Question about Camping, Backpacking & Hiking
Any idea where i can find replacement bulbs for utilitech battery lantern?
I bought one tonight at Lowes and they didn't carry the replacement bulbs and i have searched the web and have had no luck finding them. Gives off great light but if i can't replace the bulbs it will be useless once the ones that came with it burn out.
SOURCE: Vector Super Sport Spot VEC127Y replacement battery
I need a new power supply for my Vector Spotlight, Model VEC127Y. Any suggestions as to where one can be purchased?
John seadoc@aol.com
Posted on Nov 17, 2008
  • 29 Answers
SOURCE: replacement globe for a 1960's thermos portable gasoline lantern
Hard find.........www.ronfoo.com
This guy may be able to point you in the right direction being an antique/collector's item.
GGBMDB
Posted on Dec 02, 2008
  • 973 Answers
SOURCE: trying to find replacement bulbs for our Swissgear
You can find the bulbs you need at this link; http://www.bulbs.com/eSpec.aspx?ID=14393&Ref=Light+Bulbs%2c+Ballasts%2c+Fixtures+and+More&RefId=0
Posted on Jun 25, 2010
CarlGlas
  • 283 Answers
SOURCE: replacing batteries on Energizer Hard Case Lantern
Step 1.
Start by locating the battery compartment which will be on opposite end of the lamp. The compartment is covered with a protective rubber, tire-tread-like surface.
Step 2.
Twist the cover of the battery compartment counterclockwise to unscrew. Do not unscrew any of the screws on the sides of the spotlight, you need only to use your hand to turn and take off the battery casing cover and expose the batteries.
Step 3.
Remove the old batteries taking note of the orientation of the batteries in relation to positive and negative polarity.
Step 4.
Install replacement batteries, making sure to replace the batteries using the correct polarity.
Step 5.
Replace the cover of the battery compartment by putting it back into place and turning clockwise until secure.
  • Step 2 Twist the cover of the battery compartment counterclockwise to unscrew. Do not unscrew any of the screws on the sides of the spotlight, you need only to use your hand to turn and take off the battery casing cover and expose the batteries.
  • Step 3 Remove the old batteries from the hard case spotlight's battery compartment. Take note of the orientation of the batteries in relation to positive and negative polarity. Check for any corrosion of the battery terminals and clean with a small amount of vinegar, if necessary. Allow vinegar to air dry before replacing the batteries.
  • Step 4 Install 4 new C size batteries into the spotlight. Make sure to replace the batteries using the correct polarity. Rechargeable batteries are not recommended for this particular spotlight.
  • Step 5 Replace the cover of the battery compartment by putting it back into place and turning clockwise until secure.
  • Read more: How to Replace the Battery for an Energizer Hard Case Spotlight | eHow.com http://www.ehow.com/how_6182197_replace-energizer-hard-case-spotlight.html#ixzz0sx9yYC1Q
    Posted on Jul 07, 2010
    CarlGlas
    • 283 Answers
    SOURCE: Coleman rechargeable lantern: Charged overnight -
    Check the battery with a volt meter to make sure you have the correct voltage. If not, replace battery. If correct voltage, bypass switch to determine if it is good or not. If not, replace. There really isn't much to go wrong on the lanterns except the bulb or battery.
    Posted on Jul 21, 2010
    I need the English instructions for the Utilitech timer #0144506
    I found a Utilitech timer at Lowes with the item number #0144506. The Utilitech model number for this timer is UTTNID001. If this is the correct timer, the manual is on the product page: https://www.lowes.com/pd/Utilitech-15-Amp-1-Outlet-Digital-Residential-Plug-in-Lighting-Timer/4740850 . Scroll down and expand the Guides & Documents section. The direct link is currently: http://pdf.lowes.com/useandcareguides/054732817825_use.pdf .
    I hope this helps.
    Nov 23, 2017 | Hardware & Accessories
    Utilitech pump model KLHO75 manual
    Lowe's has the manual for the Utilitech KLH075 0.75 HP submersible pump on the product site: http://www.lowes.com/pd_240035-84862-KLH075_0__?productId=3880627 . Click on the Info & Guides tab. The direct link to the guide is http://pdf.lowes.com/installationguides/717301122392_install.pdf . This is labeled an installation manual. The operating instructions start on page 6.
    I hope this helps.
    Mar 24, 2016 | Plumbing
    .where can i purchase a replacement housing for my pump
    How about where you bought pump?
    Utilitech is a lowes brand, isn't it?
    Apr 14, 2015 | Utilitech 2-HP Irrigation Pump UTP20P1
    How do I change the bulb of the 6V Eveready Lantern if bulb won't come out
    Drop a couple of drops of WD 40 on the bulb retaining ring. Let site overnight and in the morning it will easily unscrew. Note: be sure you use only a couple of drops as you don't want to get it on the reflective lense
    Sep 27, 2014 | Energizer Eveready Utility Lantern Uses 6V...
    Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
    Timer is probably wired incorrectly.
    Copy following links for correct wiring, and larger instructions.
    I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
    http://waterheatertimer.org/How-to-set-timers.html
    http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
    Jul 31, 2012 | Hardware & Accessories
    I just bought a 35 w halogen bulb from lowes for my GE truetemp profile JKP56 built in oven. I just spoke to a GE rep who sells the bulbs and he said the bulb has no replacement numbers so I don't...
    If the bulb you bought from Lowes is a 35 watt bulb and it screws in, then it will work just fine.
    Appliance parts people love to sell you the "one" specific for your model because most of the time it is more profitable for them.
    Good Luck!
    Joey
    Jun 11, 2011 | GE Profile JKP56 Electric Double Oven
    I have bought a new 6volt battery for my dolphin but can't work out how to replace it.
    The bezel (the circular portion on the front of the flashlight that holds the bulb and lens) will unscrew. The old battery should slide right out.
    Hope this helps.
    Apr 07, 2011 | Energizer Eveready Utility Lantern Uses 6V...
    I have a GE Hurricane lantern model # 17000, how do I get it apart to put new batteries in it? There is an arrow on the bottom of it pointing to oppen one way and close the other, but nothing is budging.
    I have the same latern. Apply a bit more force to rotate the bottom lid in a counter-clockwise direction. There are threads on the inside of the botton lid. To replace the battery or bulb you go through the botton of the lattern.
    Jun 30, 2009 | Camping, Backpacking & Hiking
    Battery won't charge on 1million candlelight spotlight pml9000
    Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech.
    Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.
    Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit.
    Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.
    Repeat the process in reverse to install the new battery.
    Mar 21, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
    Camping, Backpacking & Hiking Logo
    726 people viewed this question
    Top Camping, Backpacking & Hiking Experts
    Tom Chichester
    ray gallant
    Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
