Question about Westinghouse 40" Class 1080p 60hz LCD HDTV - Black CW40T8GW
Wall mount does the westinhghouse 40" 1080p lcd hdtv cw40t8gw have wall mounting capabilities? bought one and none of the screws fit?
SOURCE: wall mounting my t.v.
cheak for clip
Posted on Feb 19, 2008
  • 97 Answers
SOURCE: Wall mounting
According to the manufacturer (and numerous websites selling this TV) there is no provision to mount this TV by normal industry standards. It should state clearly on the box or manual what the mounting standard is if it is mountable, and in this case its not. Sorry.
Posted on Mar 23, 2008
SOURCE: removing base from tv
I researched this problem on the net and found the solution. Someone on one of the posts said the base can be removed by taking out four screws - all from the back of the TV. One screw is the one closest to the power plug, the next screw is beside it, the remaining two screws are the corresponding screws on the opposite side of the base panel (still on the back of the TV). Once these screws are removed the base comes off including the mounting bolt and the rectangular shaped plastic panel. There are no electronics or any components inside the base panel, only the bolt and plastic base which are held on by the four aforementioned screws. It was very easy to remove!
Posted on Feb 25, 2009
falter
  • 245 Answers
SOURCE: How to wall mount
u have to get a wall braked to do this.......go to a store where they sell televisons and they will help u with ur problem.....also it eill have a installation guide enclosed in the carton
Posted on Nov 28, 2009
westytech
  • 120 Answers
SOURCE: when installing a wall mount on a westinghouse
Depending on the model you have you might need ether the inverter board or you might actually need the power board. You are likely to find both these parts at www.shopjimmy.com or by emailing parts@wde.com, you should always have a certified technician fix your TV but it doesn't take a rocket scientist to change ether of these boards.
Posted on Jan 26, 2010
What screw/bolt size is it to wall mount?
Contact the authorized dealer for more details about the sizes of hardware. Electro help
Oct 16, 2014 | Televison & Video
Size of wall mount for GPX LED HDTV
Not sure what you are asking. Are you looking for the screw for the attaching the mount to the TV or the mount to the wall.
If you are looking for the screw size for the back of the TV, it could be metric size M6 or M8. Just be careful of the length. Too long and you will ruin the TV. Maybe google the TV model and it might show in the owner manual the exact screw to use.
Apr 18, 2014 | LG 42LG50 42 in. LCD HDTV
Will it fit a universal fit wall mount
Most of these will. You san see the screw mounts on the back of the set and compare them the wall mount spand holes. I have mounted 19" RCA LCD Panels so I have got to believe this 32" should be able to mount on most universal wall mounts.
I hope this helps,
Skyassoc
Dec 11, 2010 | RCA L32HD31 32 in. LCD HDTV
How do i mount tv to wall
What type of wall mount would I need for a 32in Emerson LCD320EM9 HDTV LCD. And how do I mount it to the back of the TV. TV on back only has two holes for screws?
Nov 26, 2010 | Emerson LC320EM9 32 in. LCD HDTV
VESA Screws
I went to Lowes and found some 4mm .7 screws, 25mm long, and they worked like a champ. (get the lock washers too)
Apparently, most mounts include only 5mm and larger screws
Mar 29, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
No screws to mount AKAI LCT3701AD LCD TV.
Hi i bought mine at home depot for a few dollars they were very helpfull there and they worked great...
Feb 03, 2010 | Akai LCT3701AD 37 in. LCD Television
Wall mount screws don't fit in my proscan 32lb30qd
The PEERLESS kit should be supplying the Metric M4, M5, M6 to cover most of the screws used for mounting the mounting plate to the back of the TV.
Dec 18, 2009 | Proscan 32LB30QD 32 in. LCD TV
Can the 19av500u be mounted on the wall
yes to find proper mount google 19av500u wall mount PLEASE make sure it is screwed into a 2-by-4 in wall
Sep 02, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Sony Bravia 40" LCD TV Stand
There is a slotted area on the bottom of the unit and the bracket on the stand slides over top of it. There should have been four screws that came with the packaging that fit in the four locations in the lower center of the cabinet back that secures the unit to the Stand.
I hope this helps,
Skyassoc
Aug 25, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
42'' LCD PLTV-4250 MOUNTING
The universal mounts generally have a selection of screws that are to fit different makes and models of tvs.
If you bought the appropriate size mount for the size of your TV, there should be mounting holes that match your TV, and screws that will secure it.
I have not seen any mounts that use more than four.
Apr 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Westinghouse 40" Class 1080p 60hz LCD HDTV - Black CW40T8GW Logo
89 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
