Question about Bissell SpotBot Robotic Wet/Dry Vacuum
Spot bot leaking when using manual hose
Water pouring out the center spout of the rotating circle when and only when I use the manual hose. Please help. Checked all the easy stuff.
  • Kathryn Michaels Jan 08, 2013
    Mine is doing the same thing. It's not the duckbill gasket and not an obvious leak from the clean tank. Read somewhere else there's supposedly an internal gasket/ low-quality rubber ring that may need to be tweaked, but you have to take the whole bottom of the machine off.
  • 3 Answers
This is an old post but I thought it might help anyone having this problem now to post the solution.
The internal water pump feeds two water delivery hoses on the Bissell Spot Bot. One goes to the spout located in the center of the rotating brushes.
The other feeds the spout located on the underside of the brush at the end of the hose.
There is a water shut off valve that is actuated when you pull the plastic tube at the end of the hose out of the plastic tube it is fitted into during storage.
When you pull the end of the hose out of this plastic fitting a button inside is no longer depressed and a valve shuts of the water flow to the rotating brushes. If this valve is clogged with gunk it will not release when the hose end is pulled out and water will still come out of the rotating brushes even in manual mode.
This is a mechanical fault not an electronic fault.
To resolve the issue you can mix a solution of vinegar and hot water and fill the water tank with it.
Put the rotating brushes over the sink. Remove the hose and fit the scrub brush to the end.
Start the machine in manual mode. The sink will catch the water coming from the rotating brushes area.
Now point the hose end at the sink to catch the water and pull the water release trigger. While holding the trigger press and release the black button inside the tube that holds the hose end during storage. This moves the internal workings of the valve.
Do this till all the water is gone.
At some point during this procedure you will notice that when you release the black button the water will stop coming from the rotating brushes.
You problem is now solved.
If this does not work after two tanks of hot water and vinegar then the valve would need to be removed and soaked in a solution or replaced.
This is a much more complex procedure that requires disassembly.
Maybe a youtube video is in order.
If your lucky the procedure above will solve the problem.
Posted on Jan 15, 2013
reddevil6
  • 1673 Answers
SOURCE: Spot Bot
Their customer service # is 1-800-237-7691 and they can tell who to call for service. You can also go to bissell.com, there is a link for service centers, just put in your zip code and a list will come up.
BISSELL Service Center Locator Please enter your ZIP Code: CANTRELL SUPPLY INC. 2918 SOUTH COOPER F-2 ARLINGTON TX, 76015 (817)465-9121 11.1 miles BRANCH VACUUM & JANITORIAL SUPPLIES, L.P. 12895 JOSEY LANE #122 FARMERS BRANCH TX, 75234 (972)247-5838 15.7 miles FORT WORTH SHAVER & APPLIANCE 1900 MONTGOMERY STREET FORT WORTH TX, 76107 (817)335-9970 16.3 miles AMERICAN VACUUM CO. 5545 W. LOVERS LANE DALLAS TX, 75209 (214)357-8419 18.2 miles KIRBY CO. OF DALLAS 4118 MAPLE AVE DALLAS TX, 75219 (214)526-7951 19.0 miles BRUNER KIRBY CO., INC. 5608 MC CART AVE. FT. WORTH TX, 76133 (817)292-8421 19.4 miles VACUUM DEPOT 5359 WEDGEWOOD FT WORTH TX, 76133 (817)292-4472 19.4 miles MODERN AMERICAN MAINTENANCE 8545 CAMP BOWIE WEST FORT WORTH TX, 76116 (817)244-0919 19.9 miles ALL VAC, INC 4451 LOVERS LANE DALLAS TX, 75225 (214)521-2558 20.2 miles KIRBY CO. OF DESOTO 104 N. HAMPTON ROAD DESOTO TX, 75115 (972)223-4029 23.8 miles AAA VACUUM CLEANER CO. 9845 WALNUT HILL LANE DALLAS TX, 75238 (214)348-1620 25.0 miles BROADWAY VACUUUM 4401 BROADWAY BLVD GARLAND TX, 75043 (972)240-7971 31.1 miles THE VACUUM DOCTOR 500 NORTH GALLAWAY - STE. 10 MESQUITE TX, 75149 (972)329-1104 31.4 miles CHAMPION VACUUM, INC. 8809 LAKEVIEW PARKWAY #128 ROWLETT TX, 75088 (972)463-2755 34.3 miles VACUUM & SEWING DR. OF TERRELL 811 WEST MOORE, SUITE E TERRELL TX, 75160 (972)563-0330 49.8 miles var prm = Sys.WebForms.PageRequestManager.getInstance(); prm.add_initializeRequest(resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity); prm = null; function resizectl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity() { var elAct = $get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_ctl00_pnlActivity'); var bounds = Sys.UI.DomElement.getBounds($get('ctl00_ctl00_cphAllContent_cphContent_pcaMain_ctl02_upServiceCenter')); elAct.style.width = bounds.width + 'px'; elAct.style.height = bounds.height + 'px'; Sys.UI.DomElement.setLocation (elAct, bounds.x, bounds.y); } Locating Stores... progressbar.gif
Posted on Feb 29, 2008
SOURCE: how can i clean the hose of my bissell spot bot?
Well... it's sub optimal but this is what I did, run hot water into the sink, add a few table spoons of bleach and run the hose along the edge of the water to slowly **** it into the hose (the tank fills very rapidly and the auto shut off will activate). You will want to run 4 or 5 tanks of waste to get the bulk of the gunk along the walls out and this will also get rid of the serratia growing (red stuff). If you dangle the hose in a u down the front of the sink and shut off the machine you can catch about a pint of water and bleach solution in the hose and roll it around inside the hose then let it sit for awhile and finish by sucking it into the waste tank, not perfect but my hose is much cleaner.
Posted on Jun 28, 2009
SOURCE: Need to clean hose.
I filled a bowl with hot bleach water and sucked the water up. It cleaned the hose pretty well (along with the gunk that was stuck in the hand wand). Mine was filthy. It looked like it had mold growing in it. Then I ran several rounds of hot water through the hose. I alternated hot water & bleach. Did this about 8 times. It is not perfect, but it sure does look a lot better. 90% of the gunk is gone.
Posted on Sep 03, 2009
  • 85 Answers
SOURCE: The hose on my spot bot has torn
yes you can replace the hose for $25
If your unit is less than a year old it will be under warranty and replaced at no charge to you
Posted on Dec 15, 2009
  • 85 Answers
SOURCE: bissel spot bot water not coming out of tank
you could take the end of the handle off 2 screws i think check the line for a clog or just take it to a bissell service center it will be covered under warranty
Posted on Dec 16, 2009
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1039&cid=ccsocial
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Tip
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Automatic Clean on Spot Bot 1200 dosent work
Ted, it can be bear when the auto settings aren't working. One of our service centers can inspect and fix any warranty repairs needed.
To locate a BISSELL Authorized Service Center, please click on the following link:http://www.bissell.com/service-centers/&=ccsocial
Oct 22, 2012 | Bissell SpotBot Robotic Wet/Dry Vacuum
Need a Bissell Spot Bot Manual
You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
http://www.bissell.com/searchresults.aspx?searchtext=1200&mode=userguides
May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
Spot Bot leaking water from reservoir through brushes
make sure that your collection tank is empty and correctly attached. If it is full, it will shoot water on the spot, but not **** it up several times in the cleaning process leaving a large wet puddle bigger than the original spot.
Mar 16, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Leaving bigger dirtier wet spots after cleaning
Sounds like the vacuum motor is defective or you have a clog in the vaccum line. Basically everything is running except the vacuum "Suction" cycle. Do you hear the "Suction" phase (light indicator) during operation when it loudens like a whine? That would be the vacuum phase. Is the dirty water reservoir clean, do you rinse it thoroughly when you empty it? Have you removed the hose assy and rinsed it out? I think it is still part of the auto cycle even if you don't use the manual tool.
Feb 24, 2010 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissel spot bot water not coming out of tank is not a year old and tried manual wand and the water doesn't come out there either. any advice. Is not a year old yet.
Dec 16, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Clean the spot bot hose, it looks dirty.
My hose was filled with black mold, nearly from end to end, because I didn't clean it properly a year ago, which was the last time I used it. Here's how I got every speck of grime and mold out of the hose, and brought it back to looking brand new!
1. I placed the Spotbot on the counter on one side of my deep utility sink.
2. I unwrapped the hose from the body of the machine and held the mouth of the hose low, close to the sink drain.
3. I ran the water until it was scalding hot, and put the hose mouth up to the stream, keeping it low. I filled it for 3 seconds.
4. Then I poured spashless bleach down the hose mouth for a 2-3 second pour. Add more water if needed.
5. With a portion of water in the hose, I swung it back and forth, moving the bleach water all over the affected areas.
6. I continued to fill the hose with water and bleach(2-3 times), until I had a 1.5 inch reservoir in the dirty water basin to act as a suction plug.
7. I plugged my utility sink, and filled it with 3 inches of hot water, which I used to continue to fill my hose and to push out the air bubbles.
8. When the hose was full from end to end with bleach water and no air bubbles, but the reservoir remained at 1.5 inches full, I filled a plastic jar with 3 inches of water (for stability), and pinched the mouth end of the hose together upright into the jar. I placed the jar directly across from the Spotbot on the counter, on the other side of the utility sink. This means each end of the hose is elevated, and the body of it is hanging in the utility sink.
9. I left it like this all day and overnight. 22 hours later, I returned and the hose was pristine! I backwashed the hose and the dirty water reservoir out 4 times and hung the hose over the faucet to dry.
10. Hope this helps you!
Jun 21, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spot Bot
Feb 29, 2008 | Bissell 12005 Spot Bot Handheld Vacuum
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
HTH
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
492 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
