Question about Refrigerators
GE SIde by side refrigerator GSS22JERF WW is making a clicking sound and is not keeping cold. We have tried cleaning the back of the refrigerator to see if this would help. But it continues to make the sound.
  • 163 Answers
Hi!!! your current relay has shorted change it and you should be okay..your hearing your relay cliking its no good..it looks like this and is located by the compressor where the rires go into the compressor..good luck..look at image of the current relay..GE SIde by side refrigerator - d1dad63.jpg or location here
Posted on Jan 04, 2009
2 Suggested Answers
CRTN
  • 716 Answers
SOURCE: GE Side by Side GSS22JERFWW not keeping cold
often there is a cover in the rear of the freezer with some screws remove these and put low temp grease on the fan. The Problem Is %100 The Fan So If You Look Up Your Fridge On Google It Will Tell You Where The Fan Is.
Posted on Jan 05, 2009
How old is the ge refrigerator model no gss22jerf ww
Sometimes the id plate located on the refrigerator has the manufacture date. Otherwise using the serial number attached to the machine, contact the manufacturer for this info.
Dec 10, 2015 | GE Refrigerators
GE DL213908 Side by Side Refrigerator not freezing or cooling properly
It doesn't cool
  1. Condenser coils
Make sure you dust off the condenser coils to prevent dust build up and overheating due to it overworking. Simply unplug and use a long coil cleaning brush to get rid of debris.
  1. Check seals
If your refrigerator door seal is broken, warm air is pushing its way inside the unit, thus causing it to not cool properly. Prevent this from happening by replacing your seal and keeping the cool air inside.
  1. Temperature controls
Ensure that your thermostat is set correctly, usually 38-40 degrees Fahrenheit.
  1. Defective condenser fan
When this fan is defective, cold air is prevented from flowing through the vents. It may require replacement.
  1. Compressor issues
Check if there are clicking sounds coming from the compressor as it tries to start. If there is a clicking, it is one of only two options, either the start capacitor or a bad compressor. A start capacitor is fairly inexpensive whereas a sealed system repair on the compressor is very expensive and often not cost effective. Refrigerator Repair Help Troubleshooting and Parts
Aug 18, 2014 | GE Refrigerators
My ge refrigerator side by side gsh22jfta ww freezer is cold enough but the fridge is not there is a vent between freezer and fridge, but I don't feel any cold air comming from it. Plz help me
The "damper" that open and closes is not working. It is controlled electronically with a thermostat. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy
Apr 06, 2013 | Refrigerators
I have a GE artica md417876 ps525mgna ww side by side the frezzer is not frezzing the food it sounds like the fan is working what can I do to fix this problem
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 25, 2011 | GE Profile Arctica 25.4 Cubic Feet...
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side (GSS25JFMD WW) is not cooling. It's blowing cool air, but not cold .
heatman101
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Jan 04, 2009 | GE GSS22JER Side by Side Refrigerator
GSS22KGMC WW side-by-side refridgerator not cold anymore
I have no idea to this day, what caused the complete lack of cooling in my freezer and refridgerator. However, it seems to be working fine now. All I did was turn the compressor and fan totally off, let it rest for a few minutes, and then turn it back on. It seems to have "re-booted the system, and now everything is working normally. The ice-maker is once again making ice! It has been three days or so now, and so far, so good!
Dec 25, 2008 | GE PSS26SHRSS Side by Side Refrigerator
Frost build up on the back wall of the freezer
The thermostat is not functioning the way it should leading to frost build up. You need to replace it. Should cost you around 40$
Sep 02, 2008 | GE GSS20IEM Side by Side Refrigerator
Refrigerators Logo
242 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
