Question about KitchenAid KESC307 Electric Kitchen Range
CERAMIC TOP COOKER ELEMENT
After using the self clean feature the two top right side elements no longer turn on everthing else is working fine..... any sugestions thanks in advance
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
Check the wiring to the element looking for bad contacts, use an ohm to check the continuity of the elements. always remember to disconect the power when doing these types of tests
Posted on Sep 28, 2007
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    We have a free standing Frigidaire flat top stove oven that is electric I decided to use the self cleaning feature on it and the bottom element burnt into My husband removed the bottom element before...
    I THINK THE HEATING ELEMENT YOU GOT COULD BE WRONG SIZE. I KNOW MINE WENT OUT WHEN COOKING SOMETHING HOTTER THAN I USUALLY USE LIKE 450 DEGREES, IT BURNT OUT. BY CLEANING OUT YOU'RE OVEN, WHICH REQUIRES REAL HOT TEMPERATURES, IT SOUNDS LIKE YOU ON THE RIGHT TRACK. IT BEING OLDER STOVE, A LOWER RATED ELEMENT I WOULD TRY..
    Mar 24, 2017 | Kitchen Ranges
    Hi there Have recently moved into a house with a Belling 626 white, electric cooker and the grill doesn't seem to be working. It has a mian oven, top ovem and "dual grill". The main oven...
    ISOLATE THE MAINS POWER BEFORE CHECKING THE APPLIANCE
    Run your fingers along the grill element, in this model it is accessible, check for raised areas or small hole or roughness not food burnt, if visible, it should be Black Grey colour at the blemish, you can obtain parts from www.whitegoods.co.uk you will need the model and serial numbers.
    The grill elements come out but when unsrewed sometimes the ceramic holders crack, remove element before ordering as you may have to replace the element holders.
    Hope this has been helpful
    john
    May 31, 2011 | Belling Ovens
    I have a Maytag Gemini Double Oven Range. The model is nowhere on the appliance but on the manual it could be a MER6555/6751/6755/6775 or 6875. The lower over heating elemant on the bottom stopped working...
    turn off breaker or unplug. then wires commonly burn out near the heating element. To determine if a wire has burned out, inspect the wires leading to the element. If a wire is burned out, it will often be visibly burnt.
    Jan 14, 2018 | Maytag Gemini 30" Self-Cleaning...
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    My right front burner will not turn off on my electric stove top.
    Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
    Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
    Oven heat
    There is a bottom hidden element that is the main element used for baking and cleaning. If its not heating then the element has gone bad and needs replacing. If you have a volt meter then you can confirm this by checking the voltage between the two terminals sticking out of the rear of the range. There should be 240vac across the two. If you have that then you need a new element if you don't then you need a new control board.
    Nov 03, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
    Problem w/burners & lights after self clean
    You may want to re-seat the right two cooking elements, in case there is poor electrical contact. When you have them removed, clean the contacts with denatured 91% alcohol and a Q-tip. The removal procedure follows.
    First, unplug the range.
    LIFT–UP PORCELAIN COOKTOP
    To lift:  When cool, grasp the cooktop front
    edge.  Gently lift up until the two support rods
    snap into place.
    To lower:  Hold the cooktop front edge and
    carefully push back on each support rod to
    release.  Then lower the top into place.
    COIL ELEMENTS
    ➢When an element is on, it will cycle on
    and off to maintain the heat setting.
    ➢Coil elements are self-cleaning. Do not
    immerse in water.
    To remove:  When cool, raise element.  Carefully pull out and away from receptacle.
    Check them for damage. They do wear out.
    To replace:  Insert element terminals into receptacle.  Guide the element into place. Press down on the outer edge of element until it sits level on drip bowl.
    COIL ELEMENT SURFACE
    ➢ On Canadian models, the two front elements will not operate during self-clean.To prevent the risk of electric shock or fire, never line drip bowls with aluminum foil.
    If that does work, you may have a faulty control panel. In that case, call Maytag at the number below.
    Maytag Customer Service
    533 Benson Road
    Benton Harbor,MI 49022
    (800)688-9900 U.S.
    (800)688-2002 Canada
    Dec 03, 2007 | Maytag MER6772 Gemini Electric Kitchen...
    KitchenAid KESC307 Electric Kitchen Range Logo
    151 people viewed this question
    Top KitchenAid Kitchen Ranges Experts
    Colin Stickland
    Colin Stickland
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
