Question about Kenmore 24032\24036 Top Load Washer
Agitator does not spin.
Clothes are wet after cycle is finished.
Kenmore 80 seriers -6 yrs.old.
  • 198 Answers
The clutch needs replacing. The gearcase needs to be removed and the centrifugal clutch is mounted on the gearcase.
Posted on Jan 05, 2009
Kenmore 80 Series washing machine agitator is not moving much
sounds like you motor coupling may have broken, part is about $20
Jan 17, 2010 | Washing Machines
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
Spin cycle is not working right,
This is a problem in your transmission. Not Good!
May 18, 2009 | Washing Machines
Kenmore 80 series washer clothes are still dripping wet
Turn timer to rinse cycle. let fill up and agitate. when it stops agitating it should pause then start to pump water out. After about 2 minutes it should pause for 3-5 seconds then start again and spin. If it starts the first time and never stops it will just continue to pump but no spin. The 3-5 second pause allows the transmission to shift to spin. If it does not do this the problem is your timer. You may need to do this a few times to verify the problem.
If that is not the problem it is likely that you need a new clutch. You will need a technician to install a new clutch for you
May 16, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series only 3 yrs old, won't, spin and the agitator appears to be stripped
your agitator dogs are stripped there about $10.00,remove cap to replace. easy,need 1/2 to 3/8 adapter or 7/16 socket depending on model. and your coupler is broken about $20.00 its what runs yous washer its like your belt under neath between motor and transmission , less cloths max water will stop it from happening again
Nov 09, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer model series 23711 pn 10182371800
nurse annie give me your model number and approx age .and will be happy to advise mike give me the age of your washer as you might not have the same problem
Jan 14, 2008 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
108 people viewed this question
Sal De
 Brian Main
Brian Main
