remote reset' must be done whenever the batteries are replaced, otherwise either the remote will not function correctly, or the device will not recognise it.
Very simple, takes a few seconds or so, and costs nothing to try.
Apr 17, 2011 | Panasonic DMP-BD30K Blu-Ray Player
Panasonic DMR-EZ485V. Remote stopped working when
Panasonic website under FAQs. Using code shown on dvd readout,
such as RC2, press 2 & enter or ok, hold for 2 seconds, and machine
will reset connection between remote & dvd recorder. So stupidly simple it works.
Feb 15, 2010 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Universal Remote says ''RC2'' for DMR-EZ27
Question (s): The remote control for my DVD recorder has stopped working. Every time I press a button, the display says "CHK REMOTE 1", "RC1" or "SET1". What is wrong? Answer/Comments: Your DVD recorder remote control can be programmed (with different codes), so it can be used with multiple Panasonic DVD players. When you press a button and the display shows [CHK REMOTE #] or [RC#] or [SET#] it means that the DVD recorder and the remote control are not set to the same code.To set the remote control code to that of the DVD recorder, press and hold [ENTER] as well as the corresponding code number on the display (1, 2 or 3) at the same time for more than 2 seconds.
Mar 14, 2009 | Panasonic DMR-EZ27K
Panasonic DMR- EA18 DVD player/recorder - Remote control Problem
I figured out, unlike all the other posts, you don't have an enter button. But Instead, you would hit the 2 and OK button at the same time for a few seconds. I had the RC1 message and I did the 1 with OK and it worked. so if you have RC2, you should hit the 2 and OK. Should work!!
Jan 26, 2009 | Panasonic DMR-ES25 DVD Recorder
Panasonic DMRES20 dvd recorder shows RC2 on the display and has no response. My original remote control quit working. Replaced that remote with a universal phillips. that worked fine until I changed the...
Read the manual. Using Panasonic remote hold the enter button down and #1 or #2 for at least 2 seconds until you find the right code combination for the remote and unit.
Sep 02, 2008 | Televison & Video
DMR--EZ48V
Your DMR is telling you that it is set to listen for RC2 but your remote is transmitting RC1.
Two choices for a fix:
1. Put the remote back into RC2 mode by simply holding both the ENTER and 2 button for at least 5 seconds.
OR
2. Reconfigure the DMR to listen for RC1 by going into the function menus and selecting SETUP. Look for the remote control option. Change it to 1, it will currently display the value 2.
Enjoy.
Mar 19, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
123 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
