Question about Whirlpool LER4634J Electric Dryer
Dryer is making loud thumping noise.
I have a Whirlpool 5 Cycle dryer. It started making a loud noise when running. It still dries the clothes and seems to work in every way. The sound is something like a thump and rattle as the drum turns. The noise appeared suddenly and has not increased or changed. It's quite loud.
  • 3 more comments
  • Todd Podoll Jan 29, 2009
    I have the same problem. The dryer makes a terrible noise, but it is not continuous. It thumps and rattles, but does not sound like a bad bearing. The sound has changed a bit over the past few weeks.
  • Anonymous Mar 16, 2014
    when I turned the dryer knob, while it was running, it made a loud sound like an electrical arch then quit.
    Bravos Quiet Series 400 make loud noise while in spin cycle
  • Anonymous Mar 18, 2014
    Whirl pool duetb dryer drum makes noise when running.
  • Anonymous Mar 31, 2014
    dryer makes a loud scratching sound and does not always get hot
  • 979 Answers
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Posted on Jan 14, 2009
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
My whirlpool duet washer hammers very loud when it spins. The outside of the machine doesn't seem to vibrate much but it is very loud.
That is a common occurrence with dryers such as this one. Even though it sounds bad, it is harmless. If it really bothers, you can re-balance the load and it should reduce the vibration.
Jul 29, 2008 | Whirlpool Washing Machines
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
LG washer - loud noises & brown spots on clothes.
The drum bearing has perished this wild cause the noise and the brown spots on your clothes is probably the grease from the bearing
May 05, 2017 | LG WM2077CW Laundry XL Front Load...
When we turn on our Whirlpool Supreme electric dryer, it heats up and dries clothes, but it is making a loud squeaking noise throughout the cycle...sometimes louder than others.
The squeaking noise can be caused by any of the following.
Location High:
Belt slipping on the dryer drum
Worn Drum seals but would sound more like a dragging noise
Location Low:
Belt tensioner pulley bearing frozen and the idler pulley shaft is spinning inside the belt tensioner assy.
Belt slipping on the motor bearing
Motor bearing is dry
Thanks for using FixYa!
Kelly
Mar 04, 2010 | Whirlpool LER5636P Electric Dryer
I have a LER4634EQ1 WHIRLPOOL electric dryer. Last week it started to shut down before completing a cycle. The other day it completed the cycle but the clothes weren't dry. It also makes a loud noise when...
if the noise is a rumbling sound tha that would be your roller's.the other problem sounds like a bad timer.time to think,do i put that kind of money in a 12 year old dryer or get a new one.
Nov 05, 2009 | Whirlpool LER5636P Electric Dryer
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Dryer makes noise and vibrates when starting and stopping
Most likely it is the bad blower wheel. The clothes seems hotter than normal oh yeah bad blower wheel.
May 19, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer
Today my whirlpool dryer started making a loud noise. it is drying the clothes but the noise is loud.
Jul 06, 2008 | Kenmore Dryers
Whirlpool LER4634J Electric Dryer Logo
1,238 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
