Question about Epson Stylus Photo R300 InkJet Printer
The new light cyan cartridge was not printing...I thought it may be faulty so purchased another which also did not work. I did 'clean print head ' several times followed by nozzle check. All other colours are working perfectly but lt cyan does not print any colour at all.
  • Barry S. Yorysh Jan 09, 2009
    I have the same problem. I tried swapping cart. but it would not print even then. I tried putting in an old cartridge and resetting the chip. That did not work either. I think it's time for a new non-epson printer.
Replace the other cartridges with either remanufactured or new Epson cartrdiges.
Posted on Jan 25, 2009
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
HP Officejet 6310 will not print cyan
The Cyan print head nozzle maybe blocked.
If deep cleaning does not fix it then you need a new print head.
The cost of a new print head is expensive and it maybe better to get a new printer.
Oct 15, 2012 | HP Officejet 6310 All-In-One InkJet...
My HP Officejet Pro K550 is not printing the cyan (blue) ink. It has a new cartridge. I've run print quality pages and configuration pages -- no cyan shows up. I cleaned the printheads and no c
Do a test print...
assuming you have done multiple print head cleans... if it fails to print ANY cyan, I'd guess the print head is dead... although to be honest im not an expert with this hp printer. if that is the case, it probably isnt worth repairing.
If it does print some cyan, just missing, you may be able to find info, sorry, I cant help you there, on accessing the service or maintenance mode and doing a higher level clean, if your printer supports that.
As a last option, disassembly and soaking the bottom of the print head in cleaning solution /water... overnight, without getting ANY water on any contacts, then re running print cleans.
good luck
in my exp, again, not with this printer, mind you, if a print head fails to print ANY ink for a given colour, the print head is usually faulty.
Hope this info helps
May 15, 2012 | HP OfficeJet Pro k550 Printer
Printing colour is wrong, colours come out pink. Nozzle check indicates cyan colour is not printing. I have carried out cleaning, deep cleaning. I've cleaned the print head and finally just replaced the...
> replaced the print head
Did you replace the tri-colour ink-cartridge, or did you replace the print-head mechanism?
Are you sure that the CYAN part of the ink-cartridge is not empty?
Mar 09, 2011 | Canon i9900 InkJet Photo Printer
Will not print cyan
The cyan print head may be blocked. Try several deep cleaning of the print head to see if it can clear the blocked cyan print nozzles. Also check the cyan cartridge, make sure it is not empty.
If none of this works then the print head needs to be replaced. NOTE the print head is not a cheap item, you may consider putting the money towards a new and better printer.
Nov 13, 2010 | Canon I960 InkJet Photo Printer
Hp officejet v40. new cartridge but missing blue when printing
Sounds like your cyan print head is clogged. You can try to get it flowing yourself by rubbing the print head with a wet paper towel. If you press the print head on a dry paper towel you should see three distinct lines of color. If you still don't see the cyan, try letting the print head rest on the wet paper towel on a surface that ink can be cleaned up from or one you don't care about staining. If the cyan still won't flow, you should go back to where you purchased it and return it for a new one.
Jan 12, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
My printer has stopped printing from the cyan ink
Hi, did you let the ink cartridge dry out completely before inserting a new cyan cartridge???
If this is the case you may have a bit of trouble getting the ink through the printhead...you have to persevere with deep cleaning and/or head cleaning...
if that does not work you may need a new printhead...which is usually dearer than a new printer...
I would also take the printhead out and clean the contacts with Isopropol alcohol...do not get finger prints on the contacts...that will stop it very quickly...
just a thought...did you remove the sealing tape over the airholes and bottom feeder hole on the cartridge???
if the airholes are sealed the cartridge pulls a vacuum and the ink will not flow...
hope this helps you...
cheers
haitchhcee
Dec 06, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
After cyan ran out, installed new cartrige. Printer produced everything colored blue as red. Purchased new cyan cartrige and the problem recurred.
The problem seems from your new cyan cartridge.
It doesnt print cyan ink.
Try to clean print head and test print for each color
from the utility menu
Sep 09, 2009 | Epson Stylus CX6000 All-In-One InkJet...
One of the 3 colors will not print
This problem may be due to blocked nozzles, faulty cartridges or a faulty print head or main board. The first thing to do is eliminate the cartridges. Do a proper cartridge change on both printers, but swap the yellow and cyan (blue) cartridges between printers rather than fit new ones. If either (or both) of the missing colours now appear, you know the problem is the cartridges; replace it (or them) with new ones.
For example, take printer A, with yellow missing. Do a cartridge change procedure on printer A, but instead of fitting a new yellow cartridge, put in the yellow cartridge from printer B (since you know this yellow cartridge works). If yellow now prints in printer A, you know the cartridge you took out is faulty - put a new yellow in printer B, and throw away the cartridge you removed from printer A. Repeat this process for printer B with the Cyan cartridge.
For one or both printers where the above does not solve the problem, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head across fully into its parking position on the right, so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean or two. If the missing colours now start to appear, try another clean or two. If still not perfect, leave for 24 hours and try again. If still nothing, report back.
Feb 08, 2009 | Epson Stylus C62 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
