Stop in the middle of circle
I have just got a second hand washing machine when I tried it. It couldn't finish any circle. It always fill the water and agitate a while and then nothing happened further. The previous owner did not plug it in and I did not try it there. They just told me they did not have issue although they haven't used it for quiet while and it has been put outside room on the porch for a while. When I moved this machine to my apartment I put it side way on the machine's back instead of upright because my wagon couldn't fit it upright. Could be that do any damage to it? Or this machine has been like that even before I try? Anyway is there a quick fix to this. Thanks
  • carl carpenter
    carl carpenter May 11, 2010
    does it pump out water after agitating
  • 716 Answers
You May Have A Plugged Hose Inside Open Up The Front And See Could Easily Be Your Problem. They Are Usually Clear So you'll Be Able To See If Its Kinked Or Clogged.
Posted on Jan 05, 2009
Washing machine stopping and starting when filling
Sounds like maybe a bad water inlet valve? timer may have isses as well? have u tried running it in hot water only and cold water only cycle? see if one line is bad in ur inlet valve?
Dec 16, 2014 | Washing Machines
I have a Simpson ezi set 9.5 kg washing machine.It has stopped in the middle of a wash and the LCD screen I showing EFO.Can you tell me what this means and what I need to do to get machine to finish...
i have a 9.5kg simpson washing machine just 5months old and ive had this problem E20 quite frequently that its annoying. I printed out a manual and foundout why. i do not have the patience to remove draining hose im sure there is a simplier way. Ive notice if i tap the side of machine 3 to 5 times it drains lol! seriously never had a problem with my old 7.5kg hoover machine, please help
Jun 19, 2013 | Washing Machines
Does anyone know how to check a fuse in my Bosch Maxx 1000 washing machine??
Try it in a different socket as it may not be the machine. The machine would have been factory fitted with a moulded plug, lift out the middle section and try a new fuse. If the unit failed after filling then possibly you have a short on the wash heater..you could verify this if you get power by setting a cold cycle or rinse and see if if completes it. Please also check that the consumer unit (main fuse box) has not been triggered.
Nov 26, 2011 | Bosch Washing Machines
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Washing machine begins the wash cycle going immediately to the agitate cycle, without filling up with water first.
water will not stop running into drum unless shut off at faucet does not happen all the time and wife can't find her rubber boots
Apr 26, 2009 | Washing Machines
Tricity Bendix
try opening the small front panel at the bottom right hand side of the machine unscrew the drain guard and check for any blockages
Sep 08, 2008 | Tricity Bendix AW1260W Front Load Washer
WF320P Water fills on wash cycle drum starts to rotate. After 30 seconds or so middle three red error lights flash and cycle stops.
Hi there swamib lets see if we can help you out. If the lights in the middle of the appliance flash led 1,2,3 that means there is a problem with the heater it is most likely it is open circuit replace this and it should solve the problem keep in touch noffie......
Apr 08, 2008 | Washing Machines
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
