Question about Cell Phones
See below flip phone opening and closing mechanism broken. how do you get at this part?
  • 716 Answers
You Use A Small Flat Head Screwdriver And GENTLY Pry Apart The Edge On The Left It Will Pop Out. The Left Inside That is. Please Be Gentle.
Posted on Jan 05, 2009
My p990i phone the fip is broken and it is remained as if the flip is closed and i cannot use the other functions.......how can i flip open if the flip is broken.....
You need to dismantle the back panel and unscrewing 6 screw using a T6 precision screw driver to be able to release the front panel,but be careful cause the keypad flex connector is attach on the board interface and be careful cause touchscreen and LCD is also connected. On the upper panel,remove the keypad panel by inserting a flat screw driver on each side at the bottom of the front panel.if done,remove the adhesive at the back of the keypad interface and you will see the keypad flex connector,if the parts is still ok,gently remove the flex cause it is fitted by a strong adhesive.the you can replace or if not put an adhesive on a broken part.
good luck....
Jun 20, 2011 | Sony Ericsson P990i Cell Phone
I cant open the driver side lock with key. Mechanic said plastic clip is broken can it be replaced?
The lock mechanism or latch may be jammed or seized for whatever reason and as long as it can be locked/unlocked and opened from inside without any problems than your linkage should not be restricted or causing the problem. Try some wd40 on the latch and with the door open flip the latch closed manually with your hand and try opening from outside and then inside if that fails several times and maybe that might free it up maybe not. Yes 99.99% of anything can be fixed as long as it's not beyond repairing
Apr 28, 2011 | 1990 Nissan 300ZX
I HAVE CHANGED BROKEN FLAP 2 MONTHS AGO BUT THE FUNCTION OF OPERATE SYSTEM AFTER CLOSE THE FLAP CANT WORK PROPERLY, SO PLEASE TELL ME WHAT CAN I DO?
Was the flap changed by a techician ?
I have played with my 1200 and thus
know the flap hinge area has two special aspects :
(a) embedded-into-hinge-on-one-side, a spring loaded mechanism, for the firm open-close action.
(b) a small circular magnet embedded within the hinge framework (this magnet working from the right location should be essential to trigger the answer-when-flip-open or disconnect-when-flip-is-closed systems).
So your problem could be due to one or both of these things not being (re)installed correctly.
Good Luck.
fixya[at]technife[dot]com
Nov 05, 2010 | Motorola Mobility A1200
My soap cap remains in the closed position at all times. The clasp mechanism works fine, if I cycle through with the door open I can see and hear the catch release when it should. But the door remains...
there is a little spring in there that flips the door open, just take the screws off of the side of the door, you'll see the broken spring by the door, make sure power is off to dishwasher
Oct 19, 2010 | GE Nautilus 24" Built-in Dishwasher
Samsung juke broken
you may have broke the spring it is fixable but it may cost a pretty penny if your not doin it yourself carefully take the phone apart there ar screw behind the battery and look just inside so if anythings broken if so take it to verizon so they can get you that part
Apr 21, 2009 | Verizon Communications Samsung Juke Cell...
Disable v-cast key
With the phone closed, hold down the multi-function button on the lower-right side of the phone for a few seconds; that will lock all of the buttons on your phone until you either a) open the phone, or b) hold down the same button for another few seconds to unlock the keys.
To the best of my knowledge, there's no way to set the button to ALWAYS be disabled when closed; you have to lock it every time you close the phone.
NOTE: Locking your keys can create another problem, at least on my phone, where I've disabled the option to anser a call by flipping it open (I prefer the option to view the caller and ignore it if it's not a priority). When I receive a call with the phone locked, I have to wait a few seconds after flipping the phone open before pressing the "answer" key; if I answer too soon after flipping it open, the phone tends to lock up for about 30 seconds, which obviously kills the call.
Apr 07, 2009 | 2007 Toyota Avalon
Broken flip
all you need to do is take the flip off and try putting the flip on at a different angle, keep trying it and it'll work eventually, cus the little atachment thing is a square so there arent many ways it can be attached!
Feb 05, 2009 | Sony Ericsson W350i Cell Phone
LCD has no light neither does outside LCD
Hi Robin I am sure 100% that your LCD Cable has broken. That is the common problem for most Flip cell phones because the LCD cable is connected one side on one end of the flip and the other end to the connector under the board below the keypad. Therefore, several open and close times the flip will cause the cable is broken one day. I has showed it common on most Motorola V-series phones and all other models so your are not an exception. Now, the only solution is purchased the new LCD cable and replace it.. If yo can provide me your phone model, I can send you the link to show you how to disassemble you r phone and how to replace it. I hope my repair list has your phone model. If you can still dial the number and still can receive a call, I can be 100% sure you need to only replace the LCD cable. Email me at joe_dao2003@yahoo.com so I can send you the instruction.
Mar 05, 2007 | Audiovox CDM8910WW
Back light wont turn on
the flex cables broken or lose in the board and If iots cracked Im not sure if you can replace it as i donr know where to get the part unless your provider can get them or has a broken phone you can take one out of. Good Luck
Apr 17, 2006 | Nextel i860
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
