Question about GE GSS25LGM Side by Side Refrigerator
Will not cool or freeze
Fan is working but not blowing cold air.(compressor out??)
  • GE Master
  • 4,654 Answers
A common problem for your model is the motherboard has possibly failed, compressor start relay and a few other symptoms. Can you pull the refrigerator away from wall, unplug power and remove lower cover that covers the compressor? I need you to do a few things so I can help you determine the problems you are having with your GSS25LGM
I can walk you through the diagnostoics to find out if this is related to your=> WR55X10942 Main Control Board
Here is a manual=>
GE Refrigerator Technical Service Manual
Let me know if you would like my assistance, Thanks Sea Breeze
Posted on Nov 05, 2012
    Top Expert:
  • GE Master
  • 9,472 Answers
Unplug the unit and pull it out from the wall. Take the relay off the compressor and shake it. If it rattles, it is bad and needs to be replaced. Here is the part to order.
Keep me posted.
  • 531 Answers
SOURCE: I have a GE Profile side by side and it is not
you may have defrost problem
Posted on Apr 06, 2009
  • 531 Answers
SOURCE: Refrigerator not keeping food cold
Maytag317
  • 1136 Answers
SOURCE: Does not cool. Compressor is running, fans are
Hi, Look in the freezer section and see if there is frost building up on the rear inside panel. If the is frost, on of three parts are bad in the automatic defrost.
If there is no frost, the compressor might be weak and not pumping the coolant as strong as it should.
Remove the rear inside panel in the freezer sevtion and see if the evaporator is frosting at all.
Please let me know what you find so I can assist you further with this issue.
Vic
Posted on Jun 27, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE profile refrigerator line freezes, fan blows but no cold air?
OK, I think I understand. Thing is we need to do a few things to see if your control board is the problem or if the fan or a freon leak is the answer. You need to tell me if this began suddenly or if over a period of time. I have been having trouble lately from Fixya if the customer (YOU) responds to my solutions. Let me know if you want my help and I will see if I get a email letting me know of your response, Thanks, Sea Breeze
Posted on Jul 12, 2009
  • 833 Answers
SOURCE: Freezer won't get cold
Defrost the unit completely.  There may be ice blockage preventing proper cooling.  You may also be low on gas.  With the unit off for an hour, restart while observing the largest pipe on the compressor.  It should frost and then after about 15 minutes either dry out, form ice or water on it.  If it is still frosted, it will need a recharge.
Posted on Nov 27, 2008
Not staying cool
sounds like it is either low on Freon or the compressor is going out. The blowing ice cold is an indicator that it may be freezing up because the low Freon. when it stops blowing cold, turn it to fan only mode and see if it gets colder again. If that is the case then the unit is low on freon and freezing up. I know that sounds confusing but that is how AC works. The low freon pressure means the gas is expanding too fast and the air flow cannot take up the cold from the evaporator fast enough. Turning the compressor off and keeping the fan on will alow the room air to take up the cold.
Apr 22, 2014 | Frigidaire FAM157S1A Air Conditioner
Fridge not freezing meats
I was writing a big note here before then hit the wrong button, it was just a bunch of jargon anyway. Yes it is the condenser fan motor causing your problems. Doesn't cool the refrigerant properly than nothing works. I would change the fan before it causes any damage to the compressor.
Sep 04, 2012 | Whirlpool Refrigerators
Not getting cold enough to freeze, How to check Freon
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 05, 2010 | Kenmore 53082 / 53084 Side by Side...
It blows cold air for 5 min. and the it blows cool air for 15 min. the room warms up . Why does it stops blowing cold air continuasly???? The thermostat was disconectet on purpose so it coul clow cold air...
See if you can reposition the thermister on the facing of the evaporator coils. That could be it or the thermister might be bad. They don't use copper/mercury sensing bulbs these days. They use these cheap thermisters.
May 22, 2010 | LG Heat cool Window Air Conditioner
My fan isn't working
well there not enough data here to make a fairly good solution. but if all the fans are running! and no cool air then it is the compressor.
Jul 14, 2009 | Heating & Cooling
Fan blowing air won't get cooler
is the compressor short cycling or is the low cooling psi line freezing
Jun 13, 2009 | Heating & Cooling
Is not cooling
you may have defrost problem hear if compressor morking
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
FREEZER NOT FREEZING REFRIGERATOR NOT COOLING
can you feel the compresor??? is it hot??? if this is hte case, your compressor is hot and hte fan the freezer section is still circulating warm air sounds as ifyou have a sealed system issue, 5yr manufactue warr.. (should be anyway check your manual)
Nov 30, 2008 | Frigidaire FRT18G4A Top Freezer...
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
GE GSS25LGM Side by Side Refrigerator Logo
129 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
