SOURCE: How to enter authentication details for the Document Server ?
Hi there if you type in the internet explorer the ip address there you will have the machine information. Then login usually the login is
User name = Admin
Password = password or just enter leave blank
Once you are in there you will be able to change the details you need.
Cheers J
SOURCE: "The RPC server is unavailable"
Hi, If that doesn't work try the following :-
Solution #1posted on Dec 23, 2007 by Silan
Try :- http://www.fixya.com/support/t311909-printer_installation_problem
1.open a Command Prompt window(click start--
-->run--->type cmd and press OK)
2.key sc config spooler depend= RPCSS (note
the space after depend=) and press Enter.
Try reinstalling the printer.
Or
1. Start / Run / MSConfig / OK.
2. Select the Services tab.
3. Make sure that each of the following
services is checked:
Plug and Play
Remote Procedure Call (RPC)
Remote Access Auto Connection Manager
Remote Access Connection Manager
4. Press Apply.
5. Press Close.
6. Press the Restart button.
If the services can not be started from within msconfig try starting them from services.msc (start run services.msc etc...)
Try reinstalling the printer software.
