Question about Tivoli PAL Radio
Tivoli pal radio won't play
Won't play
3 Suggested Answers
TOLhamRadio
  • 509 Answers
SOURCE: antenna on radio broke
Radio Shack can get you an antenna, or a long wire (or wire coat hanger actually works too)
Posted on Aug 21, 2009
SOURCE: My Tivoli Pal radio casing has a sticky feel on
Just cleaned mine this morning because it was so ridiculously sticky and dirty with great success with nail polish remover and cotton pads. Read this solution posted elsewhere but was worried about ruining the finish, and there are warnings on the bottle about not using it on plastics......but tried a bit on the back. Went very well and with a load of pads and alot of scrubbing, it came completely clean! No sticky residue left, no discolouration. Looks brand new!
Posted on Jul 19, 2012
Transformer to old PAL Tivoli been eaten by rats. Where to find another for this old model
Try radio shack in States, Maplin in the UKand other similar retailers elsewhere. Also, if you can identify it try ebay, they carry a lot of these parts
May 30, 2015 | Tivoli (PAL) AM/FM Radio
Tip
Tivoli PAL volume problems
I posted this tip elsewhere but the FixYa site is, shall we say, challenging.<br /> After years of use my Tivoli PAL started having volume problems. The audio began popping, volume changed erratically, static, booming, almost feedback sounds.<br /> In my case, and others as well, I've gleaned, the problem was the volume potentiometer. Apparently it oxidizes over time and the poor electrical contact is the reason for the erractic audio.<br /> I'm not an electrical repair kind of guy, so this isn't pretty.<br /> The volume and frequency controllers are secured to the knobs with metal collars. I pried the collars loose and got the horizontal board off, I sprayed Stabilant 22 into the volume pot. There are other electrical contact cleaners as well.<br /> Put it all back together. Let the flud dry. Good as new.<br /> Good luck.
on Apr 27, 2011 | Tivoli PAL Radio
Pal speaker
you should read the catalogue.
Mar 18, 2013 | Tivoli (PAL) AM/FM Radio
Tivoly pal spare parts
i think it need parallel circuit.
Mar 17, 2013 | Tivoli Audio Players & Recorders
Bought a used iPal and it only came with a european compatible plug. I bought a US converter. Plugged it in and can't make sense of it. The radio doesn't work. When off, there's no green light....
If the radio has a European-style plug, it's probably expecting 220-volt power since that's their standard. If you got a plug adapter but not a voltage converter, the radio won't work because the line voltage is too low.
Check the radio for a ratings label which will tell you for sure what the radio expects. There may be a selector switch on the back which will let the radio work on our line voltage. Otherwise you'll need to purchase a voltage converter to use the radio.
Jun 20, 2011 | Tivoli (PAL) AM/FM Radio
Radio will not play when turned on unplugged, but will play via battery when plugged in to powerpack,, turned on, then unplugged.
I have the same problem with 2 Pal radio, I'm trying to find a solution, i think the trouble is in the switch to turn it on/off which has a bad electrical contact, I will tell you if I can find a solution. Phil
Apr 17, 2011 | Tivoli (PAL) AM/FM Radio
Antenna on radio broke
Jan 06, 2009 | Tivoli (PAL) AM/FM Radio
Tivoli Radio,
Does your radio have a sleep button or option? If so, check to make sure that you did not set it on accident or with out knowing. Or if it has batteries, check them to make sure they aren't dead or mixed with old or new.
Oct 21, 2008 | Tivoli Cherry Top-Firing Stereo Speaker -...
Tivoli iPal
send it back! I have had 2 fail this way.
Nov 13, 2007 | Tivoli (PAL) AM/FM Radio
Tivoli PAL Radio Logo
Top Tivoli Audio Players & Recorders Experts
Electro Med Services...
Are you a Tivoli Audio Player and Recorder Expert? Answer questions, earn points and help others
