Question about Lutron S-600-wh Skylark Incandescent Dimmer
Lutron CL dimmer light delay when turned on - Lutron S-600-wh Skylark Incandescent Dimmer
  • 128 Answers
SOURCE: humming inside the switch
Is it connected to a fan motor also? - most dimmers are for lights only - if there is a ceiling fan connected you may experience a humming sound from the dimmer
Posted on Nov 23, 2008
  • 15 Answers
SOURCE: Dimmer switch is not dimming
florecent bulbs wont dim unless they are dimmable.
Posted on Dec 25, 2008
frcs68
  • 1605 Answers
SOURCE: 3 pole dimmer not completely working
there is not way to know how the wires are run by the description.
it is possible to connct true 3-way switch, it will required additonal pair of wires to all 3 switches (meaning 3-14/3 wire).
so call 3-way switches is only two way. I have not seems a real 3-way switches.
go to the following site. they a connection diag. for the switches.
http://www.homeimprovementweb.com/information/how-to/three-way-switch.htm
Posted on Mar 30, 2009
VtToolMan
  • 704 Answers
SOURCE: replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Posted on Aug 19, 2009
Testimonial: "I appreciate your help."
VtToolMan
  • 704 Answers
SOURCE: LUTRON DIMMER
The Lutron Maestro dimmer isn't rated or designed to operate low voltage lighting as it is a 120 V-AC rated electronic dimmer. You should either install a standard low voltage ON/OFF switch on this installation or obtain a dimmer rated for use on low voltage lights.
You need special low voltage dimmer designed for use on the low voltage pucks lights you have installed. Usually the low voltage is either 12, 24, or 36 volts, depending on the manufacturer of your particular light set. Once the correct dimmer is in place, the problem with the flickering and pulsing of the lights, should cease.
If you still are having this problem and you can't find a low voltage dimmer, you can contact the maker of your low voltage light kit and they can provide you with an acceptable dimmer option for your lights.
Most Home Depot and Lowe's carry the low voltage puck light kits, and usually have accessories for these lights, including dimmer switches that will work with them.
Hope you find this Very Helpful and best regards!
PS: I found this old, unanswered question and wanted to provide a solution to close out the problem and clear the question from the site.
Posted on Sep 10, 2009
Ok i installed the Maestro IR on a switch that runs a celing fan with a light on it. i turned the power back on in the room and the light was flickering and the fan was unresponsive. please help!!
Lutron Maestro IR shows several model numbers:
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro+IR%C2%AE+dimmer
You posted under MIR600 single pole digital fade dimmer for incandescent and halogen.
Installation manual:
http://www.lutron.com/TechnicalDocumentLibrary/030864b.pdf
If this is not your dimmer, then add a comment with exact model number so I can read that manual and look for trouble spots.
The manual does not say 'Fan'
It appears this dimmer is for incandescent and Halogen lights.
Manual gives Lutron 24hr/7day tech support number 1-800-523-9466
If you do not want to add a comment for more free assistance, and do not want to call Lutron, then take advantage of fixya phone service.
Expert will walk you through the problem for a price.
Dec 25, 2010 | Maestro Lutron MIR-600 IR Satin Color...
We have an older maestro style lutron dimmer switch with a horizontal slide button at the bottom that can turn it on and off. we are using this button to operate the light b/c the vertical...
These in-wall devices stop working and need to be replaced from time to time.
There are no repair parts.
Generally dimmers don't last as long as ordinary light switch, because they are electronic instead of mechanical.
Lutron makes the widest selection of dimmers.
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/Pages/DimmersSwitches.aspx
Use link above to identify dimmer.
For example Skylark dimmer.
Then google search for a replacement.
For example: single pole 600 watt lutron skylark dimmer
Or: 3-way 600 watt skylark dimmer
Lutron also makes 1800 watt dimmers for larger loads.
Add a comment any time if you need more help.
You can also take advantage of fixya phone service.
Fixya expert will talk with you via phone for a price.
Dec 24, 2010 | Lutron Electrical Supplies
I have a DL-3PSLHW-WH switch with no wiring diagram. It is single pole or 3-way. Need diagram.
You posted under Lutron 3-way dimmer.
You didn't say the number of screw terminals on device or color of those screws.
If your device has two brass screws, then it is single pole.
If your device has 2 brass screws and 1 dark screw, then device is 3-way
If you are replacing 3-way switch, identify wire on dark screw >> connect this wire to dark screw on dimmer. Other two wires connect to either brass screw.
If device has wires instead of screws, the color of those wires is an important clue.
Answer back with the colors of those wire and it is easier to help.
Different dimmers are suitable for different types of lighting.
In an effort to help you, I searched my files for Lutron dimmers.
Lutron has 17 dimmer types, with numerous models under each type
They don't show DL-3PS
Lutron has NT-3PS
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/NovaTDimmer/Pages/ModelNumbers.aspx
The NT-3PS is a 3-way dimmer.
Here is wiring manual:
http://www.lutron.com/TechnicalDocumentLibrary/wallbox_wiring_6_7.pdf
If the help above does not get you going, answer back with more information and we can help.
Oct 24, 2010 | Lutron Dalia 3Way Dimmer 600W- White -...
Lutron dimmers throught the house, lights go high brightness to low all by themselves, is this just a bad dimmer?
I have spent considerable time on the Lutron site past couple days looking at their dimmers.
Lutron has a lot of dimmer varieties. The basic breakdown is 600Watt and 1000Watt. But different dimmers control different types of lighting.
Here is the long list of Lutron dimmer manuals:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
http://www.lutron.com/Service-Support/Technical/InstallationInstructions/Pages/InstallationInstructions.aspx?syst=Dimmers+%26+Switches&prodn=Maestro%C2%AE+dimmer+%26+switch
I cannot find a specific troubleshoot manual for Lutron dimmers
So I suggest 4 things:
1) Feel the dimmer switch for heat >>> if it is getting hot (not warm), then that dimmer is dangerous, so remove dimmer immediately, add up your total bulb wattage to make sure you're below the 600 or 1000 watt capacity of you model dimmer
2) Look at the list of manuals shown at link, and make sure your dimmer matches the type of bulb you are using. Your dimmer model number and wattage should be printed on side or back of dimmer.
3) These dimmers use electronics to control the lights. Electronics go bad. The higher the wattage controlled by your dimmer, the more heat, and the shorter the dimmer life.
4) Short in the wires. Replace your dimmer with one from Home Depot and see if the condition persists. If it does, then a short is probably somewhere in that circuit. Troubleshooting a short is another long answer that needs more wiring detail ... please repost if you have a short.
Oct 17, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
I AM REPLACING A LUTRON DIMMER SWITCH AND HAVE i THINK MADE ALL THE RIGHT CI=CONNECTIONS - COULD A FAULTY GROUNDING BE THE PROBLEM?
As a general rule, grounding will not affect operation of dimmer.
Type of dimmer, type of switch being replaced, type of load, and how you connect wires will affect dimmer.
Here is Lutron dimmer switch page
What is the load? Are you wiring dimmer to a ballast? Or fan? Or incandescent lights? Or florescent lights?
Are you replacing a 2-way or 3-way switch?
What color are your dimmer wires?
How many wires were connected to switch?
Can you re-install the switch, and know where each wire went?
Did you replace a light with a fan, and then want the dimmer to slow the fan? Not every dimmer will work with a fan, or florescent lights.
Dimmers cannot dim LED lights.
If I know what type switch you are replacing, and the type of load you want to control, and the specific dimmer you have, I can answer the question.
Oct 12, 2010 | Lutron #D-600PH-DK 600W SP Push Rotating...
4 can lights wired to two 3 wire Lutron
The interior flood light bulbs were the new flourescent energy savers. I replaced them with incandescent and it worked with the dimmers.
Dec 16, 2009 | Electric Electrical Supplies
Dimmer doesn't turn off! Right after I installed a Lutron electronic dimmer switch, it worked fine. After about a week, it wouldn't turn the lights off. The lights just dim to a low level at the lowest...
There is one more thing that you can try, turn the power off from the breaker and wait about 20 seconds, then turn back on. If that doesn't fix it you are probably right about the dimmer being bum. It is very rare that Lutron devices are defective. You can contact them directly and see if you can get it replaced since you no longer have the receipt. You may have to send it to them before they will send you a replacement but it beats spending another $50
http://lutron.com/CMS400/page.aspx?id=24679
Oct 17, 2009 | Maestro Lutron MRF-600MT Single pole or...
Lutron Dimmer Probelm
You may want to consider getting an "electronic" dimmer vs. a manual knob or slider. Consider using a Maestro (MA-600-XX where XX is the color). The Maestro fits into a decora opening so you may also want to get a new wallplate (Lutron makes these in a screwless version: CW-1-XX where XX is the color).
Hope this helps.
Aug 27, 2008 | Lutron #D-600PH-DK 600W SP Push Rotating...
Lutron S-600-wh Skylark Incandescent Dimmer Logo
1,555 people viewed this question
Top Lutron Electrical Supplies Experts
Steve
Craig Butler
Craig Butler
berniekruege
Level 1 Expert
Are you a Lutron Electrical Supply Expert? Answer questions, earn points and help others
