Won't ignite
It is probably the bake ignitor needs replaced. the only way to check it is with an amp meter. however, this is a part that does fail alot, and you can buy one for pretty cheap. it is located mounted on the bake burner by 2 screws. and it only involves splicing 2 wires, (the wire nuts you need should come with the new ignitor)
Hello friend, thank you for your post!
Based off the information you have provided you need to know the location of the speed bake switch inside of your Frigidaire oven. I would be happy to provide you with that information, if you can provide me with your model number. You can locate the model number on the serial tag and that can be found on the bottom drawer frame. Once I have that information I would be able to assist you further. -Matt
Thank you for your post, Jewell!
From the information you have provided you would like a manual for your Frigidaire oven. I would be happy to research and see if that information is available. In order to research for any available manuals I would need your model number. You can locate the serial tag (which lists your model number) on the door frame of your oven or on the inside left hand wall. Once I have that information I would be able to better assist you. -Matt
