Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Samsung RF266 water dispenser leaks
3 Suggested Answers
SOURCE: Samsung rs255sl refrigerator leaks water at water
The problem is at the water lines behind the kick plate. Remove the 3 screws on the kick plate. You should see too water lines a red and a blue coupling. Push the water lines in rather forcefully towards each other. When looking at the couplings on your left hand side you should see a small gray lip. You need to slide those outwards and insert the red clips (that should have been left in the plastic bag with the allen key used to adjust the door height) in between the lip and the coupling as they are compression fittings. This should fix your problem right up!
Posted on Oct 24, 2010
imufo2
  • 3773 Answers
SOURCE: My samsung RF266 stopped running
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
http://www.applianceaid.com/procedures.html
I'm
including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Aug 22, 2011
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
I have a very small dribble of water leaking from the bottom of the control panel on the freezer door. Is there a simple fix or do I need a technician? Unit is a SRS615DP.
Maybe and maybe not.
Page 9 of the user manual mentions a anti sweat heater that you can turn on or off.
Samsung SRS579NP User Manual Ice cold Water Dispenser
It maybe that the water line to the water dispenser is leaking
I am including a link to youtube videos about refrigerator water leaks but there is little about Samsung. Hopefully turning on the heater will solve your problem. At least one of the videos shows how to replace the tubing in a different brand of refrigerator.
samsung side by side water leak from freezer door YouTube
Sep 29, 2014 | Refrigerators
What is causing the water dispenser to drip? Ice is making fine
most likely a leaky water inlet valve or clogged dispenser defrost pipe or water tank leaking or water filter leaking.
Aug 06, 2014 | Samsung RS2630SH Side by Side Refrigerator
Rf266. Water collects under the bottom drawer of the refrigerator and results in leakage underneath onto the floor
Can you click HERE and read and or watch the video's so you can get an idea of what needs to be done behind the rear panel of the freezer to unblock the condensate drain Leaking Refrigerators.
Thanks, John Tripp Appliance 911
What is the model number?
May 01, 2014 | Refrigerators
Constant, slow leak from water dispenser on whirlpool refrigerator
you might need to replace the bottom section and spare parts should be available readily online. I had a slow leak on my samsung side by side and it was resolved once i bought a new part...Hope this is of some use but not an expert.....
Jan 02, 2013 | Whirlpool Refrigerators
Why does my bleach dispenser cup fill up with water every time I do a load of laundry?
I agree with grady709 about the plugged inlet lines, I had water left in my Samsung front load all the time and made sure the machine level and nothing wrong with venturi. I suddenly had water leaking from somewhere instead and when I took the top off I could feel the line swell up and leak at the fitting. Hose still leaked after replacing. Put a drill bit by hand down the nozzle where the hose clamps on and it was plugged up and also the bleach line was plugged up, also inside where the tray goes there is small holes in the top where the water sprays out can be plugged. Worked for me. Live where the water is hard.
Nov 24, 2012 | Samsung Washing Machines
Samsung french door refrigerator ice maker no dispenser defroster leaking water into bottom and produce drawers
If it is a frost free unit the water collects in a well at the compressor , there is a heater element in the well that boils off the water , this is were the fault is.
Jun 04, 2017 | Samsung RF217ACPN - 20 cu. ft. French Door...
A 2 to 21/2 year old Samsung bottom mount freezer RB217ABPN purchased from Costco. Water is starting to collect under the crisper drawers in the fridge section. This is the third time in a couple of months...
You have a leaking water tank behind the crisper drawer. You will need to get back there to determine if the tank is leaking or the water connection is leaking. This will only leak if you close the door and dispense water from the dispenser.
Jun 22, 2011 | Refrigerators
The water dispenser keeps leaking even when we are not using it
Hello, if it just leaking slowly check the filter if the filter is fine replace the water valve. If the water will not stop running out like you were pressing the water button replace the switch behind the dispenser.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Samsung RS2530BSH (25 cu ft) Side by Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
