Question about Linksys Wireless-G WRT54G Router
Roku messed up wireless laptop connection
Everything was fine, laptops, x-box. then added roku, now i get error on wireless. when mouse over signal is excellent, when i try i get error low-signal, or interruption from another device. i have turned off the roku and tried signal 1, 6, and 11. originally was on 6, roku had me change to 1. then back to 6 now trying 11
4 Suggested Answers
SOURCE: linksys wrt160n wireless router
how can i connect my router so that i can use my laptop
Posted on Sep 29, 2008
SOURCE: Laptops stopped connecting wireless
check if you’re computer is properly connected wirelessly to the Linksys router, you will need to perform six steps:
  1. Checking the IP Address of the PC
  2. Checking the Wireless Settings on a Linksys Router
  3. Disabling Computer's Firewall
  4. Disabling Proxy Settings
  5. Pinging the Router
  6. Pinging the Internet
The IP address of the computer is another indication that the computer is properly connected to the router.
The router’s wireless settings should match the wireless settings of the wireless adapter in order for them to communicate.
Disabling Computer Firewall
Make sure that the computer firewall and any third party firewall installed in the computer is disabled. With a firewall enabled on your computer, you may get an invalid IP address. In such cases we have to disable any firewall installed on your PC.
If you have proxy settings, you need to disable these on your computer. If a computer is accompanied by a router, the gateway for the Internet connection, it no longer needs to get any proxy settings to gain access.
NOTE: If you are using Mac to disable the computer's proxy settings.
Pinging the Router
Ping test helps trace the communication between the computer and the router. The computer sends packets to the router and in return the router sends out replies to validate the connection.
Ping test helps trace the communication between the computer, the router and the internet. To check the computer’s connection to the Internet you should get valid replies when you perform a ping test
Posted on Aug 02, 2009
  • 177 Answers
SOURCE: my wrt160n keeps disconnecting for my macbook.
Hi Friend,
Please follow the steps:
1.Connect the MAC with an ethernet cable to the either of the four LAN ports and connect the Internet wire to the WAN/Internet port of the router.
2.Type 192.168.1.1 in the address bar of the router and hit enter.
3.Leave the username blank and type admin in passowrd.
4.Click Wireless Tab and fill the sections as mentioned:
Configuration View-Manual
Network Mode:Mixed
Network Name:As per your choice
Channel Width-20MHz only
Channel-6 (if this was already selected you can change it to either 1,9,11)
SSID-Enabled and click Save Settings
5..Click Wireless Security and fill the sections as mentoned
Security Mode-WEP
WEP Encrypion-40/64 bits 10hex digits
Key1-Enter 10 digit password(e.g-your 10 digit telephone number) and click Save Settings
6.Now click Advance Wireless settings tab and fill the sections as mentioned:
Beacon Interval-75
Fragmentation Threshold-2306
RTS Threshold-2307 and click Save settings.
I would suggest you to please upgrade the firmware
Please follow the link: http://homesupport.cisco.com/en-us/wireless/linksys/
Enter the model number and click the Download tab. Then enter the version number(which you will get once u turn upside down the router) and download the firmware and save it on desktop.
7.On the router setup page click Administration and then click Upgrade Firmware.
From here upgrade firmare and turn off the router for 30 seconds. Turn it on and enjoy.
I hope this will resolve the issue.
Regards
Chiranjeet
Posted on Jun 15, 2010
A new Roku HD does not find any wireless sites but another Roku in the same place finds all sites. Putting the older Roku in the same place works fine and connects to my wireless network without...
No way to fix that sadly, contact Roku and have them replace it for you. If you could fix it, you'd have to open it up which would void most warranties.
Apr 02, 2015 | Computers & Internet
Hype optical mouse model no. HY-7005-WMA 2.4GHz isn't working properly, wont connect to any device. How do I get the adapter signal to read on my laptop?
So you're saying you've tried connecting to other devices to no avail?
Might be worth reading the direction carefully. Sometimes there's a reset/rescan button(small) on the mouse that needs to be engaged after everything is plugged in.
Oct 31, 2014 | Hype 2.4GHz Wireless Optical Mouse -Blue
I would like to have my computer and tv hook up wireless
I think you're out of luck, you have to have a internet ready tv to do what you want.
Mar 22, 2012 | Computers & Internet
Hello. I'm tried to connect my pc to tv via wireless
u can connect using special cables...u must have a TV out slot in the laptop
Wireless i am nto sure...as TVs dont have softwares that can be configured to receive signal using wireless systems, unless ur TV and laptop is connected thru some connecting medium(a converter box/ADS instant DVD maker etc)
Jan 22, 2010 | Computers & Internet
Can't connect to internet since purchasing wrt100.
What is your laptop name, model#?
All "wireless" laptops have software that can "scan" for , and "repair" wireless connections. Bottom right corner, do you have a pix [picture] of a monitor ( with what looks like a 'radar' signal coming out ? ) right click mouse and you should see a menu, left mouse click " repair " and follow directions.
that you loose the signal after 3 ft. could suggest that your antenna is not connected right, that the coil ( that makes up the antenna ) is 'opened' or that you did not configure the wireless part of the router.
May 22, 2009 | Linksys RangePlus WRT100 Wireless Router
Wifi connection
try plugging the wireless mouse receiver into a different usb port
reboot your machine
is there a key on the keyboard with a little wireless symbol? if so it is probably in blue and there is fn key that you need to hold down while you press the wireless key to turn on the wireless
Feb 17, 2009 | Sony VAIO VGN-N130G/W Notebook
New HP laptop will not connect to wireless secure network
Problem solved. I disabled the security on my network. I connected the new laptop to the unsecure network. I saved the settings on the laptop for the unsecure network. I rebooted the laptop. I re-enabled security on the router. I tried to connect to the network. I got an error on the laptop saying the network saved settings did not match. I modified the settings to a secure network on the laptop and saved the 128 bit key. Rebooted everything. All works fine now.
Sep 06, 2008 | D-Link AirPlus DI-524 Wireless Router
Re: kensignton wireless mouse, connected but not working
have you checked the battries in the mouse as the battries that com with the mouse don't last long and have you pressed the connect buttons on receiver and mouse as somtimes usb power receivers loose connection on laptops try this one. hope this works
Aug 13, 2007 | Kensington Mouse-In-A-Box Optical Elite...
Wireless connection keeps falling
It may be just a problem of the signal bouncing around and your laptop is struggling at times to find the signal. Some earlier laptops don't have a wireless booster built in the screen. Go to your laptops' web site and see if there are any updated drivers for your wireless card. If still unhappy with results purchase a USB wireless dongle and dissable wireless card, it may have a better reception area, or purchase a signal booster that works in conjunction with your wireless router.
Dec 18, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Linksys Wireless-G WRT54G Router Logo
143 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
