Question about Braun Flex Integral Shaver 5520
Need to replace batteries for 5520 braun - Braun Flex Integral Shaver 5520
2 Suggested Answers
brector3
  • 1625 Answers
SOURCE: i need to replace batts in a Braun #5520...i donr
You will need to remove the two screw covers on the bottom of the shaver. They are on each side of the hole where the cord plugs in. Then remove the two screws to take off the bottom and you can then slide the outer case off the bottom also. You may need to change the position of the lock to get this outer case off.
You will then need to remove the black plastic back of the inner case. It snaps on so you will need to 'unsnap' it. You can then remove the circuit board for easier access to the batteries. Reassemble in reverse.
You can purchase batteries from shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
be sure to read the installation note on the item page
Posted on Feb 09, 2010
What is model number of clean and charging stand for a 5520 Braun shaver
Braun does not make a clean and charge stand for model 5520
Jul 29, 2015 | Braun Health & Beauty
I have 6520. when i plug it into a wall jack i does not charge and does not show power from the wall jack any more. this means when the battery is out it will not work any more. please help
Model 6520: If the green light no longer illuminates when you plug it in, you have waited too long to address the battery problem and the circuit board is now damaged. Replacing the batteries alone will not help as it will still not be able to recharge. To repair, you will need a new circuit board but Braun has discontinued for this model. You will be lucky to find one at this date.
model 5520, 5525, 5550, 6520, 6525 and 6550 are all prone to this problem when you neglect batteries that no longer charge correctly. It is suggested that batteries be changed early on when you notice that they are a problem instead of running your shaver from the cord until it dies.
Aug 12, 2011 | Braun Health & Beauty
The razor will not hold a charge. How can the battery be replaced? How much does a replacement cost?
Thanks for using Fixya. You can buy battery for your braun shaver 5520 from this website. It will cost you around $40.
Have a nice day.
Rating the solution is highly appreciated.
Mar 10, 2010 | Braun Flex Integral Shaver 5520
I need to replace batts in a Braun #5520...i donr
Feb 09, 2010 | Braun Flex Integral Shaver 5520
My Braun shaver model 5520 won't take a charge anymore. When you plug it in, the green light doesn't go on and it won't charge. The shaver is at least 10 years old. Thanks
If the green light no longer comes on when you plug it in, the circuit board is also damaged. The circuit board often gets damaged from continuing to run the shaver directly from the cord after the batteries have gone bad. Prolonged use like this will eventually ruin the circuit board in this model type.
To purchase a new circuit board, which includes batteries pre-installed to it, you can get them from shaveroutlet.com. See link below.
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-106.html
Replacing this is not difficult if you know how to get inside. There are two screw covers on the bottom of the shaver. They are found on each side or the port that the cord plugs into. They can be gently pryed off with the edge of a razor blade. Once removed, you will see screws underneath. Remove screws nd then the outer case of the shaver will slide down and off. You may need to move the travel lock to it's opposite postion for the case to move off freely.
Once the outer case has been removed, you will see that there is an internal cover made of black plastic. It simply unsnaps from 4 points and can be removed. You will then see the circuit board and it can simply be lifted out.
When putting in a new circuit board, you may need to remove a rubber protective coating that covers some of the contact points. Them drop it in place and use instructions above in reverse to reassemble.
Jan 23, 2010 | Braun Health & Beauty
Braun Syncro 7505 Shaver, Need Power Cord.
If you just need a eplacement cord, you can get one at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-charger-cord-for-7000-syncro-8000-activator-360-complete-p-120.html
If you need batteries or PC board, this will raise the price considerably and you may find a less expensive option of buying a replacement. You will also find similar replacement units at shaveroutlet.com
Jan 14, 2010 | Braun Syncro 7505 Electric Shaver
Braun electric shaver will not charge.
Your batteries are no longer capable of being recharged and need to be replaced.
If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Hope you find this Very Helpful and best regards!
Sep 05, 2009 | Braun Flex Integral Shaver 5520
Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Nov 03, 2007 | Braun Flex Integral Shaver 5520
Health & Beauty Logo
81 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
