Question about Garden
Automatic throttle control toro sr4 does not work
2 Suggested Answers
SOURCE: I NEED A MANUAL FOR A TORO LAWN MOWER MODEL# 20058
Go to:
https://homeownersolutions.toro.com/portal/server.pt/community/product_center/225
Posted on Aug 18, 2010
HOW TO REPLACE A FUEL FILTER ON A SR4 TORO MOWER?
Check that the vent in the fuel tank lid is clear.
Oct 06, 2014 | Toro Garden
Tip
GSM alarm system with RFID & APP control and Touch keypad
Name:GSM alarm system with RFID & APP control and Touch keypad
Memo:
products introduction
??Features:
??Multi-languages voice; system volume is adjustable (low, medium and high);
??99 RFID cards to arm, disarm, and control the relay;
??SMS notification for disarm by RFID card; SMS content (of the first 10 cards) is editable;
??12-second voice message: by control panel or remotely;
??Broadcast system time and play voice message;
??Use panel as a telephone to make calls;
??Set the by control panel, SMS or remote calls;
??10 remote controls, 99 wireless and 2 wired defense zones;
??Sensor low power alert and tamper alert;
??Some of SMS alarm contents are editable;
??SMS alert for control panel tamper, low power, power failure/ recovery;
??Remotely control the relay.
REV M White SUNRAY 800 HD SE SIM 2.10 Card SUNRAY DM800 HD SE A8P ALPS M Tuner SUNRAY DM800 HD PVR SIM210 with Wifi HDMI SIM 2.1 Cable receiver.SUNRAY DM800 HD SE A8P card SUNRAY DM800 HD SE A8P card ALPS M Twin Tuner SUNRAY DM800 hd Pro Alps Tuner REV M SUNRAY DM500 hd Pro satellite Receiver ,wholesale cheap discount price.alarm security systemVU SOLO 2 SE Twin tuner SOLO MINI 3LED DisplayLED signLED Display ScreenOUTDOOR LED sign large LED DisplayOUTDOORLED SIGN BOARLED DisplayFlexible CurtainLED Dance Floor Display FullCOLOR OUTDOOR Led Sign led screenoutdoor led displayled displayindoor led displaytransparent led displayled display lightingled video wallchina led displayfull color led displayled screensflexible led screenrgb led displaylarge led displayled curtainled dance floorfull color led displayout door led displayled display manufacturerssmd led displayled dance floor for saleled display, led curtain, led mesh for stageoutdoor led screenadvertising led displayindoor led displaystransparent led screenled meshled displayled screenA8p card SUNRAY SR4 V2 Rev.E jynxbox store
dreambox dm800 hd se v2alarm security systemdreambox dm7080dreambox dm7080dreambox dm820dreambox dm7020 hd v2cheap wholesale dreambox dm800 hd v2Sunray SR4 V2 Sunray SR4 800 se Sunray SR4 hd se JynxBox Ultra HD V14JynxBox Ultra HD V16JynxBox Ultra HD V15Dreambox DM7080 HD PVRDreambox DM820 HD PVRDreambox DM8000 HD PVRDreambox DM7020
on Mar 29, 2016 | NU -set Gsm Padlock Alarm System -...
Toro Z4200 hdro won't stay in neutral
Your throttle csble is stretched it needs a new one
Dec 15, 2013 | Toro Garden
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Need to know where to look on my mower to find out what info I need to find a new belt for my Toro SR4 Super Recycler.
I believe you will need belt Toro part # 91-2258 Try Partstree.com or call 1-877-798-7278 they are great to work with and can guide you to id your mower and get you the right part.
Jul 05, 2012 | Toro Power Lawn Mower
How do I remove the blade of my SR4
This is from the Toro owners manual for SR4 euper recycler model 20058 serial number 250003464
The steps and picture are on page 18 of the manual 3352-864[1].pdf
You can enter those numbers on this page for a manual:
https://lookup3.toro.com/request/request.cfm
1. Disconnect the spark plug wire from the spark
plug. Refer to Preparing for Maintenance
2. Tip the mower onto its side with the air filter up.
3. Remove the
2 blade nuts (A)
and the
stiffener (B).
4. Remove the
blade (C).
5. Install the blade and the stiffener that you
removed in steps 3 and 4.
6. Install the blade bolts and torque them to 15 to
27 ft-lb (20 to 37 N?m).
The replacement blade part number is:
108-3762-03 (google / net search)
Thanks for choosing FixYa,
Kelly
May 20, 2011 | Toro Power Lawn Mower
Throttle running too slow
I have the same problem. The mower is great---always starts and runs good, but it runs to slow and you can't speed it up. I even took it all apart. There just is no throttle control. I imagine it is designed this way to keep people from working on their mowers and to require an expensive trip to the service center. It will be my last Toro for this reason.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
