Question about LG 47LE5500 TV
47LE5500 firmware upgrade doesn't load
What is the process of updating the the firmware on my 47LE5500?
2 Suggested Answers
  • 8457 Answers
SOURCE: I've upgraded the FW on
Ur tv Firmware u upgraded it have corrupted files or the wrong version.Sorry ur main board tv Tuner signal board it have corrupted in it softwares or the wrong version in it CPU programming now.This problems,u cannot be undone or put the old version back.Only can repair by doing replacing a whole refurbish new tv Tuner signal board only now.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish main board tv Tuner signal board for the replacement.
Posted on Aug 30, 2011
Configuration Lost After Restart
there must be some memory on the board that isn't functioning properly. Try to do a factory defaults and set it up and see if it sticks. If it doesn't then I would suspect bad circuitry or perhaps firmware issue. You can upgrade your firmware may resolve this issue.
Here is where you can download your manual and download firmware. Do not update firmware through wireless connection!
http://www.dlink.ca/products/?pid=DIR-601&tab=3
To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process. Wait about 30 seconds to access the router. The default IP address is 192.168.0.1. When logging in, the username is admin and leave the password box empty.
The updated version of firmware is level 1.02NA You can check which level of firmware you currently have installed and if its a lower number you can try to update it if factory defaults don't do the trick.
May 19, 2012 | D-Link Wireless N 150 Home Router 4Port...
Cruz T103 android upgrade problems!
You should try doing the whole process all over again. If it still won't turn on then it's time to flash the firmware into the tablet using your computer.
Mar 31, 2017 | Micro Innovations Velocity T103 Tablet PC
Firmware version
Wireless routers contain built-in programmable logic called firmware. The firmware is embedded software that implements network and security protocols for that specific model of hardware device.Every wireless router ships with a tested version of firmware provided by the manufacturer. However, most routers are also designed to support a firmware upgrade process. This allows the manufacturer to provide enhancements to routers already sold. Manufacturers generally provide firmware upgrades as free downloads from their Web site.
Additionally, a few manufacturers (like Linksys) provide their firmware as open source code on the Internet. Programmers worldwide are free to modify and extend the code with new features for their routers. Several versions of this hacked firmware can be found on the Web, but the average homeowner should avoid these types of firmware.
The Firmware Update Process
You begin a firmware upgrade by downloading a binary file package from the manufacturer's Web site. After the package is set up properly on a PC, an administrator can launch the actual upgrade from the wireless router's administrative console. The router will stop functioning if the upgrade fails to complete. For this reason, manufacturers generally recommend an Ethernet cable be run from the router to the PC to ensure maximum stability during the update. Consult the router's product documentation for details.
Immediately after purchasing a router, check the firmware version to ensure it is the latest version. Firmware can be installed on a router at the factory several months before the router is sold.
Then, check the manufacturer's Web site occasionally over time for any new firmware upgrade postings. Each time a firmware upgrade is posted, the manufacturer will provide notes detailing the enhancements it provides. Feel free to skip an upgrade if the new version does not offer any interesting features. However, if a router is performing sluggishly, freezing unexpectedly or experiencing dropped connections, firmware upgrade often supplies a quick fix.
Dec 15, 2011 | NetGear Computers & Internet
I've upgraded the FW on my LG 47LE5500 and now the TV is not succeeding to start - looping reboot
Aug 30, 2011 | LG 47LE5500 TV
Where can i find firmware updates for LG GSA-4163B dual layer burner - believe it to be A106
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).
The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
WARNING: Never update the firmware if the problem you're having is the drive isn't seen by windows, won't write with the included software, or other interface related problems. Unless the firmware specifically states it fixes the problem you are having, firmware updates normally don't fix these types of problems. Trying to update the firmware when there are interface problems can damage the drive's firmware. An error when updating the firmware is usually caused by a problem with the drive interface or there is more than one drive connected to that IDE channel.
IMPORTANT: do not interfere with the drive during the firmware update. If an error occurs during the upgrade process, or the upgrade process is cancelled during this process, damage to the drive can occur. If you experience any problems or have any questions, please contact our LG customer support line toll-free at 1-800-243-0000.
Hope this helps you
Aug 21, 2011 | LG (GSA4163B) DVD±RW Dual Layer...
I got the old 407291 software version on my machine and would like to upgrade my firmware, but LG says : Contact your dealer --- Please help
You can download any available ODD (Optical Disc Drive) updates from http://us.lgservice.com. Click Product Support, click Optical, choose your model number from the list, and click go. Click the Drivers & Software tab. Download the latest version posted (highest number).The firmware for all recent drives works with Windows. Before running the update, make sure the drive is empty. Close as many programs running the background as you can. Run the downloaded executable file to start the update. Some will automatically start updating the dive and some will require you to push "Upgrade" or "Start". If the firmware doesn't see the drive it was designed for, it will not install.
hope this helps
Aug 11, 2011 | LG BH08LS20 Blu-ray Burner
La impresora 4345mfp se bloquea y nose como hacer la actualizacion del firdware.
Upgrading the firmware
The MFP has remote firmware update (RFU) capability. Use the information in this section to
upgrade the MFP firmware. The overall process involves the following steps:
1 Determine the current level of firmware that is installed on the MFP.
2 Go to the HP Web site and find out whether a firmware update is available. If an update is
available, download the latest firmware to your computer.
3 Transfer the new firmware from your computer to the MFP.
Determining the current level of firmware
To determine the current level of firmware, view the configuration information on the MFP control panel. To view the configuration information, follow these instructions.
1 Press MENU.
2 Touch INFORMATION.
3 Touch PRINT CONFIGURATION. The configuration page prints.
4 The firmware datecode is listed in the section called Device Information. The firmware
datecode has this format: YYYYMMDD XX.XXX.X. The first string of numbers is the date, where
YYYY represents the year, MM represents the month, and DD represents the date. For example, a firmware datecode of that begins with 20040225 represents February 25, 2004.
Downloading the new firmware from the HP Web site
To find the most recent firmware upgrade for the MFP, go to www.hp.com/go/lj4345mfp_software.
This page provides instructions for downloading the new firmware version.
Transferring the new firmware to the MFP
Use one of the following methods to update the firmware.
Using FTP to upgrade the firmware on a network connection
NOTE The MFP can receive an .RFU file update as long as it is in a "ready" state.
The elapsed time for an update depends on the I/O transfer time, as well as the time that it takes for the MFP to reinitialize. The I/O transfer time depends on a number of things, including the speed of the host computer that is sending the update. If the remote firmware update process is interrupted before the firmware is downloaded (while Receiving Upgrade appears on the control-panel display), the firmware file must be sent again. If power is lost during the flash DIMM update (while the Performing Upgrade message appears on the control-panel display), the update is interrupted and the message Resend Upgrade appears (in English only) on the control-panel display. In this case, you must send the upgrade by using the parallel port. Finally, any jobs that are ahead of the RFU job in the queue are completed before the update is processed.
Follow these instructions to perform the upgrade by using FTP.
To upgrade the firmware on a network connection by using FTP
1 Take note of the IP address on the HP Jetdirect page. The HP Jetdirect page is the second page that prints when you print the configuration page.
NOTE Before upgrading the firmware, make sure that the MFP is not in Sleep mode.
Also make sure that any error messages are cleared from the control-panel display.
2 Open an MS-DOS command prompt on your computer.
3 Type: ftp <TCP/IP ADDRESS>. For example, if the TCP/IP address is 192.168.0.90, type ftp
192.168.0.90.
4 Press Enter on the keyboard.
5 When prompted for the user name, press Enter.
6 When prompted for the password, press Enter.
7 Type bin at the command prompt.
8 Press Enter. The message 200 Types set to I, Using binary mode to transfer files appears in
the command window.
9 Type put <filename> where <filename> is the name of the .RFU file that was downloaded
from the Web, including the path. For example, type put C:\LJ\4345FW.RFU, and then press
Enter.
NOTE If the file name or path includes a space, you must enclose the file name or path
in quotation marks. For example, type put "C:\MY DOCUMENTS\LJ\4345FW.RFU"
The following series of messages appears in the command window:
? 200 PORT command successful
? 150 Opening BINARY mode data connection
? 226 Ready
? 226 Processing Job
? 226 Transfer complete
Then, a message that contains the transfer-speed information appears.
10 The download process begins and the firmware is updated on the MFP. This can take
approximately five minutes. Let the process finish without further interaction with the MFP or
computer.
NOTE The MFP automatically turns off and then on again after processing the upgrade.
11 At the command prompt, type: bye to exit the ftp command.
12 At the command prompt, type: exit to return to the Windows interface.
Using MS-DOS commands to upgrade the firmware
To update the firmware by using a network connection, follow these instructions.
1 From a command prompt or in an MS-DOS window, type the following: copy /B <FILENAME>
\\<COMPUTERNAME>\<SHARENAME>, where <FILENAME> is the name of the .RFU file
(including the path), <COMPUTERNAME> is the name of the computer from which the MFP is
being shared, and <SHARENAME> is the MFP share name. For example: C:\>copy /b C:
\9200fW.RFU \\YOUR_SERVER\YOUR_COMPUTER.
in quotation marks. For example, type: C:\>copy /b "C:\MY DOCUMENTS\3500FW.RFU" \\YOUR_SERVER\YOUR_COMPUTER.
2 Press Enter on the keyboard. The control panel shows a message that indicates the progress of the firmware upgrade. At the end of the upgrade process, the control panel shows the Ready
message . The message 1 file(s) copied appears on the computer screen.
Jul 15, 2011 | HP LaserJet 4345mfp Printer
Hi Yesterday i upgrading my Samsung wave s8500 firmware. while upgrading internet connection is Disconnect and now my phone only shows one picture on display whenever i tried to USE it... PICTURE i.e One...
Step I: Download the latest version of Samsung Kies from official site of Samsung Kies. The latest version of Kies is: Kies_2.0.0.11044.
OR
You can download it from here: Samsung Kies Download Link
Step II: Open Samsung Kies and connect your Samsung Wave with PC (Wait for driver installation, if you have attached your phone for the first time with your pc)
As soon as Kies will detect your phone it will offer a prompt of new firmware update available, see the screenshot below
Firmware upgrade prompt
Click on UPDATE button
Step III: Now you will face a window of 'Agree to the Terms and Conditions." You can choose the option of save and don't save the information. This option is that, Samsung will store your information of IP and hardware specifications on their servers for 2 years. It is totally dependent on you, which you want to choose.
We would like to recommended you to choose "Allow saving"
Upgrade Terms & Conditions
Hit START UPGRADE button
Step IV: It is strongly recommended not to disconnect your phone from PC until the upgrading process is complete. So take care of it.
Within few minutes (depends upon the speed of your internet connection). Upgrading process will move on and will complete successfully.
Upgrade in Progress
Note: Don't use any options on your phone, while the upgrading process is taking place, your phone will be restarted. DON'T PANIC!
Your phone will come to working state automatically and your Samsung Wave is successfully upgraded to Bada 1.2
Jun 03, 2011 | Samsung Wave S8500 Smartphone
Blackberry 8520 curve was reset app 523 error what i do
Connect to the Desktop Manager. If your device still having problems. Wipe it with BBSAK. Then insatll software from Loader application.
May 04, 2011 | RIM BlackBerry Curve 8520 Smartphone
Open Questions:
See all LG 47LE5500 TV Questions
LG 47LE5500 TV Logo
57 people viewed this question
Computer Repairing
Computer Repairing
