Question about Gateway MT6705 Notebook
What bios settings work best with mt6705/windows 7
  • joecoolvette
    joecoolvette Nov 05, 2012
    1) Normal or regular settings, Not optimized. 2) Problems? What is going on? Post back in a Comment.
  • Gateway Master
  • 27,725 Answers
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Posted on Nov 07, 2012
I have a hp altec 255 laptop .when I put in reinstall disk .windows 7 .computer will not set it up to take program .enyway to get a new hp recovery and applications/drivers reboot disk
please check bios boot type I sujspect it may be booting for UEFI rather than for legacy boot. Windows 8 will boot on UEFI boot type but windows 7 will need legacy bios type of boot up settings in bios
see
http://blogs.technet.com/b/askcore/archive/2011/05/31/installing-windows-7-on-uefi-based-computer.aspx
Dec 21, 2014 | HP Computers & Internet
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
How to restore factory setting on gateway model mt6705
Step 1:
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate. Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files. It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen Click the "Start" icon in the lower-left corner of your Windows 7 home screen. Click "All Programs" in the Start menu, then click "Gateway". Click "Gateway Recovery Management" to open the Gateway Recovery Management program. Click the "Restore" header, then click "Restore System To Factory Default". Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes". Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart. When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes. Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer. Your computer will reboot. After the computer restarts you will need to configure Windows 7 with your personal preferences. b> Recover at Startup Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program. Click "Restore System From Factory Default". Click "Next" to begin the restoration process. The process could take anywhere between 30 and 90 minutes.
Feb 25, 2013 | Gateway MT6705 Notebook
Upgrade software from windows 7 starter to windows 7 ultimate need bios password
Strange. Shouldn't need BIOS password to install software. Be that as it may, the only person that is going to know that is the person who set it. None of the Major manufacturers actually set the BIOS password when they sell systems. If you have no way of finding out what it was set to by asking the previous owner your best chance to get it is to open the case after disconnecting the power and removing the BIOS or CMOS battery. This will rest the Bios to factory default.
Jun 16, 2011 | Computers & Internet
My keyboard is not working . after i upgrade my laptop to windows 7
The operating system does not have direct access to the keyboard, this is handled by a keyboard controller chip on the motherboard (so that it can be controlled by the BIOS). If the keyboard works before Windows 7 is loaded then there is no hardware fault. If the keyboard does not work at all, even before Windows is loaded then you need to check the connection of the keyboard to the motherboard. If it is a problem only within Windows 7 then try an external USB keyboard. If this works then there may be a driver problem.
There may also be some setting in the BIOS, so use an external keyboard if necessary and get into the BIOS to check all the settings there.
Check online for a BIOS update for your laptop.
Feb 24, 2011 | Compaq Keyboard
PCI Video wont work with Gigabyte GA-K8VM800M motherboard
hey try the removing cards.....
window 7 may took up it best when no such changes are around..
! Gb or 2 RAm is enough to get run your Win 7
and sound card is noot required untill you have 4 or more speakers
Feb 12, 2010 | Gigabyte GA-K8VM800M Motherboard
How to install windows 7 on Satellite A205-S5880
To install Windows 7 no need for RAID driver. If you face issues in installing Windows 7 disable RAID in BIOS, install Windows 7 and then install RAID driver.
How To Manually Upgrade from Vista to Windows 7 - Satellite A200/205:
http://cdgenp01.csd.toshiba.com/content/support/downloads/PSAF3U-PSAF6U-Win7UpgradeInstructions.pdf
Windows 7 Drivers page:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2060003&rpn=PSAE3U&modelFilter=A205-S5880&selCategory=3&selFamily=1073768663
Dec 31, 2009 | Toshiba Satellite A205-S5880 Notebook
Model:MT6705 won't boot says operating sys not found How do I fix this?
You may have lost your connection to your hard drive.
Try to remove and reseat your hard drive.
If the unit has been dropped or taken a good hit, you may have to replace the drive.
Oct 22, 2009 | Gateway MT6705 Notebook
When my gateway MT6705 tries to boot, blue screen
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
Oct 18, 2009 | Gateway MT6705 Notebook
Gateway MT6705 Notebook Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
