Question about Altec Lansing (AHS-322) Headset
My mic is broken, so I tried to fix the headset by cutting the wires. Then I striped the wires. But I noticed that there were only 4 wires, yet there were 5 places to solder. Looking at the part, There are 3 connected wires that I have not cut off yet and there is 1 wire broken. That leaves 1 wire and 2 soldering spots unaccounted for. When I look at the 2 soldering places, they both have a small strand there, so I can not tell which one the wire broke off of. I tried searching online to find the blueprint of Altec Lansing AHS322, but I had no luck. I just need to see where the wires go. Does anyone have any ideas?
  • bob bob May 22, 2007
    This is the picture.
    Problem Solver:
  • 4 Answers
What i've done in similar situations is basically trail and error. You've got two spots for one wire, try them both out.
Some companies will use a generic piece for all their similar products. Maybe one of Altec's other headsets uses that 5th spot for something. Just try them both out and see what happens. Just dont solder them right away, stick them on with some electrical tape or something to save yourself some time. Then when you're sure you can solder away.
Posted on Jan 07, 2008
How to connect the mono headset
If you're trying to convert a STEREO output to feed MONO headphones, the best is to use a resistive splitter network as shown.
There are adapters out there that simply short the two L/R signals from the stereo, but you run a risk of overloading the output stages of your amp.
The resistive network places a current-limiting resistor on each stereo output in series, so eliminating shorts and overload.
If using a mic-enabled headset, the jack has 4 connectors, the back one nearest the plastic case being for MIC.
Mono: Tip, Sleeve.
Stereo: Tip, Ring, Sleeve.
Incl Mic: Tip, Ring, Sleeve, Mic.
Tip is Left, usually Green.
Ring is Right, usually Red.
Sleeve is common GND, usually bare copper or black.
Mic can vary according to manufacturer. Seen striped colors, white, red, purple.
These thin shellac-coated wires are sometimes difficult to solder, so here are some tips:
Using a combination of fine emery paper, craft-knife and flame, try to burn/scrape/clean about 5 mm from each wire.
Copper should be shiny without shellac color showing at end.
To burn the shellac off, best hold the wire 5 mm or so back with pliers or fingers. The shellac varnish may ignite the whole wire if you don't block it first.
Diagrams and drawings should help to clarify the text.
872c3844-2630-46b9-86e4-869f044bad22.pngstereo plug connection -amwsxm2bpytpyryuvmyoeb4d-4-3.png
Oct 12, 2017 | Radio Communications
Wires broken plantronics .audio 628
Strip the wires back further. There make be more broken wires. Put all of the colors together and include the bare copper wire. That wire is the ground and there will be poor performance or no performance if the headset is not wired properly.
Oct 20, 2017 | Plantronics audio 628 Stereo Usb Headset...
How to sync afterglow ax.4 headset with xbox 360
how do tou fix the after glow ax.4.the problem whith it is that my freinds can hear me but i have to un plug it to hear them
Aug 03, 2012 | Microsoft Xbox 360 Afterglow Ax.4 red...
I have a telex airmen 850. I tried calling to see if it was still under warranty- with no help. It's $200 flat rate fee to ship it there... Is there somewhere else I can send it to be fixed? It was working...
Don't know why answers for different type of headsets shown up on a question about the Telex 850. Probably there is an issue with the cord. The cord has two shielded "double" wires on each pair. The ones for the mic are "white" and "light blue". May be one is cut preventing the mic to work. Look around for a local avionics shop, they should be able to fix it. Hope this helps ;)
Apr 19, 2011 | Telex Radio Communications
Most people I try to talk to using the bluetooth complain that they can't hear me even whn I almost shout.
It could be that your mic is clogged up or dirty, or that you have a loose or broken wire. No way to know. If you try to clean the mic with a damp cloth, do not run it under water. Surgery drinks will leave crystals in the mic, which do not allow sound through. If it still won't work you may need to replace the headset.
Good luck from Headsets Direct!
Sep 28, 2010 | Plantronics Voyager 500A Deskphone Adapter...
I need the pinout for the Avaya 2400 series telephone headset RJ-11 Jack.
I noticed that Avaya headset is different from the Avaya handset or any other standard headset: The outer two pins are switched.
Avaya-Headset-pinning is like this:
Look to the RJ11 and turn it until you see leads from top and from front, then from left to right you look at
1) mic 5V
2) speak
3) speak
4) mic gnd
RJ11 of Avaya-handset and any standard headset/handset from the supermarket:
1) mic gnd
2) speak
3) speak
4) mic 5V
Hope that helps.
Stefan
Nov 24, 2009 | Avaya 2420 Corded Phone
Motorola mic no longer works. Any fixes?
This is probably a broken wire inside. the microphone piece moves back and forth to turn this unit off and on and the wires have broken because of it. there is a similiar problem with the H800 as the mic extends in and out to turn it on and off.
Nov 07, 2009 | Motorola Mobility H710 Bluetooth Headset
My headset for my ps2 broke i can hear but i can't talk
the mic cable is probably broken its very simple 2 wires and can be fixed on your own by useing a soldering iron for example.
Apr 16, 2008 | Logitech 250 Headset
My mic aint working
most likely a broken wire inside. it's dead imo.
Apr 14, 2008 | Koss SB45 Professional Headset
Radio Communications Logo
270 people viewed this question
Top Altec Lansing Radio Communications Experts
Michial Gueffroy
Jose Ma DM.
Jose Ma DM.
Are you an Altec Lansing Radio Communication Expert? Answer questions, earn points and help others
