Question about Teac CD-RW880 CD Player / Recorder
Question Thinking about purchasing the unit ... will it work also on conventional CD-R and CD-RW or does it need Audio specific discs? thanks!
  • 2 more comments
  • skyway99 Jan 05, 2009
    Thanks John ... one additional question since I have never come across "Audio" CD-R or CD-RW.
    Since I can have conventional CD-Rs practically for free, would it possible to just have one Audio CR-RW to use with the unit and then copy onto conventional CD-R? Or is there anything that prevents an Audio CD-RW from copying it by means of usual PC programs to duplicate CDs?
    Thanks!
  • skyway99 Jan 06, 2009
    Hi John ... I forgot to mention an important point. I would use RW880 to copy only vinyl and cassettes onto CDs. To copy, or make compilation starting from CD I have always used my PC.
    Does this take the SCMS stuff out of the picture? If so, I could put the vinyl LPs on an audio CD-RW and then copy this to a computer CD-R by means of the PC. I would just need a single Audio CD-RW (well, I do not know how many times it can be re-used but I guess it's in the range of several tens).
    Comments? Thaaaaankssssssss!
  • skyway99 Jan 07, 2009
    OK John ... I think I'll go for it. Best wishes and thanks again
  • teckietired Feb 02, 2009
    I am using Sony CD-R Suprema CDs and the TEAC RW-880 does not respond, If I push play I get nothing.
  • 41 Answers
You can master to an AUDIO version of a CD-rw and later duplicate it on a PC (CD copy) to a regular data CD-R disc. SCMS will not enter into the process unless you are transferring from a stand alone CD player to the CD recorder via a optical or coax digital connection.
Posted on Oct 14, 2009
  • Linus_007 Oct 14, 2009
    I would spend a little bit more and go for a professional cd recorder. With a professional recorder you can record to any media and you do not have to deal with hassles related to SCMS. Most professional CD Recorders will accept SPDIF (consumer) and AES/EBU (professional) digital formats.
  • 4 Answers
I am 99% certain that it will only work with 'audio' discs. This is the case with my Philips CDR-796 and as far as I am aware applies to all consumer CD recorders.
Hope this helps
HifiJohn
Posted on Jan 05, 2009
  • John Talbot Jan 05, 2009
    I haven't tried this myself, but I think there would be problems in doing this. It would depend on the source of the recording for your CDRW 'master' copy.
    Domestic CD recorders have something called 'serial copy management system' (SCMS) to limit 'pirate' copying. This allows you to make a first generation digital copy of commercial copyright CDs but in the copying process sets a 'flag' in the header data that prevents the recorder from making any further digital copies from the first generation copy.
    I suspect the same applies to copying on a PC. A possible work-around would be to make your original CDRW 'master' in analogue copy mode, though this would result in a small loss in quality and loss of track title and any associated CD-text.
    So unless there is PC software that can ignore/workaround the SCMS protection, doing what you want to do will involve some hassle if it is possible at all. If your software allows you to make copies of commercial CDs then you may be in with a chance.
    HTH
    HifiJohn
  • John Talbot Jan 06, 2009
    Hi skyway,
    Yes that would mean the SCMS issue is not a problem, and that you should be able to do what you propose.
    I believe most manufacturers claim that CDRWs can be re-recorded 500-1000 times, although in my limited experience (I use them for 'time-shifting' radio programmes) minor manufacturing imperfections eventually cause data glitches in recordings that end the discs useful life well before that. Also note that it can cause a disc to become unusable if a recording runs past the end of the discs capacity, so keep a watchful eye on the 'time remaining' if it's going to be close to the 74 or 80 min disc limit.
    Good luck
    HifiJohn
Am in process tranferring vinyl to cd using sony compact disc recorder and not computer,ran out of audio discs last week purchased some verbatim discs high speed rw but will not work on my machine can you...
Hi raymackie265
You are right , don't use cds for computer ( cdroms ) but well audio cds . Pay attention to this point when purchasing new stuff . Regarding the issue with cd-Rw , it's a compatibility issue with your Sony device and you need to check if the recorder will accept CD-RWs . If yes ( and it should be yes ) , try to find lower speed discs but you need to find audio cds . I ' m using a Pioneer recorder and it works fine with any kind of audio cds , not with cdroms .
Best regards ,
fanaudi .
Aug 30, 2011 | Verbatim 10PK CDRW 80 MIN 700MB 4X12X...
I don't founr cd 74 mn 650mb, what use the DENON CDR M30 ??
If I understand your question, it can play any kind of music CD but it can only record on CDR-Audio or CDR-Music discs only.
• Only audio CD-R/RW discs can be recorded with this unit. "Use Audio CD" will be displayed when a disc other than one
for use with audio such as a CD-R/RW disc for use with a personal computer or another type of disc is loaded. (See "Discs that Can Be Used with this Unit" on Page 5.)
• CD-R discs can be recorded to only once. The recorded information cannot be erased.
• The recorded information of CD-RW discs can be erased. When this disc has been finalized, erase after the finalization removal operation has been performed. (See "Cancellation of CD-RW disc finalizing" on Page 28.)
• Recording mistakes made with CD-R discs cannot be erased; therefore, it is recommended that a CD-RW disc be used until you are accustomed to the recording operation.
If you desire 74-minute blank disc just Google "cd-r audio 74". The unit will also use 800MB 80-minute CD's.
Jan 31, 2011 | Denon CDR-M30 CD Recorder
Hello, my Philips AZ1145 shows "no disc" despite I put normal ou RW CD discs, old or new. Can I fix it or is it for garbage ?... Thanks
First try a normal shop purchased cd (you must have at least one laying about). If that works, GREAT it means that your boombox does not like cdrw discs (not many do unless specifically stated on the unit with a CDr/RW logo). If it still refuses to play ball, try a cd lense cleaner. If after all that, you're still getting nowhere, my guess is that the lense has had it's day. Although these can be replaced, on a unit like this it's actually cheaper to buy a new boom box.
Best of luck
Sep 03, 2010 | Philips AZ1145 Cassette/CD Boombox
Does the unit recognize 80 minute discs?
Any desk CD recorder will only recognize discs labeled "Audio Disc".
That means you cannot use CD-R or CD-RW discs, that are basically data discs. No matter duration, if your 80 minute disc is CD-R or CD-RW, your unit will not recognize it. Good Luck.
Flavio/BRAZIL
Jul 25, 2010 | Philips CDR778 2-Disc CD Recorder
Recording error
Refer to your user manual for error codes and troubleshooting tips.
If you cant find the error code then please kindly forward the following:
Disk Type:
Recording Device:
Hardeware Specifications:
May 26, 2009 | Symphonic SR90VE
Won't record record to CD-RW
First make sure your cdrw disc is blank. If it is blank try another good known cdrw brand disc and burn it in 12x speed for a good burn.
If it still fail check the software side of your cd rewriter first and lastly the cd rewriter unit.
Mar 28, 2009 | Crosley 4-in-1 Entertainer CD Shelf System
Can't get it to record
I experienced this problem a long time ago, i believe that it was because i tried to use a normal data cd-rw but the unit only reads audio discs. It has to be a cd-rw for audio only (will say cd-rw audio on the disc, whereas if it is a data disc it will simply say cd-rw.) Hope this helps..
Mar 13, 2009 | Pioneer PD-R509 CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
I burned a cd and it wont play in the cd player i have a 2003 ford focus with a blapunk ford radio the cd is a rw
Most older factory car radios won't play a burned disc. You could try a cd(+ or -) r instead of a rw. But it probably won't work. Some cd players work better with a specific brand of disc too.
Specifications can be found at the radio manufacturers web site.
In 2003 mp3's and burning discs was new to car audio so the radio may not be compatable.
Sep 02, 2008 | Car Audio & Video
Won't recognize a blank dvd in drive
Clean the drive with a cd/dvd cleaner. Sounds like the read optics are a little drity.
Nov 07, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Teac CD-RW880 CD Player / Recorder Logo
231 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
