Question about Marantz SR7002 6.1 Channels Receiver
Flashing power led on marantz sr7002 - Marantz SR7002 6.1 Channels Receiver
3 Suggested Answers
SOURCE: Standby light is flashing rapidly and I can't turn
RECEIVER MARANTZ SR7002, FLASHING THE STANDBY about 8 times per second and will not start, HELP
Posted on Sep 24, 2009
alpug
  • 1961 Answers
SOURCE: how do I connect a
If your turntable has an stereo output through it RCA output connector make sure that the RCA cord you are using is new means there is no cut of wires inside it .check the continuity by connecting the RCA cord to the auxiliary input of your reciever then touch the plug with your hand.you should hear a loud humming audio left and right following which plug you are touching.it means the cord is good.if only one channel you hear then replace the cord.good luck..
Posted on Jun 26, 2011
I have a marrantz sr7002 The red blinking light
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for intermittent shutdown.
Apr 18, 2011 | Marantz SR7002 6.1 Channels Receiver
Hi I would like a little help to update the firware dvd blu ray bd 8002 Marantz tell me how should I do? thanks you.
Hello
Enter these sites for fudate your Maranz.
www.buyblurayplayers.com/firmware-updates/how-to-update-your-firmware
www.avforums.com/.../765663-marantz-firmware-updates-sr7002.html - United Kingdom
softwaretopic.informer.com/firmware-update-tool/
I'll ge you some hints also
Open the Internet browser and navigate to the Marantz.com website. Select "Products," then choose "DVD Players."
Select the DVD player you are currently using, then select "Manuals and Downloads." This lists all of the available updates for the Marantz DVD player.
Click the software update to download to your computer system
Plug the USB flash drive into a USB port on the computer, then click "Start," "(My) Computer," then double-click the removable device icon. A window loads with all of the files stored on the flash drive.
Click-and-drag the software update into the open window, then close the window, right-click the removable device icon and select "Eject."
Disconnect the flash drive from the computer once the icon disappears.
Plug the USB flash drive into the USB port on the rear of the Marantz DVD player, then power on the device. The software update will upload onto the DVD player. A prompt on the television screen appears once the update has finished.
Mar 20, 2011 | Marantz BD8002 Blu-Ray Player
Standby light is flashing rapidly and I cannot turn on
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Marantz-SR7002-Receivers-manual/id/6753ci475/t/2/
Page 81...
PROTECTIVE FEATURE
In some cases, the STANDBY indicator may blink slowly, twice per second. In this case, turn off the unit, unplug the power cord, and check the following points.
Make sure the speaker cables are not reversed and connected to the wrong sides (+ and -) on the unit.
Make sure the speaker cables connected to the unit are not shorted. (Check both the unit end and the speaker end.)
Make sure the volume does not exceed the level that the unit is capable of producing.
When using the unit in a rack or other enclosed space, heat may build up inside the unit and cause a fire. When installing the unit, be sure to leave suffi cient space between the top, back and both sides of the unit and walls or other AV components to prevent the internal temperature from rising.
After checking these points, plug in the power cord and use the remote controller to turn on the unit. Turn down the volume before resuming playback. Confirm that there are no problems with the speaker connections and playback performance.
If this symptom recurs, request service at your nearest service center.
In rare instances, the unit may enter standby mode and the STANDBY indicator may blink rapidly, 8 times per second. In this case, unplug the power cord and request service at your nearest service center.
Feb 27, 2011 | Marantz SR7002 6.1 Channels Receiver
How to connect to an analog tv
Try to locate the composite video/audio in(1) and audio (2) out sockets of your tv.
(1): three small round sockets, one yellow, one white, one red (2): two small round sockets, red and white. (only if you want sound from your tv on your marantz receiver)
You will need a composite audio/video cable: 51433a4.jpg
and a composite audio cable: db5db51.jpg
Connect the composite video/audio cable (1):
the yellow lead to MULTI OUT (yellow) the white lead to MULTI OUT (white) the red lead to MULTI OUT (red)
on your tv: connect these cables to the respective yellow, red and white input. (there should be a text like: game in/dvd in/ext in/AV-1/VCR) If all you see at the back is a big socket like this one: 0f41fcb.jpg
you will need a SCART-to-composite adapter, like this:
(2) To get audio from your tv to your Marantz, locate an 'audio out' (red + white round connectors) on your tv, and connect these pins using cable (2) to TV (complete bottom left on your Marantz).
Dec 13, 2009 | Marantz SR7002 6.1 Channels Receiver
When running video thru the amp, the pic flashes on and off
usually that is an issue of cabling and/or the monitor. The Marantz units are pretty darn stable. Check your setup to see if it is upconverting.
If you can, try a new HDMI cable to the TV. You could also try the second HDMI out, to see if there might be a problem with that particular output port. You can also try a different HDMI port on the TV.
Another thing to try is to directly connect your DVD player to the TV. If your cabling is all in walls, etc, you can get an HDMI coupler at a big box store for $15.00 or so. That will tell you if it is any of the cables, the DVD player, or the TV.
Jan 05, 2009 | Marantz SR7002 6.1 Channels Receiver
How can I connect a equalizer to a marantz sr7200
The internal equaliser working with digital inputs is already incorporated into the receiver. You can access it through MAIN MENU. An external equaliser, I assume for analog inputs, should be connected between corresponding receiver multichanel (7.1) inputs and the source (ie DVD player's) analog outputs.
The digital output of you source can still be connected directly to the receiver using digital cables.
May 03, 2008 | Marantz SR7002 6.1 Channels Receiver
Marantz SR7002 6.1 Channels Receiver Logo
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
