Good evening....I own a model T43 Lenovo laptop. . Contiue to have pop up window telling me following: "Power Surge on Hub Port. A USB device has exceeded the power limits of its hub port. For assistance in solving this problem click this message." I have nothing in the USB port and have clicked the message and followed instructions to reset....window will not go away. What can be done to get rid of the window? Thanks, Steve Bowman
    President:
  • 846 Answers
My friend had that happen to his laptop after something had shorted out in a USB port.
Any additional info would be great, such as things you did with the PC for prior to this problem.
Posted on Jan 04, 2009
Power surge on hub port i dont have a usb device instaled.. and there is no usb2.0 in my device manager.. how to solve it..
What makes you think the USB hub took a surge? If the surge got into your computer the Driver will not fix the interface if the circuit (inside your computer) got blown out.
It does not hurt to try the driver, you can download the driver from IBM directly. Here is the link;
http://www-307.ibm.com/pc/support/site.wss/product.do?doctypeind=9&template=/productselection/landingpages/downloadsDriversLandingPage.vm&sitestyle=lenovo
Dec 13, 2010 | IBM ThinkPad T43 Notebook
Power Surge error message
can you please detail the exact name and model of your hub..?
Thank you
May 13, 2008 | HP Pavilion dv4000 Notebook
I Have Toshiba Satellite Laptop, i am continuously getting pop up message " Power Surge On Hub Port " A USB device has exceeded the power limits of its hub port. Please help how to stop this pop...
Remember the help below is only a fix for seeing the error message not for overdrawing the port.
To stop overdrawing the port you need to either use a power supply or a double USB cable.
To prevent seeing the USB Power Surge alert message, complete the following steps:
Click on START, Click on CONTROL PANEL, Double-click on the SYSTEM icon, Click on the HARDWARE tab, Click the DEVICE MANAGER button, Click the "+" next to Universal Serial Bus Controllers to expand the selection.,Right-click and select PROPERTIES on the Intel® USB UNIVERSAL HOST CONTROLLER (not the USB Root Hub),Click the ADVANCED Tab, Check the box that says: "Don't tell me about USB errors"
Nov 29, 2010 | Amstron Toshiba Satellite A80 Laptop AC...
I am getting error power surge on hub port in windows xp pro
your usb hub is exceeding the power limit or you are attaching a device that is extracting more more , use a USB 2.0 port HUB with a power adapter if you are attaching more devices on hub
Sep 24, 2009 | Computers & Internet
Hp pavilion dv4000 usb port can't use
This error occures when a USB device draws more power than the USB port can supply.
To fix this problem, purchase a powered USB hub. Power up the hub and connect it to the laptop's USB port and then plug the USB device into the powered USB hub.
May 05, 2009 | HP Pavilion dv4000 Notebook
Some USB devices draw excessive power from the USB port, especially USB scanners. When this happens you need a powered USB hub, connect this to your computer's USB port and connect the USB device into the powered USB hub, you should not have any further error power surge problems.
Apr 27, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge message
Problem :Overvoltage on USB hub port
Solution: Look carefully at that same port and you will four gold pins make sure they are NOT touching each other..
Apr 16, 2009 | Computers & Internet
Error power surge on hub port
Some USB devices draw too much current from the computer's USB port and you get an exceed power error message.
To get around this problem, get a powered USB hub and connect it to the Computer's USB port and then connect the troublesome USB device into the powered USB hub.
Apr 09, 2009 | Lenovo 3000 N500 Notebook
That series of laptop has a problem with it's battery which causes malfunction...
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=BATT-LENOVO
Moreover, make sure you have current BIOS and driver updates for you laptop, not all manufactures offer complete firmware updates like Lenovo; take advantage of it.
http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-58597
Nov 27, 2008 | IBM ThinkPad T43 Notebook
I guess that this could be your error message:
"Error message when you wake up a Windows XP-based computer from hibernation or from standby: "Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port"
If it is the case, please try below solution:
SYMPTOMS
When you wake up a Microsoft Windows XP-based computer from hibernation or from standby, you may receive the following error message:
Power Surge on Hub Port: A USB Device has exceeded the power limits of its hub port. This error message is displayed even if there are no USB devices connected to the computer.   WORKAROUND loadTOCNode(1, 'workaround'); To work around this issue, disable the USB 2.0-enhanced host controller.
Note When you disable the USB 2.0-enhanced host controller, you lose USB 2.0 functionality. That is, you revert to USB 1.1 functionality.
To disable the USB 2.0-enhanced host controller, follow these steps: 1. Right-click My Computer, and then click Manage. 2. Under Computer Management (Local), click Device Manager. 3. In the Device Manager pane, expand Universal Serial Bus controllers. 4. Right-click the USB 2.0-enhanced host controller, and then click Disable.
Note The name of the USB 2.0-enhanced host controller may vary. 5. When you receive the confirmation message, click Yes. 6.
Close Device Manager.
I hope that this should resolve the issue for you.
Please let me know the result.
you can mail me at thumuvikram@rediffmail.com for any further assistance on this issue.
I'll be glad to help you.
Oct 18, 2007 | IBM ThinkPad T43 Notebook
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
