Question about Britax Boulevard
Does it only work with the LATCH system?
Will this work with a car without the LATCH system hooks?
  • 30 Answers
Posted on Jun 30, 2007
How to fix latch/ spring on door
Brand and model would help but here is the most common way to fix. There is a plastic frame all the way around the inner door which should have the 2 holes in it that the latch hooks come through. That frame usually needs to be gently pried away from the door. Use a small blade screw driver and be careful because it is brittle and will crack easily. Once that is removed, you should see the latch and spring system. springs are usually attached over a small hook on the door and one on the latch hook.
Apr 04, 2015 | Microwave Ovens
How do I get rear gate to close if the latch clasp is rotated out of correct position?
You probably need to pull the manual release and physically move the latch back into its unmatched position. The latch hook will rotate open so that it can receive the fixed bar on the body.
Aug 18, 2014 | Cars & Trucks
Door on a driver side does not work I put a new door handle now it doesn't work?
Can't tell from the vid but you did hook up the rod from the handle to the latch mechanism, correct? There should be 3 different rods hooked to the latch, one for the lock, one for the inside handle and one for the outside handle. make sure the one for the outside is hooked up at both ends. Then disconnect the one going to the handle and try actuating the latch by pushing/pulling the rod. If you can't actuate it that way, the latch may be broken internally and will need to be replaced.
Oct 14, 2012 | Cars & Trucks
1999 bentley arnage. The trunk will not latch, cannot seem to see anything broken or sheared, but the trunk will not latch regardless
is latch already in closed position will not close see if you can insert key and turn to unlock
using a pick hook or scredriver to re open pawls in latch system
if all this is corect adjustment may be needed on latch system to catch
Jul 19, 2011 | 1999 Bentley Arnage
My door is all hooked up, with the exception of the outside door handle. the inside door handle pulls the rod which is hooked into the door latch but my door still wont open. i think maybe the latch is...
if the linkage is hooked up and you can get into the truck from the passenger could reach into the door and pull up on the linkage over by the latch
Aug 17, 2010 | 1990 Chevrolet S 10 4WD
Front damage, inside cable to open hood snapped from latch. latch damaged and can't open hood. Know of any way to pop the hood? 1991 park avenue
Usually a strong coat hanger will snag the lug the cable attaches too. You will need to bend a 3/8 end J hook from the coat hanger and snag it from the drivers side of the latch to pull on this lug horizontally
' If the hood is trashed just zip a hole into the hood were that latch is located with a disc grinder and a cut off wheel instead
Apr 26, 2010 | 1991 Buick Park Avenue
Latch belt too short
Looked at the owner's manual of my car and realized where I needed to hook the latch belt hook strap. I was trying to hook it to the wrong thing. Car seat works great now!
Nov 21, 2009 | Safety 1st Baby Gear
New Beetle boot does not shut properly 2000 model indicator light stays on boot appears to be locke3d on on first notch.
Hope this helps, it worked on my 2003 beetle convertible. First, I tried adjusting the latch mechanism and the catch post to put them closer together when the trunk is closed. You will need to remove all of the trunk trim to get to the screws on these two pieces. You also need a special bit called a "triple square" bit in two sizes to loosen them. The trim removal took forever. This works for many folk, but unfortunately, this did now work for me. The second trick did work. I found the cure on my car when I rotated the latch hook by hand. When the latch hooks around the catch you can see that there is a piece of rubber in the top of latch hook that is supposed to cushion the thud of the latch shutting on the catch post. On my car, the rubber extended so far into the latch and was so hard that the catch post could not go far enough in to allow the hook to snap over. Use the remote to open the latch, pull off the soft plastic cover over the latch and you will see the rubber spacer and how it attaches. Pull off the spacer, sand it down a considerable amount with sand paper wrapped around a small dowl, and reinstall. I could now see that there was room for the catch post to fit into the latch far enough that the hook would spring around and lock it down. Works now with no slams. Good luck.
Oct 31, 2009 | Volkswagen New Beetle Cars & Trucks
01 Jeep Cherokee Hood latch cable broke
look in through grill you should see where cable hooks to latch should be able to pop it there may need a long tool to reach it
Dec 26, 2008 | 2001 Jeep Cherokee
Sentry H4100 file safe
There is a lock and there is a latch.
You can latch the safe without locking it and unlocking it does not unlatch it.
After you unlock it, then you must press up on the spring loaded latch while (this important) pressing down on the cover to releast the pressure on the latch hook, allowing it to move out of the way. After the latching hook is out of the way, you can release the pressure on the lid and it will open. You can't see the latch hook as it drops down from the lid, into the front wall of the safe where it engages a post, but perhaps you can imagine what it looks like.
Mine will not unlatch, even though it is unlocked, unless I press down on the lid to give it clearance first. There is quite a bit of spring in the plastic that this safe is constructed out of. It works against you when you try to open it and close it.
I can take digital photos of the mechanism if this description does not help.
Another Gary
May 14, 2008 | Sentry Fireproof Safe
Britax Boulevard Logo
118 people viewed this question
Top Britax Baby Gear Experts
Jennifer Rock
Jennifer Rock
Dorel UK
Dorel UK
Are you a Britax Baby Gear Expert? Answer questions, earn points and help others
