Question about Samsung DVD-VR320 DVD Recorder/VCR
I get an error code 0207
When I insert a disc to record from vhs to dvd (not copyrighted) my system tells me my disc can neither be played nor recorded......
please help!
  • Anonymous Feb 14, 2009
    I am getting the same problem, have you found a solution?
  • sjsspirit Apr 03, 2009
    I have the same problem with some DVDs but got a Maxell -R DVD to burn a few months ago. Will try that brand again. Tried to see if Samsung is brand specific or something but didn't see that on the specs. Good luck! J
SOURCE: DVD player recorder won't read or play any disc
This just worked for me. Don't know how long it will last though. I found it on this webpage
http://forum.ecoustics.com/bbs/messages/15118/130292.html
To do a reset:
On the remote control press the SETUP button,
Press the right key on the remote 3 times,
The Preference page will show up,
Press the down arrow five time to highlight
"default", hit right arrow to highlight "reset"
Press enter to reset. Turn off/on machine, etc.
Posted on Feb 14, 2008
SOURCE: recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Posted on Apr 05, 2008
SOURCE: SAMSUNG DVD R120 error EC:0207
Search for the latest firmware for Samsung R120 and download it, burn it to a disc, then put it in the player. Get the latest firmware and you'll be fine.
Posted on Apr 18, 2008
jerryg50
  • 1673 Answers
SOURCE: CAN NOT RECORD COPYRIGHT VHS
This is the protection for the source material. Commercialy distributed media is not supposed to be copied. This is under copyright law.
What you can do to be legal, is to buy a second copy.
Jerry G.
Posted on Jul 19, 2008
SOURCE: dubbing VHS to DVD
You have to go into the Home menu and select setup. At the bottom left there should be an icon that looks like a dvd disc. Select that and then go to finalize and select that to finalize the disc. After that is complete it should play on any dvd player. I had this problem and I got through to LG's customer service line and had them talk me through it. After I finalized the disc, it worked.
Posted on Feb 05, 2009
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
I put in my dvd on my magnavox blue ray player and it says disc error then something like disc not recorded for thins region code * 2 * 45 *
DVDs are recorded for three world regions (for copyright reasons and to match the electronic TV system also broadly in three world regions known as PAL, SECAM & NTSC)
You're likely in the USA as you refer to the Magnavox brand.
Your region is 1 and system NTSC.
Your machine is correctly telling you it can't play the disc because it's for Region 2 system PAL.
However, there are multi region players available, for a few dollars more, which play discs of any region or system.
Sep 20, 2011 | Audio Players & Recorders
Can record on DVD disc will not play on DVD player
Make sure the materials you're trying to record onto the DVD
is not Copyrighted. Try to record a normal TV program onto your
VHS, transfer it to your DVD and then play it. See if that will
work. A VHS movie is usually Copyrighted and Protected by
Macrovision. The picture output can be displayed on a TV set
for viewing but is scrambled black to a DVD Recorder.
Jul 16, 2011 | JVC DR-MV100B DVD Recorder/VCR
The machine will play some DVDs, but frequently
COPYRIGHT PROTECTION FOR DVD`S AND VHS TAPES RENDERS THE ZENITH XBR716 INTO USELESS JUNK. TOSS IT INTO THE TRASH BIN.
Jan 05, 2010 | Zenith XBR716
Have a samsung Samsung LE26A456C and a toshiba dvd recorder. Have set up telly fine, set up video to play fine but cannot record
What is it that you are trying to record? If you are trying to record a DVD you have purchased onto a DVD-R, you will almost always run into a problem because most purchased DVDs have copyright codes burned into them, making them unrecordable. Most VHS tapes have these copyright protection codes in them as wel. If you are trying to record a television show, and are unable to do so, make sure that the DVD that you are using is compatible with your burner. If your burner is set up to record only DVD-R, then you must use only the DVD-R discs. If your burner is set up to record only DVD+R, then you must use only the DVD+R discs. Some burners will record both the DVD-R and DVD+R. If you have the right discs for your burner, make sure that the discs are correctly formatted to be recorded. Also, make sure that if you are recording from a cable box or other input that you have the correct unput channel selected on the burner. If these suggestions don't work, then it could be the brand of DVD that you have purchased (i.e. Sony,Maxell,TDK,Fuji,etc.). Check your manual for acceptable brands. I hope this helps you out. Let me know if I can be of further assistance.
Sep 08, 2008 | Samsung Televison & Video
Panasonic DMR ES15, cannot record coywrighted vhs tapes onto dvd.
Try this:
If you have another VCR system (Master) you can connect it from the master to the Panasonic DMR ES15 (slave). Insert the copyrighted tape onto the master VCR system and insert a empty VHS tape on the slave system. In the slave, record from the master. When done, you can record from the videotape you have made from the master tape, to the DVD recorder.
If you still have problems, please contact the manufacturer of this model.
Aug 03, 2008 | Televison & Video
Recording from vhs to dvd
Jan 20, 2008 | Televison & Video
New Unit- Plays VHS - Records VHS - Plays C.D's - but ... ALL DVD's say
How old is your player?, has it ever played DVD's ?.
Try and avoid cleaning disc's.
Dec 04, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
I had exactly the same problem -- error message of "This disc can be neither played nor recorded. Please check the disk [EC:0207]" after the machine had been working fine for a year. I downloaded the latest firmware from the Samsung website, burned it to a CD-R disk (took three tries until the DVD Recorder recognized the disk -- worked when I used Rocio CD Creater software), then loaded the firmware updates to the DVD Recorder. On the Samsung website you can retrive the firmware update instructions as well. I had to perform the firmware upgrade several times until it successfully updated both the system firmware as well as the disk firmware. After successfully updating both, the Recorder now recognizes the DVD-R disks and I was able to resume recording. I have however, noted some choppiness with the playback of the newly recorded disks. Other than that, the firmware upgrade successfully resolved the problem.
Oct 29, 2007 | Samsung DVDR120 DVD Recorder
My dvd always shows "system error" and won't play commercial copyright dvds, only recorded ones.
I had the same problem with my recorder except that it wouldnt play any discs at all.. I finally unplugged the recorder and left it unplugged for 16 hours. Now it is fine. I am not getting any error messages.
Nov 23, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Samsung DVD-VR320 DVD Recorder/VCR Logo
161 people viewed this question
Henry  Thomas
Henry Thomas
