Question about Sansui Televison & Video
I have a Sansui SLED1953W Series A TV and on 1 tv I can't figure out how to get the digital stations (they will record but I can't just watch them?) and the other 1 has a WII attached. I can hear the sound but there isn't a picture?
  • 4102 Answers
SOURCE: 42 inch LG Plasma TV Lost Picture
Hi it sounds like it has had an elctric fault like a resistor failing.
The click you heard would be a internal switch that cuts off the elctric supply to the screen to stop furthe damage hapening.
It could even be something simple like a bad solder and in that case will need locating and resoldering.
How old is the telly and how often is it used.
When you switch it off leave it off for about an hour then try again if you have allready done this then it probably is a blown resistor are you sure nothing has been pressed on controll have you tried seeing if you can acess the menu screen via the remote and see if that comes up on the screen let me know ok
Posted on Dec 14, 2007
  • 98 Answers
SOURCE: No picture screen is blue
If you use RF cable, need to change brand new cable.
But, before that need chck the status of cable connector.
Posted on Feb 09, 2009
  • 90 Answers
SOURCE: no sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Posted on Feb 24, 2009
  • 20 Answers
SOURCE: Cannot get tv to scan digital stations. I have a
test test 18:30
test test test 18:31s rthsr thsty 3456234
Posted on Jul 07, 2009
  • 4 Answers
SOURCE: Loss of Digital Shows??
Hi, I am assuming this has not happened before? When digital pictures freeze or go missing it can commonly be because the signal strength you are picking up from your antenna is not strong enough. If the signal becomes too weak it won't go fuzzy like analogue, it will just jump or cut out completely. If your analogue signal is also poor this supports the theory that you are not receiving a strong signal from your antenna. On your digital tuners there is often a way to see the signal strength you are receiving for the channel (possibly on an info button or in the set up menu). See if you can find this to confirm your signal strength. If it is low and this hasn't happened before I suggest you check your cables, connection, and antenna to make sure a lead or connection has not detached, or damage to the antenna etc. Good luck.
Posted on Oct 26, 2009
Panasonic troubleshooting
I guess you mean a Set Top Box to convert digital TV transmission to old analog TV. Choose the correct video format for your screen.
Ah... Perhaps Your recording at an old standard & passing it to a modern TV or HD TV with the digital output from 1080 HD to 720 or lower still.
OR
Get a Digital Hard Drive recorder.....
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
Main Features:
DVB-T Twin Digital Turners
DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
2.5" Sata Hard disk: 500GB
Time Shift Function (Pause live TV)
HDMI Digital Output
Digital Audio Output
CVBS/YPbPr/SPDIF connectors
Supports TV formats 4:3 and 16:9
Electronic Program Guide (EPG) up to 7 days in advance
EPG searching and auto download
Recorded program edit
Parental Control
Copy files from internal HDD to external HDD
Built-in WiFi
Network Playback
USB 2.0 Interface
Aug 14, 2014 | Panasonic Televison & Video
Tv firmware updates
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 09, 2014 | Sansui Orion JVC LED TV Remote Control...
TV SANSUI SLED1953W
Check its main digital board. It might need replacement. If you wish to get more details, check the site linked below. Pull up older posts there. Check the site with patience, as it has over 2400 posts now. All are related to electronic equipment repair help. If you search the site in Timeslide option, which can be selected from the drop down list at the top left of the display window, it will be easy to locate the related post. You can also do a search by type in the brand name to your device into its search box at the top right of display window.http://electronicshelponline.blogspot.com/
May 01, 2013 | Televison & Video
How to record to my Sony SLV830 VCR from Sony Bravia 32" after digital switchover
You can't really record from the TV while watching something else. The only way to do that is to have two tuners. What you would need to do is get another converter box and connect that to the VCR, via the second VCR socket. But as you have a Satellite box, you will need to find a scart switching box like the one shown below (try Amazon for them).
This will allow you to connect all your items to the one TV.
Mar 18, 2017 | Sony Bravia S-series Kdl-32s3000 32-inch...
When I turned my Sansui 19
Chk all cabling for a short at back. If disconnecting cables turn off tv 1st.
Sep 05, 2012 | Sansui 19 in. LCD TV
Can I watch tv with the timer on the dvd recorder turned on?
Hook up the cable wire that comes directly from the wall to the dvd recorder's in connection, then get a 3 ft cable cord and connect from the out of the dvd recorder to the in on the tv. You should be able to set the dvd recorder channel and timer and leave it off. you then should be able to have your tv on and watch any station but to watch the tv with dvd recorder on, your tv should be set to either channel 3 or 4 depending on the switch on back of dvd recorder. I hope this solves your problem. Foxpaw13
Jun 15, 2009 | Panasonic DMR-EZ37VS
How to record ditigally on old comb tv/vhs
If you have the box hooked up to your 1996 combo turn or tune on channel 3 if the converter box is selected to channel 3 you should get all your digital reception from the box to your tv/vcr. Select what you want to watch or tape on the box, what you see on your tv will record to your vcr when you select record.
Jan 14, 2009 | Televison & Video
Switch to DTV -- how can I watch one program and record another
Unless the box has two digital tuners in it then I believe what you are trying to do is impossible. Find out first if it does have two digital tuners.
Jan 12, 2009 | Televison & Video
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
150 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
